Probleme minecraft installation
Bonjour/bonsoir à vous, je tien d'avance a m'excuser si un topic à déja été fait à ce sujet, mais je n'arrive pas à lancer Minecraft 1.6.4. Le laucher s'affiche et lorsque je met play la page disparait, comme pour lancer le jeu, puis réapparait ainsi :
Refreshing local version list...
Launcher 1.2.5 (through bootstrap 5) started on windows...
Current time is Sep 23, 2013 8:14:26 PM
System.getProperty('os.name') == 'Windows 8'
System.getProperty('os.version') == '6.2'
System.getProperty('os.arch') == 'x86'
System.getProperty('java.version') == '1.7.0_40'
System.getProperty('java.vendor') == 'Oracle Corporation'
System.getProperty('sun.arch.data.model') == '32'
Refreshing remote version list...
Refresh complete.
Loaded 1 profile(s); selected 'Dessnoff'
Refreshing auth...
Logging in with access token
Getting syncinfo for selected version
Queueing library & version downloads
Download job 'Version & Libraries' started (8 threads, 19 files)
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput-platform\2.0.5\jinput-platform-2.0.5-natives-windows.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl-platform\2.9.0\lwjgl-platform-2.9.0-natives-windows.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar for job 'Version & Libraries': Used own copy as it matched etag
Finished downloading C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4.jar for job 'Version & Libraries': Used own copy as it matched etag
Job 'Version & Libraries' finished successfully
Delta time to compare resources: 9924 ms
Download job 'Resources' skipped as there are no files to download
Job 'Resources' finished successfully
Launching game
Looking for old natives to clean up...
Unpacking natives to C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4-natives-7922669253241
Launching in C:\Users\davidderai\AppData\Roaming\.minecraft
Running C:\Program Files (x86)\Java\jre7\bin\javaw.exe -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -Djava.library.path=C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4-natives-7922669253241 -cp C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar;C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4.jar net.minecraft.client.main.Main --username Dessnoff --session token:80ce1e7abae845e99db15ca3eb93f6ed:14eb56a18bc64d34a2387dfeb580492f --version 1.6.4 --gameDir C:\Users\davidderai\AppData\Roaming\.minecraft --assetsDir C:\Users\davidderai\AppData\Roaming\.minecraft\assets
Client> 2013-09-23 20:14:37 [CLIENT] [INFO] Setting user: Dessnoff
Client> 2013-09-23 20:14:37 [CLIENT] [INFO] (Session ID is token:80ce1e7abae845e99db15ca3eb93f6ed:14eb56a18bc64d34a2387dfeb580492f)
Client> 2013-09-23 20:14:38 [CLIENT] [INFO] LWJGL Version: 2.9.0
Client> #
Client> # A fatal error has been detected by the Java Runtime Environment:
Client> #
Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6163b77e, pid=6800, tid=3932
Client> #
Client> # JRE version: Java(TM) SE Runtime Environment (7.0_40-b43) (build 1.7.0_40-b43)
Client> # Java VM: Java HotSpot(TM) Client VM (24.0-b56 mixed mode, sharing windows-x86 )
Client> # Problematic frame:
Client> # C [ig7icd32.dll+0x3b77e]
Client> #
Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Client> #
Client> # An error report file with more information is saved as:
Client> # C:\Users\davidderai\AppData\Roaming\.minecraft\hs_err_pid6800.log
Client> #
Client> # If you would like to submit a bug report, please visit:
Client> # https://bugreport.java.com/bugreport/crash.jsp
Client> # The crash happened outside the Java Virtual Machine in native code.
Client> # See problematic frame for where to report the bug.
Client> #
Client>
Client> [error occurred during error reporting , id 0xc0000005]
Client>
Game ended with bad state (exit code -1)
Ignoring visibility rule and showing launcher due to a game crash
Deleting C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4-natives-7922669253241
Couldn't delete C:\Users\davidderai\AppData\Roaming\.minecraft\versions\1.6.4\1.6.4-natives-7922669253241 - scheduling for deletion upon exit
Sachant que je ne comprend absolument rien je vien pour un apelle à l'aide. Je ne sais pas ce qui déconne j'ai desinstaller et réinstaller Java mais je n'y comprend plus rien, à l'aide svp :D
(ps : désoler pour les fautes d'orthographes)
