Problem lors de depoiement d'une application JEE
bonjour a tous,
j'arrive pas a déployer mon application chaque fois il me génère l'erreur suivant:
GRAVE: Exception lors de l'envoi de l'évènement contexte initialisé (context initialized) à l'instance de classe d'écoute (listener) org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SessionFactory' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.util.ArrayList' to required type 'java.lang.Class[]' for property 'annotatedClasses'; nested exception is java.lang.IllegalArgumentException: Cannot find class [com.model.User]
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
 at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
 at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
 at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
 at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
 at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:567)
 at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
 at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
 at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
 at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
 at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
 at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4797)
 at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5291)
 at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
 at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
 at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
 at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
 at java.util.concurrent.FutureTask.run(FutureTask.java:166)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
 at java.lang.Thread.run(Thread.java:717)
Caused by: org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.util.ArrayList' to required type 'java.lang.Class[]' for property 'annotatedClasses'; nested exception is java.lang.IllegalArgumentException: Cannot find class [com.model.User]
 at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:490)
 at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:516)
 at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:510)
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1406)
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1365)
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
 at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
 ... 21 more
Caused by: java.lang.IllegalArgumentException: Cannot find class [com.model.User]
 at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:294)
 at org.springframework.beans.propertyeditors.ClassEditor.setAsText(ClassEditor.java:63)
 at org.springframework.beans.TypeConverterDelegate.doConvertTextValue(TypeConverterDelegate.java:434)
 at org.springframework.beans.TypeConverterDelegate.doConvertValue(TypeConverterDelegate.java:406)
 at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:163)
 at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:110)
 at org.springframework.beans.TypeConverterDelegate.convertToTypedArray(TypeConverterDelegate.java:445)
 at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:175)
 at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:470)
 ... 27 more
Caused by: java.lang.ClassNotFoundException: com.model.User
 at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1713)
 at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1558)
 at org.springframework.util.ClassUtils.forName(ClassUtils.java:258)
 at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:291)
 ... 35 more
11 mai 2014 12:13:40 com.sun.faces.config.ConfigureListener contextInitialized
INFO: Initialisation de Mojarra 2.0.1 (FCS b02) pour le contexte '/ProjetMven'
11 mai 2014 12:13:40 com.sun.faces.spi.InjectionProviderFactory createInstance
INFO: JSF1048 : Présence d''annotations PostConstruct/PreDestroy  Les méthodes de beans gérés marquées avec ces annotations auront des annotations dites traitées.
11 mai 2014 12:13:41 org.primefaces.webapp.PostConstructApplicationEventListener processEvent
INFO: Running on PrimeFaces 3.5
11 mai 2014 12:13:41 com.sun.faces.config.ConfigureListener$WebConfigResourceMonitor$Monitor <init>
INFO: Monitoring jndi:/localhost/ProjetMven/WEB-INF/faces-config.xml for modifications
11 mai 2014 12:13:41 org.apache.catalina.core.StandardContext startInternal
GRAVE: Error listenerStart
GRAVE: Erreur de démarrage du contexte [/ProjetMven] suite aux erreurs précédentes
11 mai 2014 12:13:41 org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
11 mai 2014 12:13:41 org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
GRAVE: The web application [/ProjetMven] registered the JDBC driver [com.mysql.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
11 mai 2014 12:13:41 org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-apr-8180"]
INFO: Starting ProtocolHandler ["ajp-apr-8109"]
11 mai 2014 12:13:41 org.apache.catalina.startup.Catalina start
INFO: Server startup in 4636 ms
il dit qu'il n'arrive pas a trouver le chemin com.model.User et cette chemin bien existe dans mon projet donc je n'ai pas compris d'où vient cette erreur
aidez moi svp.
merci d'avance
  1. désolé, mais je ne vois pas où est le problème,
    mais il y ce cas-ci est très similaire au tien:
    http://stackoverflow.com/questions/5153539/class-not-found-exception
    1. ok merci je vais voir
    2. personne peut résoudre cet problème?
  2. bien sur ,
    voici ma classe user:
    package com.model;
    // default package
    // Generated 12 mai 2014 13:38:22 by Hibernate Tools 3.4.0.CR1
    import javax.persistence.Column;
    import javax.persistence.Entity;
    import javax.persistence.GeneratedValue;
    import static javax.persistence.GenerationType.IDENTITY;
    import javax.persistence.Id;
    import javax.persistence.Table;
    * User generated by hbm2java
    @Entity
    @Table(name = "user", catalog = "fac_medecine")
    public class User implements java.io.Serializable {
    private Integer id;
    private String login;
    private String password;
    public User() {
    public User(String login, String password) {
    this.login = login;
    this.password = password;
    @Id
    @GeneratedValue(strategy = IDENTITY)
    @Column(name = "Id", unique = true, nullable = false)
    public Integer getId() {
    return this.id;
    public void setId(Integer id) {
    this.id = id;
    @Column(name = "login", nullable = false, length = 50)
    public String getLogin() {
    return this.login;
    public void setLogin(String login) {
    this.login = login;
    @Column(name = "password", nullable = false, length = 50)
    public String getPassword() {
    return this.password;
    public void setPassword(String password) {
    et voici fichier de config applicationContext.xml
    <?xml version="1.0" encoding="UTF-8"?>
    <beans xmlns="http://www.springframework.org/schema/beans"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:tx="http://www.springframework.org/schema/tx"
    xmlns:context="http://www.springframework.org/schema/context"
    xsi:schemaLocation="http://www.springframework.org/schema/beans
    http://www.springframework.org/schema/beans/spring-beans-3.0.xsd
    http://www.springframework.org/schema/tx/spring-tx-3.0.xsd
    http://www.springframework.org/schema/context/spring-context-3.0.xsd">
    <!-- Data Source Declaration -->
    <bean id="dataSource" class="org.springframework.jdbc.datasource.DriverManagerDataSource">
    <property name="url">
    <value>jdbc:mysql://127.0.0.1:3306/projet?useUnicode=true&characterEncoding=UTF-8</value>
    </property>
    <property name="driverClassName">
    <value>com.mysql.jdbc.Driver</value>
    </property>
    <property name="username">
    <value>root</value>
    </property>
    <property name="password">
    <value></value>
    </property>
    </bean>
    <!-- Session Factory Declaration -->
    <bean id="SessionFactory" class="org.springframework.orm.hibernate4.LocalSessionFactoryBean">
    <property name="dataSource" ref="dataSource" />
    <property name="annotatedClasses">
    <list>
    <value>com.model.User</value>
    </list>
    </property>
    <property name="hibernateProperties">
    <props>
    <prop key="hibernate.dialect">org.hibernate.dialect.MySQLDialect</prop>
    <prop key="hibernate.show_sql">false</prop>
    </props>
    </property>
    </bean>
    <!-- Enable the configuration of transactional behavior based on annotations -->
    <tx:annotation-driven transaction-manager="txManager"/>
    <!-- Transaction Manager is defined -->
    <bean id="txManager" class="org.springframework.orm.hibernate4.HibernateTransactionManager">
    <property name="sessionFactory" ref="SessionFactory"/>
    </bean>
    <!-- User Service Declaration -->
    <bean id="indexService" class="com.service.IndexService">
    <property name="indexDao" ref="indexDao" />
    </bean>
    <bean id="genericService" class="com.service.GenericService">
    <property name="genericDao" ref="genericDao" />
    </bean>
    <!-- User DAO Declaration -->
    <bean id="indexDao" class="com.dao.IndexDao">
    </bean>
    <bean id="genericDao" class="com.dao.GenericDao">
    <property name="sessionFactory" ref="SessionFactory" />
    </bean>
    </beans>
    et encore ceci ma classe bean
    package com.bean;
    import java.util.ArrayList;
    import java.util.List;
    import javax.faces.application.FacesMessage;
    import javax.faces.bean.ManagedBean;
    import javax.faces.bean.ManagedProperty;
    import javax.faces.bean.SessionScoped;
    import javax.faces.context.FacesContext;
    import javax.faces.event.ActionEvent;
    import org.primefaces.component.datatable.DataTable;
    import com.model.User;
    import com.service.IGenericService;
    import com.service.IIndexService;
    import com.utils.ClassUtils;
    @ManagedBean(name="userBean")
    @SessionScoped
    public class UserBean {
    @ManagedProperty(value="#{genericService}")
    IGenericService genericService;
    //private List<User> users=new ArrayList<User>();
    private DataTable usersTable;
    private User user = new User();
    private User addUser = new User();
    private boolean connected = false;
    private List<User> filteredCars;
    @ManagedProperty(value="#{indexService}")
    IIndexService indexService;
    public String connect(){
    // ClassUtils classUtils=new ClassUtils();
    System.out.println(user.getLogin());
    user.setPassword(ClassUtils.getEncodedPassword(user.getPassword()));
    System.out.println(user.getPassword());
    user = indexService.connect(user);
    if(user!=null){
    connected = true;
    user.setPassword(null);
    return ClassUtils.CONNECT;
    else{
    ClassUtils.messageError(FacesMessage.SEVERITY_INFO,"Error connexion!","",null);
    user=new User();
    return null;
    // pour affichier la liste des users
    public String displayUsers() {
    System.out.print("dans display users");
    List<Object> objects = genericService.getAllObject(User.class);
    users = new ArrayList<User>();
    for(Object o : objects){
    users.add((User) o);
    //zoneDisplayBooks = true
    return ClassUtils.LISTEUSERS;
    //pour ajouter un user
    public void saveUser(ActionEvent actionEvent){
    if(addUser.getId()==0)
    genericService.saveObject(addUser);
    else
    genericService.updateObject(addUser);
    FacesContext context = FacesContext.getCurrentInstance();
    context.addMessage(null, new FacesMessage("Utilisateur Bien Ajouter"));
    addUser=new User();
    //return null;
    //action de navigation
    public String ajoutMembre(){
    System.out.print("voila");
    return ClassUtils.AJOUTERMEMBRE;
    public String listeUsers(){
    public void test(){
    System.out.print("test Action listenaire");
    //edit popop pour la modification
    public void editEvent(int id) {
    user=(User) genericService.getObject(User.class,id);
    //pour la mise a jour
    public void edition(ActionEvent e){
    genericService.updateObject(user);
    context.addMessage(null, new FacesMessage("Utilisateur mise à jour"));
    int i=0;
    for (User s : users) {
    if (s.getId()==user.getId())
    break;
    i++;
    users.set(i, user);
    //pour la suppression
    public void delet(User o) {
    genericService.deleteObject(o);
    context.addMessage(null, new FacesMessage("Utilisateur Supprimer"));
    int i=0;
    break;
    i++;
    users.remove(i);
    public User getUser() {
    return user;
    public void setUser(User user) {
    this.user = user;
    public void setIndexService(IIndexService indexService) {
    this.indexService = indexService;
    public boolean isConnected() {
    return connected;
    public void setConnected(boolean connected) {
    this.connected = connected;
    public IIndexService getIndexService() {
    return indexService;
    public IGenericService getGenericService() {
    return genericService;
    public void setGenericService(IGenericService genericService) {
    this.genericService = genericService;
    public User getAddUser() {
    return addUser;
    public void setAddUser(User addUser) {
    this.addUser = addUser;
    public List<User> getUsers() {
    System.out.print("dans get users");
    return users;
    public void setUsers(List<User> users) {
    this.users = users;
    public DataTable getUsersTable() {
    return usersTable;
    public void setUsersTable(DataTable usersTable) {
    this.usersTable = usersTable;
    public List<User> getFilteredCars() {
    this.displayUsers();
    return filteredCars;
    public void setFilteredCars(List<User> filteredCars) {
    this.filteredCars = filteredCars;
    1. est-ce qu'il est possible de voir ta class
      com.model.User et ton fichier de conf applicationContext.xml?
      ou sinon, il semble que tu veuilles caster un tableau []
      en arraylist ce qui n'est pas permis.
