Problème installation Minecraft
Comme bon nombre d'utilisateurs, nous avons un pb lorsque nous voulons installer MINECRAFT.
Nous avons réinstallé JAVA, arrêté l'antivirus, mais rien n'y fait.
Avez-vous la solution ?
Merci beaucoup par avance
Voici le message d'erreur qui apparait :
Bootstrap (v5)
Current time is Oct 5, 2013 10:04:29 PM
System.getProperty('os.name') == 'Windows 7'
System.getProperty('os.version') == '6.1'
System.getProperty('os.arch') == 'amd64'
System.getProperty('java.version') == '1.6.0_24'
System.getProperty('java.vendor') == 'Sun Microsystems Inc.'
System.getProperty('sun.arch.data.model') == '64'
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma
Exception: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Recognized exception: the likely cause is a set of broken/missing root-certificates. Check your java install and perhaps reinstall it.
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 2/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 3/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 5/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 6/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 7/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 8/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 9/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 10/10)
Unable to download remote file. Check your internet connection/proxy settings.
FATAL ERROR: net.minecraft.bootstrap.FatalBootstrapError: Unable to download while being forced
at net.minecraft.bootstrap.Bootstrap.execute(Bootstrap.java:95)
at net.minecraft.bootstrap.Bootstrap.main(Bootstrap.java:381)
Please fix the error and restart.
  1. Appuis sur la touche windows et la touche R en même temps et une fenêtre de recherche apparaît tape %appdata% > roaming et suprime le fichier .minecraft
    Puis relance le laucher et normalement ça marche :D
