Problème avec Java
Bonjour/Bonsoir, j'ai actuelement un Packard Bell sous Windows 8 et mon Java a un sérieux problème. Je m'explique, je joue à Minecraft puis lorsque je voulais me connecter à un serveur une phrase se met qui est celle-ci : Bad compress data format
Donc vut que sa me m'était sa, j'ai désiter de le désinstaller et le réinstaller mais lorsque j'ouvre l'application, les logs et sa met:
Bootstrap (v5)
Current time is Jun 1, 2014 9:48:35 PM
System.getProperty('os.name') == 'Windows 8'
System.getProperty('os.version') == '6.2'
System.getProperty('os.arch') == 'amd64'
System.getProperty('java.version') == '1.7.0_45'
System.getProperty('java.vendor') == 'Oracle Corporation'
System.getProperty('sun.arch.data.model') == '64'
Found cached update
Renaming C:\Users\robin\AppData\Roaming\.minecraft\launcher.pack.lzma.new to C:\Users\robin\AppData\Roaming\.minecraft\launcher.pack.lzma
Unable to rename - could be on another filesystem, trying copy & delete.
Copy & delete succeeded.
Looking for update
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma
Got reply in: 1162ms
Found update in time, waiting to download
Exception: javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: Invalid TLS padding data
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 2/10)
Got reply in: 634ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 3/10)
Got reply in: 567ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Got reply in: 557ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 5/10)
Got reply in: 549ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 6/10)
Got reply in: 396ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 7/10)
Got reply in: 422ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 8/10)
Got reply in: 514ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 9/10)
Got reply in: 538ms
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 10/10)
Got reply in: 537ms
Unable to download remote file. Check your internet connection/proxy settings.
Voila merci de m'aider au plus vite
Cordialement Robdu60112
Bootstrap (v5)
Found cached update
Looking for update
Got reply in: 634ms
Got reply in: 567ms
Got reply in: 557ms
Got reply in: 549ms
Got reply in: 396ms
Got reply in: 422ms
Got reply in: 514ms
Got reply in: 538ms
Got reply in: 537ms
Bootstrap (v5)
Current time is Jun 3, 2014 7:46:14 AM
Looking for update
Got reply in: 1238ms
No update found.
Reversing LZMA on C:\Users\robin\AppData\Roaming\.minecraft\launcher.pack.lzma to C:\Users\robin\AppData\Roaming\.minecraft\launcher.pack
FATAL ERROR: net.minecraft.bootstrap.FatalBootstrapError: Unable to un-lzma: java.io.FileNotFoundException: C:\Users\robin\AppData\Roaming\.minecraft\launcher.pack (Accès refusé)
at net.minecraft.bootstrap.Bootstrap.unpack(Bootstrap.java:146)
at net.minecraft.bootstrap.Bootstrap.execute(Bootstrap.java:123)
at net.minecraft.bootstrap.Bootstrap.main(Bootstrap.java:381)
Please fix the error and restart.
Voila se que sa me met maintenant quand j'allume Minecraft -
Non sa c'est quand j'ouvre l'application les logs apparaise et c'est sa
Cette erreur ne survient que lors de la connexion en serveur ?
Mon ordi est bien en 64 Bits alor je ne sais pas et avec Windows 8 j'ai déja tenté de le réinstaller java mais sa ne marche pas alor franchement je comprend pas
Ton ordinateur est-il sous 64 bit ? Sinon le problème peut venir de la
J'utilise le laucher que donne Minecraft sur leur site Minecraft.net et mon Java est en 64 Bits
As-tu vérifié la version de ton java ?
D'après ce que je lis ça n'est surement pas un problème de ton javais, ce n'est qu'une "Exception"
Je pense plus à un problème de client Minecraft. Quel launcher utilises-tu ?
