Script shell
Bonjour, mon script de substitution ne fait pas toutes les modifs que j'attends (ss unix). QQ'un a-t-il une idée?
IFS="!"
if [ $# -lt 1 ]
then
echo "nom du fichier[.csv]"
exit
fi
for lg in `cat $1`
do
Fichier=`echo $lg | awk -F";" '{ printf "%s", $1 }'`
echo $Fichier
sed -e "s/Atout RPV/RPV/
{s/Null, 0, 0, Null)/Null, 0, 0, 1, Null, Null, Null, Null)/
s/Remise [Ff]icti[fv][ e]/Remise fictive/
s/ Null, 0, 0, 1)/ Null, 0, 0, 1, Null, Null, Null, Null)/
s/1, 3, 3, Null)/1, 3, 3, Null, Null, Null)/
" $UEFE_OT/g04/par/sql/$Fichier > wk2
mv -f wk2 $UEFE_OT/g04/par/sql/$Fichier
done
IFS="!"
if [ $# -lt 1 ]
then
exit
fi
for lg in `cat $1`
do
echo $Fichier
done
Configuration: Windows XP Mozilla 1.7.13
fichier entrée:
Insert Into DESCRIPTIONS Values (-14994, 2, 0, "Atout RPV", "Abonn")
Insert Into DESCRIPTIONS Values (-14992, 2, 0, "Remise fictive", "Remis")
Insert Into UNIT_CR_DEFINITIONS Values (24816, 1, 1, Null, Null, Null, Null, "01/01/1996 00:00", Null, "08/17/2002 00:00", -14992, 1, 3, 3, Null)
Insert Into CONTRACT_TYPES Values (24816, 6, 24816, Null, -1, -1, Null, 24816, Null, Null, 1, -14993, Null, -1, Null, Null, Null, Null, Null, 0, Null, 0, 0, 1)
Insert Into CONTRACT_TYPES Values (24816, 6, 24816, Null, -1, -1, Null, 24816, Null, Null, 1, -14993, Null, -1, Null, Null, Null, Null, Null, 0, Null, 0, 0, Null)
fichier sortie souhaité:
Insert Into DESCRIPTIONS Values (-14994, 2, 0, "RPV", "Abonn")
Insert Into DESCRIPTIONS Values (-14992, 2, 0, "Remise Fictive", "Remis")
Insert Into UNIT_CR_DEFINITIONS Values (24816, 1, 1, Null, Null, Null, Null, "01/01/1996 00:00", Null, "08/17/2002 00:00", -14992, 1, 3, 3, Null, Null, Null)
Insert Into CONTRACT_TYPES Values (24816, 6, 24816, Null, -1, -1, Null, 24816, Null, Null, 1, -14993, Null, -1, Null, Null, Null, Null, Null, 0, Null, 0, 0, 1, Null, Null, Null, Null)
Insert Into CONTRACT_TYPES Values (24816, 6, 24816, Null, -1, -1, Null, 24816, Null, Null, 1, -14993, Null, -1, Null, Null, Null, Null, Null, 0, Null, 0, 0, 1, NUll, Null, Null, Null)
fichier obtenu:
fictive non corrigée
1, 3, 3, Null) non corrigé
0, 0, 1) non corrigé -
ModérateurSalut,
Peut-on avoir un exemple de fichier d'entrée (de sortie aussi, enfin ce que tu attends du moins) et surtout à quel niveau il ne fait pas les substitutions ?
