Gros probleme avec speedchecker
gros probleme , je n'arrive pas a enlever speedchecker
    no problemo :)
    Quelques conseils :
    Installe Malwarebyte's Anti-Malware : https://www.malekal.com/tutoriel-malwarebyte-anti-malware/
    Fais des scans réguliers avec, il est efficace.
    Pour prévenir les sites malicieux, tu peux installer Blockulicious : https://forum.malekal.com/viewtopic.php?t=46656&start=
    Pour ne plus te faire avoir.
    A lire - Programmes parasites / PUPs : https://www.malekal.com/adwares-pup-protection/
    1. he ben c'est nikel je te remercie beaucoup, je devenais fou :)
      1. ok, donc voila le rapport
        ========== OTL ==========
        C:\Program Files (x86)\0d2eb50b-7e49-47e8-8e3d-7f4a85cda9bc folder moved successfully.
        C:\ProgramData\kbNVhgUIxJ\dat folder moved successfully.
        C:\ProgramData\kbNVhgUIxJ folder moved successfully.
        C:\Program Files (x86)\12ad90c3-6e95-41ff-9132-78dd06d77028 folder moved successfully.
        C:\Users\Sofia\AppData\Local\com\FastPlayer.exe_Url_ypw5ldaz5xtubzl3ykl5vaw3nmhswq1q\1.0.0.3 folder moved successfully.
        C:\Users\Sofia\AppData\Local\com\FastPlayer.exe_Url_ypw5ldaz5xtubzl3ykl5vaw3nmhswq1q folder moved successfully.
        C:\Users\Sofia\AppData\Local\com folder moved successfully.
        C:\Windows\SysNative\drivers\webinstrNewH.sys moved successfully.
        File C:\Program Files (x86)\Software\Update\1.2.195.0\npSoftwareOneClick8.dll not found.
        Service webinstrNewH stopped successfully!
        Service webinstrNewH deleted successfully!
        File C:\Windows\SysNative\drivers\webinstrNewH.sys not found.
        OTL by OldTimer - Version 3.2.69.0 log created on 12082014_161806
          Relance OTL.
          o sous Personnalisation (Custom Scan), copie_colle le contenu ci dessous (bien prendre :OTL en début).
          Clic Correction (Fix), un rapport apparraitra, copie/colle le contenu ici:
          :OTL
          [2014/12/08 04:02:55 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\0d2eb50b-7e49-47e8-8e3d-7f4a85cda9bc
          [2014/12/08 03:58:37 | 000,000,000 | ---D | C] -- C:\ProgramData\kbNVhgUIxJ
          [2014/12/08 03:33:31 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\12ad90c3-6e95-41ff-9132-78dd06d77028
          [2014/12/08 03:32:09 | 000,000,000 | ---D | C] -- C:\Users\Sofia\AppData\Local\com
          [2014/12/08 03:29:33 | 000,106,456 | ---- | C] (Corsica) -- C:\Windows\SysNative\drivers\webinstrNewH.sys
          CHR - plugin: Software Update (Enabled) = C:\Program Files (x86)\Software\Update\1.2.195.0\npSoftwareOneClick8.dll
          DRV:[b]64bit:[/b] - [2014/12/08 03:29:16 | 000,106,456 | ---- | M] (Corsica) [Kernel | Auto | Running] -- C:\Windows\SysNative\drivers\webinstrNewH.sys -- (webinstrNewH)
          * poste le rapport ici
