Comment supprimer optimizer pro?
j'ai télécharger une mise à jour d'adobe flash et je me suis retrouvé avec ce programme que je n'arrive pas à désinstaller. pouvez vous m'aider s'il vous plait?
  1. Contributeur sécurité
    Coucou
    J'attends le rapport Malwarebytes.
    1. salut juju, merci pour ton aide.
      Voici le rapport généré à la fin de l"analyse.
      Junkware Removal Tool (JRT) by Thisisu
      Version: 6.1.1 (02.04.2014:1)
      OS: Windows 7 Home Premium x86
      Ran by pacckard on 14/02/2014 at 22:06:18,05
      ~~~ Services
      Failed to stop: [Service] update cling clang
      ~~~ Registry Values
      Successfully repaired: [Registry Value] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\\Start Page
      Successfully repaired: [Registry Value] HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\Main\\Start Page
      Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-18\Software\Microsoft\Internet Explorer\Main\\Start Page
      Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-19\Software\Microsoft\Internet Explorer\Main\\Start Page
      Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-20\Software\Microsoft\Internet Explorer\Main\\Start Page
      Successfully repaired: [Registry Value] HKEY_USERS\S-1-5-21-2250316559-1643956302-2326966066-1000\Software\Microsoft\Internet Explorer\Main\\Start Page
      ~~~ Registry Keys
      Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\CLSID\{1AA60054-57D9-4F99-9A55-D0FBFBE7ECD3}
      Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Tracing\backupstack_rasapi32
      Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Tracing\backupstack_rasmancs
      Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Tracing\iLividSetupV1 (1)_RASAPI32
      Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Tracing\iLividSetupV1 (1)_RASMANCS
      Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{126D4697-F4DC-4EDA-9CE5-7E14B0FE238D}
      Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA9AA36B-5B7B-4996-B083-83EF84D53B19}
      ~~~ Files
      Successfully deleted: [File] C:\Windows\Tasks\registrybooster.job
      Successfully deleted: [File] C:\Windows\system32\shoCFB.tmp
      ~~~ Folders
      Successfully deleted: [Folder] "C:\Users\pacckard\appdata\local\cre"
      Successfully deleted: [Folder] "C:\Users\pacckard\appdata\locallow\datamngr"
      Failed to delete: [Folder] "C:\Program Files\cling clang"
      Successfully deleted: [Folder] "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\uniblue"
      ~~~ FireFox
      Successfully deleted: [File] C:\user.js
      Successfully deleted: [File] C:\Users\pacckard\AppData\Roaming\mozilla\firefox\profiles\i4mmp237.default\user.js
      Successfully deleted: [Folder] C:\Users\pacckard\AppData\Roaming\mozilla\firefox\profiles\i4mmp237.default\extensions\staged
      Successfully deleted the following from C:\Users\pacckard\AppData\Roaming\mozilla\firefox\profiles\i4mmp237.default\prefs.js
      user_pref("browser.startup.homepage", "hxxp://start.iminent.com/?appId=320A522D-802C-4A68-A77B-24A81AC358F6");
      user_pref("iminent.enabledAds", "false");
      user_pref("iminent.newtabredirect", "true");
      user_pref("iminent.searchindex", "1");
      Emptied folder: C:\Users\pacckard\AppData\Roaming\mozilla\firefox\profiles\i4mmp237.default\minidumps [6 files]
      ~~~ Event Viewer Logs were cleared
      Scan was completed on 14/02/2014 at 22:10:43,92
      End of JRT log
        Salut Karine,
        ▶ Télécharge ici : Junkware Removal Tool
        !!! Ne clique pas sur Download !!! , attends simplement que la fenetre de telechargement arrive pour confirmation
        ▶ Enregistre ce fichier sur le bureau.
        ▶ Ferme tout tes navigateurs
        Sous XP, double-clique sur l'icône et presse une touche lorsque cela sera demandé.
        Sous Vista/7/8, clic droit et Exécuter en temps qu'administrateur.
        ▶ NB: Le bureau disparaitra un instant, c'est normal.
        ▶ Laisse le programme travailler ne touche plus à rien
        ▶ Poste le rapport généré à la fin de l'analyse.
        Tuto : http://hackinginterdit.blogspot.fr/2013/02/junkware-removal-tool.html
        ▶ Télécharge et installe Malwarebytes' Anti-Malware (MBAM).
        ▶ Exécute-le. Accepte la mise à jour.
        ▶ Sélectionne "Exécuter un examen complet"
        ▶ Clique sur "Rechercher"
        ▶ L'analyse démarre, le scan est relativement long, c'est normal.
        A la fin de l'analyse, un message s'affiche :
        Citation :
        L'examen s'est terminé normalement. Clique sur 'Afficher les résultats' pour afficher tous les objets trouvés.
        ▶ Clique donc sur Afficher les résultats.
        ▶ Sélectionne tout (ou laisse coché) et clique sur Supprimer la sélection, MBAM va détruire les fichiers et clés de registre et en mettre une copie dans la quarantaine.
        MBAM va ouvrir le Bloc-notes et y copier le rapport d'analyse : ferme le.
        Si MBAM demande à redémarrer le pc : ▶ fais-le.
        Au redémarrage, relance MBAM, onglet "Rapport/Logs", copie/colle celui qui correspond à l'analyse effectuée.
        A+
        1. Bonjour Juju,
          Voici les rapports, je suis pas douée je l'ai lancé 2 fois ...
          Par contre j'ai toujours plein de publicités qui s'affichent avec des installations et mises à jour.
          Premier rapport :
          # AdwCleaner v3.018 - Rapport créé le 13/02/2014 à 21:29:02
          # Mis à jour le 28/01/2014 par Xplode
          # Système d'exploitation : Windows 7 Home Premium Service Pack 1 (32 bits)
          # Nom d'utilisateur : pacckard - PACCKARD-PC
          # Exécuté depuis : C:\Users\pacckard\Desktop\adwcleaner.exe
          # Option : Nettoyer
          ***** [ Services ] *****
          [x] Non Supprimé : APNMCP
          [x] Non Supprimé : BackupStack
          [x] Non Supprimé : SProtection
          ***** [ Fichiers / Dossiers ] *****
          [x] Non Supprimé : C:\ProgramData\apn
          [x] Non Supprimé : C:\ProgramData\Ask
          [x] Non Supprimé : C:\ProgramData\Babylon
          [x] Non Supprimé : C:\ProgramData\boost_interprocess
          [x] Non Supprimé : C:\ProgramData\Iminent
          [x] Non Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Iminent
          [x] Non Supprimé : C:\Program Files\Conduit
          [x] Non Supprimé : C:\Program Files\Iminent
          [x] Non Supprimé : C:\Program Files\MyPC Backup
          [x] Non Supprimé : C:\Program Files\Common Files\Umbrella
          [x] Non Supprimé : C:\Users\pacckard\AppData\Local\comnetwork
          [x] Non Supprimé : C:\Users\pacckard\AppData\Local\Conduit
          Dossier Supprimé : C:\Users\pacckard\AppData\Local\Ilivid Player
          [x] Non Supprimé : C:\Users\pacckard\AppData\Local\PackageAware
          [x] Non Supprimé : C:\Users\pacckard\AppData\LocalLow\Conduit
          [x] Non Supprimé : C:\Users\pacckard\AppData\LocalLow\searchquband
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Babylon
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\cacaoweb
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Iminent
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\IminentToolbar
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MyPC Backup
          Dossier Supprimé : C:\Users\pacckard\Documents\optimizer pro
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Smartbar
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\CT3128284
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Extensions\{8e5025c2-8ea3-430d-80b8-a14151068a6d}
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Extensions\***@***
          [x] Non Supprimé : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          [x] Non Supprimé : C:\END
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\MyPC Backup.lnk
          [x] Non Supprimé : C:\Program Files\Mozilla Firefox\defaults\pref\all-iminent.js
          [x] Non Supprimé : C:\Program Files\Mozilla Firefox\searchplugins\Babylon.xml
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\searchplugins\iminent.xml
          [x] Non Supprimé : C:\Program Files\Mozilla Firefox\searchplugins\StartWeb.xml
          [x] Non Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\user.js
          [x] Non Supprimé : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_igdhbblpcellaljokkpfhcjlagemhgjl_0.localstorage
          ***** [ Raccourcis ] *****
          ***** [ Registre ] *****
          [x] Non Supprimé : HKCU\Software\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          [x] Non Supprimé : HKLM\SOFTWARE\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          [x] Non Supprimé : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [cacaoweb]
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\AmiBs.Installer
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\AmiBs.Installer.1
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\AppID\Iminent.WebBooster.InternetExplorer.DLL
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Applications\ilividsetupv1.exe
          Clé Supprimée : HKLM\SOFTWARE\Classes\ilivid
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.DownloadArgs
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.LinkToPromoteArgs
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.RawDataArgs
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.TinyUrlArgs
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.ViralLinkArgs
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ClientCallback
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ContractBase
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.AddToUserContentCommand
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.CheckLoginStatusCommand
          [x] Non Supprimé : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.CleanCacheCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GameOverCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetCreditCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetInstallationContextCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetLoginStatusCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetLoginStatusResult
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetVariableCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.GetVariableResult
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.InstallationContextResult
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.LoadContentCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.LoadContentCommandResult
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.LoginCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.LoginStatusChangedCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.LogoutCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.MergeIdentityCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.MyAccountCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.PlayContentCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.PostContentCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.RecycleViewsCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.SetVariableCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.ShowBrowserWindowCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.ShowControlCenterCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.ShowPluginWindowCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.TestContentCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.UserContentChangedCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.VariableChangedCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.WarmUpCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.WelcomeCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ServerCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ServerResult
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.LightContent
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.LightUri
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.MediatorServiceProxy
          Clé Supprimée : HKLM\SOFTWARE\Classes\IminentWebBooster.BrowserHelperObject
          Clé Supprimée : HKLM\SOFTWARE\Classes\IminentWebBooster.BrowserHelperObject.1
          Clé Supprimée : HKLM\SOFTWARE\Classes\IminentWebBooster.ScriptExtender
          Clé Supprimée : HKLM\SOFTWARE\Classes\IminentWebBooster.ScriptExtender.1
          Clé Supprimée : HKLM\SOFTWARE\Classes\Prod.cap
          Clé Supprimée : HKLM\SOFTWARE\Classes\protector_dll.protectorbho
          Clé Supprimée : HKLM\SOFTWARE\Classes\protector_dll.protectorbho.1
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\au__rasapi32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\au__rasmancs
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ConduitInstaller_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ConduitInstaller_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividSetupV1_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividSetupV1_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\Iminent_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\Iminent_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\Searchqu Toolbar uninstall_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\Searchqu Toolbar uninstall_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SearchquMediaBar_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SearchquMediaBar_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SetupDataMngr_Searchqu_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SetupDataMngr_Searchqu_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\TaskScheduler_RASAPI32
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\TaskScheduler_RASMANCS
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\mypc backup
          Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [ApnTbMon]
          Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [comnetwork]
          Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [Iminent]
          Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [IminentMessenger]
          Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar.CT3128284
          Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{01994268-3C10-4044-A1EA-7A9C1B739A11}
          Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{BDB69379-802F-4EAF-B541-F8DE92DD98DB}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{01A602A0-D0B9-445B-8081-719E4177C4A7}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{02054E11-5113-4BE3-8153-AA8DFB5D3761}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{02C9C7B0-C7C8-4AAC-A9E4-55295BF60F8F}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{0398B101-6DA7-473F-A290-17D2FBC88CC0}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{0CC36196-8589-4B80-A771-D659411D7F90}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{143D96F9-EB64-48B3-B192-91C2C41A1F43}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{14F7D91F-F669-45C9-9F42-BACBFDB86EAD}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{187A6488-6E71-4A2A-B118-7BEFBFE58257}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{2D065204-A024-4C39-8A38-EE7078EC7ACF}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{30F5476C-677B-4DB0-B397-51F5BFD86840}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3223F2FB-D9B9-45FC-9D66-CD717FFA4EE5}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{351798B1-C1D2-45AB-92B4-4D6C2D6AB5AF}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3AEA1BEF-6195-46F4-ACA2-0ED14F7EFA1B}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3D7F9AC3-BAC3-4E51-81D7-D121D79E550A}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{4498C5E9-93C6-4142-B6BE-F0C6DC48B77A}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{479BF2D6-E362-4A99-B1AB-BC764D7B97AE}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{492A108F-51D0-4BD8-899D-AD4AB2893064}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{4B6D6E60-FBD2-4E79-BF4B-886BC98F1797}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{5C176BA0-6FC0-4EBD-8ACF-24AC592506B6}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{60893E02-2E5B-43F9-A93A-BAD60C2DF6EF}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{6D39931F-451E-4BDD-BAF4-37FB96DBBA5D}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{76C684D2-C35D-4284-976A-D862F53ADB81}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{796D822A-C3F9-4A97-BAAB-42FE7628EA63}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{79EF3691-EC1A-4705-A01A-D2E36EC11758}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{82F41418-8E64-47EB-A7F1-4702A974D289}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{85D920CE-63A7-46DC-8992-41D1D2E07FAD}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{895ED5E8-ABB4-40C3-A0CA-2571964268E2}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{8AAC123A-1959-4A45-BFC5-E2D50783098A}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{99079A25-328F-4BD4-BE04-00955ACAA0A7}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{A07956CD-81F8-4A03-B524-5D87E690DC83}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{A09AB6EB-31B5-454C-97EC-9B294D92EE2A}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{A6FEED89-3BCD-4D19-9DC2-3E613A80A2A4}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{B5E3B26B-6E5C-4865-A63D-58D04B10E245}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{B84D2DC5-42B2-4E5E-BF61-7B48152FF8EF}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{B89D5309-0367-4494-A92F-3D4C94F88307}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C014EBF8-8854-448B-B5A4-557C4090EDCE}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C31191DB-2F64-464C-B97C-6AC81ACB7AAC}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C342C7A7-F622-4EF3-8B7F-ABB9FBE73F14}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C4765B07-BC2F-477B-925C-B2BF24887823}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C875C0A1-09E3-48D5-9F8E-BD337796FD14}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{CD126DA6-FF5B-4181-AC13-54A62240D2FA}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{DD438708-AAB4-422D-A322-B619589F5680}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{E812AE43-7799-4E67-8CF8-4104297A2D16}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{F0BAAEC7-9AE0-49FF-9C4B-86E774FF397F}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{F92193FD-2243-4401-9ACC-49FF30885898}
          Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{FD21B8A2-910B-45AC-9C10-45E6A8B84984}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{021B4049-F57D-4565-A693-FD3B04786BFA}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{0362AA09-808D-48E9-B360-FB51A8CBCE09}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{06844020-CD0B-3D3D-A7FE-371153013E49}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{0ADC01BB-303B-3F8E-93DA-12C140E85460}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{10D3722F-23E6-3901-B6C1-FF6567121920}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{1675E62B-F911-3B7B-A046-EB57261212F3}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{192929F2-9273-3894-91B0-F54671C4C861}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2932897E-3036-43D9-8A64-B06447992065}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2DE92D29-A042-3C37-BFF8-07C7D8893EFA}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{32B80AD6-1214-45F4-994E-78A5D482C000}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3A8E103F-B2B7-3BEF-B3B0-88E29B2420E4}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{478CE5D3-D38E-3FFE-8DBE-8C4A0F1C4D8D}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{48B7DA4E-69ED-39E3-BAD5-3E3EFF22CFB0}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{5982F405-44E4-3BBB-BAC4-CF8141CBBC5C}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{5D8C3CC3-3C05-38A1-B244-924A23115FE9}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{641593AF-D9FD-30F7-B783-36E16F7A2E08}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{711FC48A-1356-3932-94D8-A8B733DBC7E4}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{72227B7F-1F02-3560-95F5-592E68BACC0C}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{7B5E8CE3-4722-4C0E-A236-A6FF731BEF37}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{890D4F59-5ED0-3CB4-8E0E-74A5A86E7ED0}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{8C68913C-AC3C-4494-8B9C-984D87C85003}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{8D019513-083F-4AA5-933F-7D43A6DA82C4}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{923F6FB8-A390-370E-A0D2-DD505432481D}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{9BBB26EF-B178-35D6-9D3D-B485F4279FE5}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{A62DDBE0-8D2A-339A-B089-8CBCC5CD322A}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{A82AD04D-0B8E-3A49-947B-6A69A8A9C96D}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{ADEB3CC9-A05D-4FCC-BD09-9025456AA3EA}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{B06D4521-D09C-3F41-8E39-9D784CCA2A75}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{C06DAD42-6F39-4CE1-83CC-9A8B9105E556}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{C2E799D0-43A5-3477-8A98-FC5F3677F35C}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{C58D664A-3DBC-4925-AE74-0382007DF113}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{C776D7F4-BA85-4B75-AAFC-3A0A11FE6E36}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D16107CD-2AD5-46A8-BA59-303B7C32C500}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D25B101F-8188-3B43-9D85-201F372BC205}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D2BA7595-5E44-3F1E-880F-03B3139FA5ED}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D35F5C81-17D9-3E1C-A1FC-4472542E1D25}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D54C859C-6066-4F31-8FE0-2AAEDCAE67D7}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D8FA96CA-B250-312C-AF34-4FF1DD72589D}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{DAFC1E63-3359-416D-9BC2-E7DCA6F7B0F3}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{DC5E5C44-80FD-3697-9E65-9F286D92F3E7}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{E1B4C9DE-D741-385F-981E-6745FACE6F01}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{E7B623F5-9715-3F9F-A671-D1485A39F8A2}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{ED916A7B-7C68-3198-B87D-2DABC30A5587}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{EFA1BDB2-BB3D-3D9A-8EB5-D0D22E0F64F4}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{F4CBF4DD-F8FE-35BA-BB7E-68304DAAB70B}
          Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{FC32005D-E27C-32E0-ADFA-152F598B75E7}
          Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{1C1356DA-1E98-4810-A9F6-18D89BD1C0C0}
          Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{2BF2028E-3F3C-4C05-AB45-B2F1DCFE0759}
          Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{A9CAF365-EA35-45DA-BD8B-2EFA09D374AC}
          Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{DB538320-D3C5-433C-BCA9-C4081A054FCF}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{99079A25-328F-4BD4-BE04-00955ACAA0A7}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A09AB6EB-31B5-454C-97EC-9B294D92EE2A}
          Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{00000000-6E41-4FD3-8538-502F5495E5FC}
          Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{99079A25-328F-4BD4-BE04-00955ACAA0A7}
          Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{99079A25-328F-4BD4-BE04-00955ACAA0A7}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{0AF350D9-3916-454B-AC53-0B0B65F41301}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68B81CCD-A80C-4060-8947-5AE69ED01199}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E6B969FB-6D33-48D2-9061-8BBD4899EB08}
          Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
          Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}
          Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
          Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{99079A25-328F-4BD4-BE04-00955ACAA0A7}]
          Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{D4027C7F-154A-4066-A1AD-4243D8127440}]
          Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{84FF7BD6-B47F-46F8-9130-01B2696B36CB}]
          Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{8E5025C2-8EA3-430D-80B8-A14151068A6D}]
          Clé Supprimée : HKCU\Software\AskPartnerNetwork
          Clé Supprimée : HKCU\Software\cacaoweb
          Clé Supprimée : HKCU\Software\Conduit
          Clé Supprimée : HKCU\Software\DataMngr
          Clé Supprimée : HKCU\Software\FreeSoftToday
          Clé Supprimée : HKCU\Software\Grand Virtual
          Clé Supprimée : HKCU\Software\ilivid
          Clé Supprimée : HKCU\Software\Iminent
          Clé Supprimée : HKCU\Software\Tutorials
          Clé Supprimée : HKCU\Software\TutoTag
          Clé Supprimée : HKCU\Software\AppDataLow\{1146AC44-2F03-4431-B4FD-889BC837521F}
          Clé Supprimée : HKCU\Software\AppDataLow\Software\searchqutoolbar
          Clé Supprimée : HKCU\Software\AppDataLow\Software\smartbar
          Clé Supprimée : HKLM\Software\{1146AC44-2F03-4431-B4FD-889BC837521F}
          Clé Supprimée : HKLM\Software\{6791A2F3-FC80-475C-A002-C014AF797E9C}
          Clé Supprimée : HKLM\Software\AskPartnerNetwork
          Clé Supprimée : HKLM\Software\Babylon
          Clé Supprimée : HKLM\Software\Conduit
          Clé Supprimée : HKLM\Software\FreeSoftToday
          Clé Supprimée : HKLM\Software\ilivid
          Clé Supprimée : HKLM\Software\Iminent
          Clé Supprimée : HKLM\Software\Tutorials
          Clé Supprimée : HKLM\Software\Umbrella
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ilivid
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IMBoosterARP
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Iminent
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyPC Backup
          Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SearchTheWebARP
          Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5
          Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375
          ***** [ Navigateurs ] *****
          -\\ Internet Explorer v11.0.9600.16428
          Paramètre Restauré : HKCU\Software\Microsoft\Internet Explorer\Main [First Home Page]
          -\\ Mozilla Firefox v15.0.1 (fr)
          [ Fichier : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\prefs.js ]
          Ligne Supprimée : user_pref("CT3128284.1000082.isDisplayHidden", "true");
          Ligne Supprimée : user_pref("CT3128284.1000082.isPlayDisplay", "true");
          Ligne Supprimée : user_pref("CT3128284.1000082.state", "{\"state\":\"stopped\",\"text\":\"RMC\",\"description\":\"RMC\",\"url\":\"hxxp://vipicecast.yacast.net/rmc\"}");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_TMP_city", "PARIS");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_TMP_country", "FR");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_locId", "FRXX0076");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_location", "Paris, France");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_region", "FR");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_temp_dis", "c");
          Ligne Supprimée : user_pref("CT3128284.1000234.TWC_wind_dis", "kmh");
          Ligne Supprimée : user_pref("CT3128284.1000234.weatherData", "{\"icon\":\"28.png\",\"temperature\":\"21°C\",\"temperatureClear\":\"21°C\",\"highTemperature\":\"25°C\",\"lowTemperature\":\"16°C\",\"feelsLike\":\"21Â[...]
          Ligne Supprimée : user_pref("CT3128284.3128284a129638404769606799000000paramsGK0", "{\"updateReqTime\":1347351999477,\"updateRespTime\":1347310832437,\"data\":{\"settings\":{\"icon\":\"hxxp://storage.conduit.com/bankim[...]
          Ligne Supprimée : user_pref("CT3128284.ENABALE_HISTORY", "{\"dataType\":\"string\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.ENABLE_RETURN_WEB_SEARCH_ON_THE_PAGE", "{\"dataType\":\"string\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.FirstTime", "true");
          Ligne Supprimée : user_pref("CT3128284.FirstTimeFF3", "true");
          Ligne Supprimée : user_pref("CT3128284.LoginRevertSettingsEnabled", true);
          Ligne Supprimée : user_pref("CT3128284.PG_ENABLE", "dHJ1ZQ==");
          Ligne Supprimée : user_pref("CT3128284.RSS_Pub_Config", "{\"settings\":{\"icon\":\"hxxp://storage.conduit.com/bankimages/iconsGallery/24/4669380633664526619.png\",\"componentId\":\"129638404769606799\",\"templateId\":\[...]
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000ReadItemsArr", "%7B%22572261%22%3A0%2C%22572161%22%3A0%2C%22572165%22%3A0%2C%22572119%22%3A0%2C%22572121%22%3A0%2C%22572079%22%3A0%2C%2257202[...]
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000cat0", "%5B%7B%22type%22%3A%22rss%22%2C%22version%22%3A%222.0%22%2C%22title%22%3A%2201net.%20Actualit%C3%A9s%20-%20Logiciel%22%2C%22link%22%3[...]
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000cat1", "%5B%7B%22type%22%3A%22rss%22%2C%22version%22%3A%222.0%22%2C%22title%22%3A%2201net.%20Actualit%C3%A9s%22%2C%22link%22%3A%22hxxp%3A%2F%[...]
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000embeddedVersion", "2.4.0");
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000feedsObj", "%7B%22channels%22%3A%7B%22id%22%3A%22channels%22%2C%22type%22%3A%22rss%22%2C%22data%22%3A%7B%22categories%22%3A%5B%7B%22title%22%[...]
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000lastReportTime", "1347310832478 ");
          Ligne Supprimée : user_pref("CT3128284.RSSapp3128284a129638404769606799000000newFeeds", "newFeeds");
          Ligne Supprimée : user_pref("CT3128284.RevertSettingsEnabled", true);
          Ligne Supprimée : user_pref("CT3128284.SF_JUST_INSTALLED.enc", "RkFMU0U=");
          Ligne Supprimée : user_pref("CT3128284.SF_STATUS.enc", "RU5BQkxFRA==");
          Ligne Supprimée : user_pref("CT3128284.SearchAppState.enc", "Mw==");
          Ligne Supprimée : user_pref("CT3128284.SearchAppTracking.enc", "c2VudA==");
          Ligne Supprimée : user_pref("CT3128284.SearchFromAddressBarUrl", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&q=");
          Ligne Supprimée : user_pref("CT3128284.UserID", "UN49774881496193684");
          Ligne Supprimée : user_pref("CT3128284.addressBarTakeOverEnabledInHidden", "true");
          Ligne Supprimée : user_pref("CT3128284.autoDisableScopes", -1);
          Ligne Supprimée : user_pref("CT3128284.browser.search.defaultthis.engineName", true);
          Ligne Supprimée : user_pref("CT3128284.countryCode", "FR");
          Ligne Supprimée : user_pref("CT3128284.defaultSearch", "true");
          Ligne Supprimée : user_pref("CT3128284.embeddedsData", "[{\"appId\":\"129638404645388048\",\"apiPermissions\":{\"crossDomainAjax\":true,\"getMainFrameTitle\":true,\"getMainFrameUrl\":true,\"getSearchTerm\":true,\"insta[...]
          Ligne Supprimée : user_pref("CT3128284.enableAlerts", "always");
          Ligne Supprimée : user_pref("CT3128284.enableFix404ByUser", "TRUE");
          Ligne Supprimée : user_pref("CT3128284.enableSearchFromAddressBar", "true");
          Ligne Supprimée : user_pref("CT3128284.firstTimeDialogOpened", "true");
          Ligne Supprimée : user_pref("CT3128284.fixPageNotFoundError", "true");
          Ligne Supprimée : user_pref("CT3128284.fixPageNotFoundErrorByUser", "true");
          Ligne Supprimée : user_pref("CT3128284.fixPageNotFoundErrorInHidden", "true");
          Ligne Supprimée : user_pref("CT3128284.fixUrls", true);
          Ligne Supprimée : user_pref("CT3128284.fullUserID", "UN49774881496193684.UP.20130729105549");
          Ligne Supprimée : user_pref("CT3128284.hxxp___storage_conduit_com_marketplace_83_6d_8399d181_be98_42f2_b035_1616f617316d_.PriceSparrowUuid.enc", "NDk0NEJEM0MtMjA3NC00OTZGLUIxRkQtQTQxRUYxNERFMDAw");
          Ligne Supprimée : user_pref("CT3128284.installId", "ct3128284_01net.com.exe");
          Ligne Supprimée : user_pref("CT3128284.installType", "ConduitNSISIntegration");
          Ligne Supprimée : user_pref("CT3128284.isCheckedStartAsHidden", true);
          Ligne Supprimée : user_pref("CT3128284.isEnableAllDialogs", "{\"dataType\":\"string\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.isFirstTimeToolbarLoading", "false");
          Ligne Supprimée : user_pref("CT3128284.isNewTabEnabled", true);
          Ligne Supprimée : user_pref("CT3128284.isPerformedSmartBarTransition", "true");
          Ligne Supprimée : user_pref("CT3128284.isToolbarShrinked", "{\"dataType\":\"string\",\"data\":\"false\"}");
          Ligne Supprimée : user_pref("CT3128284.keyword", true);
          Ligne Supprimée : user_pref("CT3128284.lastNewTabSettings", "{\"isEnabled\":true,\"newTabUrl\":\"hxxp://search.conduit.com/?ctid=CT3128284&octid=CT3128284&SearchSource=15&CUI=UN49774881496193684&SSPV=&Lay=1&UM=false\"}[...]
          Ligne Supprimée : user_pref("CT3128284.lastVersion", "10.16.70.505");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appStateReportTime", "%B7%B9%BE%BA%B6%B8%BB%B9%BE%BD%B6%BE%BD");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appStateReportTime.enc", "MTM4NDAyNTM4NzA4Nw==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appState_CouponBuddy.enc", "AA==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appState_PriceGong.enc", "b24=");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appsConfig.enc", "eyJBcHBzQ29uZmlndXJhdGlvbiI6W3siaWQiOiJDbGFyaXR5X0FjdGl2ZSIsInVybCI6Imh0dHA6Ly9zdG9yYWdlLmNvbmR1aXQuY29tL21hbS8zcmRwYXJ0eWFwcHMvY2xhcml0eVJheS9jcl9hY3Rpdm[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appsDefaultEnabled", "%F4%FB%F2%F2");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_appsDefaultEnabled.enc", "bnVsbA==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_calledSetupService.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_currentBadgeValue.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_currentVersion", "%B7%B4%B7%B7%B4%BA%B4%B8");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_currentVersion.enc", "MS4xMS40LjI=");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_existingUsersRecoveryDone.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_first_time", "%B7");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_first_time.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_gadgetOpen.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_globalKeysMigratedToLocalStorage", "%B7");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_globalKeysMigratedToLocalStorage.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_lastLoginTime", "%B7%B9%BE%BA%B6%B8%BB%B9%BE%BD%BA%BE%BF");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_lastLoginTime.enc", "MTM4NDAyNTM4NzQ4OQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_localization", "%u0101%A8%EA%F3%E8%F5%FE%B7%A8%C0%u0101%A8%DA%EB%FE%FA%A8%C0%A8%D6%F8%F5%F3%F5%E2%F4%EA%FB%A6%F0%F5%FB%F8%A8%u0103%B2%A8%EA%F3%E8%F5%FE%B8%A8%C0%u0101%A8%DA[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_localization.enc", "eyJkbWJveDEiOnsiVGV4dCI6IlByb21vXG5kdSBqb3VyIn0sImRtYm94MiI6eyJUZXh0IjoiTGl2cmFpc29uXG5ncmF0dWl0ZSJ9LCJkbWJ1bGxldDEiOnsiVGV4dCI6IkVjb25vbWlzZXogZGUgbOKA[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_newApps", "%E1%E3");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_newApps.enc", "W10=");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_pgUnloadedOnce.enc", "dHJ1ZQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.10.2.5.enc", "eyJTdGF0dXMiOiJzdWNjZWVkZWQiLCJEYXRhIjp7ImludGVydmFsIjoyNDAsInN0YW1wIjoiNDZfMCIsImlzVGVzdCI6dHJ1ZSwiVXNlckNvdW50cnlDb2RlIjoiRlIiLCJpc1dlbGNvbWVFeHBl[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.11.4.2", "%u0101%A8%D9%FA%E7%FA%FB%F9%A8%C0%A8%F9%FB%E9%E9%EB%EB%EA%EB%EA%A8%B2%A8%CA%E7%FA%E7%A8%C0%u0101%A8%E9%FB%F8%F8%EB%F4%FA%CA%E7%FA%EB%A8%C0%A8%B8%B6%B7%B[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.11.4.2.enc", "eyJTdGF0dXMiOiJzdWNjZWVkZWQiLCJEYXRhIjp7ImN1cnJlbnREYXRlIjoiMjAxMzExMDkiLCJpbnRlcnZhbCI6MjQwLCJzdGFtcCI6IjEwMzRfMCIsImlzVGVzdCI6dHJ1ZSwiVXNlckNvdW50[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.4.3.2.enc", "eyJTdGF0dXMiOiJzdWNjZWVkZWQiLCJEYXRhIjp7ImludGVydmFsIjoyNDAsInN0YW1wIjoiOTBfMCIsImlzVGVzdCI6dHJ1ZSwiaXNXZWxjb21lRXhwZXJpZW5jZUVuYWJsZWRCeURlZmF1bHQiO[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.8.0.4.enc", "eyJTdGF0dXMiOiJzdWNjZWVkZWQiLCJEYXRhIjp7ImludGVydmFsIjoyNDAsInN0YW1wIjoiNDZfMCIsImlzVGVzdCI6dHJ1ZSwiVXNlckNvdW50cnlDb2RlIjoiRlIiLCJpc1dlbGNvbWVFeHBlc[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_settings1.9.0.4.enc", "eyJTdGF0dXMiOiJzdWNjZWVkZWQiLCJEYXRhIjp7ImludGVydmFsIjoyNDAsInN0YW1wIjoiNDZfMCIsImlzVGVzdCI6dHJ1ZSwiVXNlckNvdW50cnlDb2RlIjoiRlIiLCJpc1dlbGNvbWVFeHBlc[...]
          Ligne Supprimée : user_pref("CT3128284.mam_gk_showCloseButton.enc", "dHJ1ZQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_showWelcomeGadget", "%EC%E7%F2%F9%EB");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_showWelcomeGadget.enc", "ZmFsc2U=");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_stamp", "%B7%B6%B9%BA%E5%B6");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_stamp.enc", "MTAzNF8w");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_userId", "%86");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_userId.enc", "AA==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_user_approval_interacted", "%B7");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_user_approval_interacted.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_user_apps_selection", "%86");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_user_apps_selection.enc", "AA==");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_welcomeDialogMode", "%B7");
          Ligne Supprimée : user_pref("CT3128284.mam_gk_welcomeDialogMode.enc", "MQ==");
          Ligne Supprimée : user_pref("CT3128284.migrateAppsAndComponents", true);
          Ligne Supprimée : user_pref("CT3128284.navigationAliasesJson", "{\"EB_SEARCH_TERM\":\"\",\"EB_MAIN_FRAME_URL\":\"\",\"EB_MAIN_FRAME_TITLE\":\"\",\"EB_TOOLBAR_SUB_DOMAIN\":\"hxxp://01NETcom.OurToolbar.com/\",\"EB_TOOLBA[...]
          Ligne Supprimée : user_pref("CT3128284.openThankYouPage", "false");
          Ligne Supprimée : user_pref("CT3128284.openUninstallPage", "true");
          Ligne Supprimée : user_pref("CT3128284.originalSearchAddressUrl", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&CUI=SB_CUI&q=");
          Ligne Supprimée : user_pref("CT3128284.price-gong.bornDate", "{\"dataType\":\"string\",\"data\":\"{\\\"Response\\\":\\\"03\\\\/23\\\\/2013 23\\\"}\"}");
          Ligne Supprimée : user_pref("CT3128284.price-gong.isManagedApp", "true");
          Ligne Supprimée : user_pref("CT3128284.search.searchAppId", "129638404645388048");
          Ligne Supprimée : user_pref("CT3128284.search.searchCount", "0");
          Ligne Supprimée : user_pref("CT3128284.searchInNewTabEnabledByUser", "true");
          Ligne Supprimée : user_pref("CT3128284.searchInNewTabEnabledInHidden", "true");
          Ligne Supprimée : user_pref("CT3128284.searchSuggestEnabledByUser", "true");
          Ligne Supprimée : user_pref("CT3128284.searchUserMode", "false");
          Ligne Supprimée : user_pref("CT3128284.selectToSearchBoxEnabled", "{\"dataType\":\"string\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_login_isFirstLoginInvoked", "{\"dataType\":\"boolean\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_login_loginCount", "{\"dataType\":\"number\",\"data\":\"4\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_toolbarGrouping_activeCTID", "{\"dataType\":\"string\",\"data\":\"CT3128284\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_toolbarGrouping_activeDownloadUrl", "{\"dataType\":\"string\",\"data\":\"hxxp://01NETcom.OurToolbar.com//xpi\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_toolbarGrouping_activeToolbarName", "{\"dataType\":\"string\",\"data\":\"01NET.com\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_toolbarGrouping_invoked", "{\"dataType\":\"string\",\"data\":\"true\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_service_usage_toolbarUsageCount", "{\"dataType\":\"number\",\"data\":\"2\"}");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_Configuration_lastUpdate", "1375098496144");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_appTrackingFirstTime_lastUpdate", "1375098498311");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_appTracking_lastUpdate", "1357322700285");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_appsMetadata_lastUpdate", "1375098499057");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_gottenAppsContextMenu_lastUpdate", "1375098498441");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_login_10.10.12.503_lastUpdate", "1345914245253");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_login_10.10.27.6_lastUpdate", "1355682554737");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_login_10.13.40.15_lastUpdate", "1373642541331");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_login_10.16.70.505_lastUpdate", "1375098498065");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_otherAppsContextMenu_lastUpdate", "1375098498731");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_searchAPI_lastUpdate", "1375098496448");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_serviceMap_lastUpdate", "1375098495948");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_toolbarContextMenu_lastUpdate", "1375098498622");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_toolbarSettings_lastUpdate", "1375098498878");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_translation_lastUpdate", "1375098501461");
          Ligne Supprimée : user_pref("CT3128284.serviceLayer_services_userApps_lastUpdate", "1373642425101");
          Ligne Supprimée : user_pref("CT3128284.settingsINI", true);
          Ligne Supprimée : user_pref("CT3128284.shouldFirstTimeDialog", "false");
          Ligne Supprimée : user_pref("CT3128284.showToolbarPermission", "false");
          Ligne Supprimée : user_pref("CT3128284.smartbar.CTID", "CT3128284");
          Ligne Supprimée : user_pref("CT3128284.smartbar.Uninstall", "0");
          Ligne Supprimée : user_pref("CT3128284.smartbar.homepage", true);
          Ligne Supprimée : user_pref("CT3128284.smartbar.toolbarName", "01NET.com ");
          Ligne Supprimée : user_pref("CT3128284.toolbarBornServerTime", "25-8-2012");
          Ligne Supprimée : user_pref("CT3128284.toolbarCurrentServerTime", "29-7-2013");
          Ligne Supprimée : user_pref("CT3128284.toolbarLoginClientTime", "Mon Jul 29 2013 10:55:58 GMT+0200");
          Ligne Supprimée : user_pref("CT3128284.twitter_v1.8.0_twitter_app_open_t_f", "false");
          Ligne Supprimée : user_pref("CT3128284.upgradeFromClearSBVersion", true);
          Ligne Supprimée : user_pref("CT3128284_Firefox.csv", "[{\"from\":\"Abs Layer\",\"action\":\"loading toolbar\",\"time\":1384025361448,\"isWithState\":\"\",\"timeFromStart\":0,\"timeFromPrev\":0}]");
          Ligne Supprimée : user_pref("Smartbar.ConduitHomepagesList", "hxxp://search.conduit.com/?ctid=CT3128284&SearchSource=13");
          Ligne Supprimée : user_pref("Smartbar.ConduitSearchEngineList", "01NET.com Customized Web Search");
          Ligne Supprimée : user_pref("Smartbar.ConduitSearchUrlList", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&q=");
          Ligne Supprimée : user_pref("Smartbar.SearchFromAddressBarSavedUrl", "hxxp://search.babylon.com/?babsrc=SP_ss&mntrId=925c1f4300000000000000225fa7bd3e&tlver=1.6.4.6&instlRef=sst&babTrack&q=");
          Ligne Supprimée : user_pref("Smartbar.keywordURLSelectedCTID", "CT3128284");
          Ligne Supprimée : user_pref("browser.newtab.url", "hxxp://search.babylon.com/?affID=111020&tt=010812_notb_3112_4&babsrc=NT_ss&mntrId=925c1f4300000000000000225fa7bd3e");
          Ligne Supprimée : user_pref("browser.search.order.1", "Search the web (Babylon)");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.admin", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.aflt", "babsst");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.autoRvrt", "false");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.babExt", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.babTrack", "affID=111020&tt=200812_67a_3412_3");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.babext", "babExt");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.babtrack", "babTrack");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.bbdpng", 26);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.cntry", "FR");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.dfltLng", "en");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.dfltlng", "en");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.dfltsrch", "false");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.envrmnt", "production");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.excTlbr", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.firstrun", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.hdrMd5", "210D34CDA903318FFD1D786FC9A0DA48");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.hmpg", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.hrdid", "925c1f4300000000000000225fa7bd3e");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.id", "925c1f4300000000000000225fa7bd3e");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.instlDay", "15575");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.instlRef", "sst");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.instlday", "15575");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.instlref", "sst");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.isdcmntcmplt", "false");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.keywordurl", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.lastVrsnTs", "1.6.4.621:50:03");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.lastdp", 26);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.mntrvrsn", "1.3.0");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.newTab", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.newtab", "false");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.newtaburl", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.prdct", "BabylonToolbar");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.prtnrId", "babylon");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.prtnrid", "babylon");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.savedVrsnTs", "1");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.sg", "azb");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.smplGrp", "azb");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.smplgrp", "none");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.srcExt", "ss");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.srcext", "ss");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.srch", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.srchprvdr", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.tlbrId", "base");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.tlbrSrchUrl", "hxxp://www.google.com/search?babsrc=TB_ggl&q=");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.tlbrid", "base");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.tlbrsrchurl", "hxxp://www.google.com/search?babsrc=TB_ggl&q=");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.vrsn", "1.6.4.6");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.vrsnTs", "1.6.4.621:50:03");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.vrsni", "1.6.4.6");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar.vrsnts", "1.6.4.621:50:03");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.babExt", "");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.babTrack", "affID=111020&tt=200812_67a_3412_3");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.newTab", false);
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.newTabUrl", "hxxp://search.babylon.com/?affID=111020&tt=010812_notb_3112_4&babsrc=NT_ss&mntrId=925c1f4300000000000000225fa7bd3e");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.smplGrp", "none");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.srcExt", "ss");
          Ligne Supprimée : user_pref("extensions.BabylonToolbar_i.vrsnTs", "1.6.4.621:50:03");
          Ligne Supprimée : user_pref("extensions.enabledAddons", "ffxtlbr%40babylon.com:1.5.0,%7B8e5025c2-8ea3-430d-80b8-a14151068a6d%7D:10.16.70.505,%7B972ce4c6-7e08-4474-a285-3208198ce6fd%7D:17.0.1");
          Ligne Supprimée : user_pref("keyword.URL", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&CUI=UN49774881496193684&UM=false&q=");
          Ligne Supprimée : user_pref("smartbar.addressBarOwnerCTID", "CT3128284");
          Ligne Supprimée : user_pref("smartbar.conduitSearchAddressUrlList", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&CUI=SB_CUI&q=,hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&Search[...]
          Ligne Supprimée : user_pref("smartbar.defaultSearchOwnerCTID", "CT3128284");
          Ligne Supprimée : user_pref("smartbar.machineId", "DQPQBXYPXQYMCVWIBYJCUIBT7ZP/TM9SH3A3G2QWDQ0SYWP5X/W2112SDVD7W4OBZQRY93J8SDCC3NMDOCIRBW");
          Ligne Supprimée : user_pref("smartbar.originalSearchAddressUrl", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT3128284&SearchSource=2&q=");
          Ligne Supprimée : user_pref("smartbar.originalSearchEngine", "01NET.com Customized Web Search");
          -\\ Google Chrome v32.0.1700.107
          [ Fichier : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\preferences ]
          AdwCleaner[R0].txt - [46475 octets] - [13/02/2014 21:09:19]
          AdwCleaner[S0].txt - [47217 octets] - [13/02/2014 21:29:02]
          ########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [47278 octets] ##########
          Deuxième rapport :
          # AdwCleaner v3.018 - Rapport créé le 13/02/2014 à 21:54:53
          # Option : Nettoyer
          [#] Service Supprimé : APNMCP
          [#] Service Supprimé : BackupStack
          Service Supprimé : SProtection
          Dossier Supprimé : C:\ProgramData\apn
          Dossier Supprimé : C:\ProgramData\Ask
          Dossier Supprimé : C:\ProgramData\Babylon
          Dossier Supprimé : C:\ProgramData\boost_interprocess
          Dossier Supprimé : C:\ProgramData\Iminent
          Dossier Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Iminent
          Dossier Supprimé : C:\Program Files\Conduit
          Dossier Supprimé : C:\Program Files\Iminent
          Dossier Supprimé : C:\Program Files\MyPC Backup
          Dossier Supprimé : C:\Program Files\Common Files\Umbrella
          Dossier Supprimé : C:\Users\pacckard\AppData\Local\comnetwork
          Dossier Supprimé : C:\Users\pacckard\AppData\Local\Conduit
          Dossier Supprimé : C:\Users\pacckard\AppData\Local\PackageAware
          Dossier Supprimé : C:\Users\pacckard\AppData\LocalLow\Conduit
          Dossier Supprimé : C:\Users\pacckard\AppData\LocalLow\searchquband
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Babylon
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\cacaoweb
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Iminent
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\IminentToolbar
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MyPC Backup
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Smartbar
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\CT3128284
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Extensions\{8e5025c2-8ea3-430d-80b8-a14151068a6d}
          Dossier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Extensions\***@***
          Dossier Supprimé : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          [!] Dossier Supprimé : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          Fichier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\Extensions\***@***
          Fichier Supprimé : C:\END
          Fichier Supprimé : C:\Users\pacckard\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\MyPC Backup.lnk
          Fichier Supprimé : C:\Users\pacckard\Desktop\cacaoweb.exe
          Fichier Supprimé : C:\Program Files\Mozilla Firefox\defaults\pref\all-iminent.js
          Fichier Supprimé : C:\Program Files\Mozilla Firefox\searchplugins\Babylon.xml
          Fichier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\searchplugins\iminent.xml
          Fichier Supprimé : C:\Program Files\Mozilla Firefox\searchplugins\StartWeb.xml
          Fichier Supprimé : C:\Users\pacckard\AppData\Roaming\Mozilla\Firefox\Profiles\i4mmp237.default\user.js
          Fichier Supprimé : C:\Users\pacckard\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_igdhbblpcellaljokkpfhcjlagemhgjl_0.localstorage
          Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
          Valeur Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [cacaoweb]
          Clé Supprimée : HKLM\SOFTWARE\Classes\AmiBs.Installer
          Clé Supprimée : HKLM\SOFTWARE\Classes\AmiBs.Installer.1
          Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\Iminent.WebBooster.InternetExplorer.DLL
          Clé Supprimée : HKLM\SOFTWARE\Classes\Applications\ilividsetupv1.exe
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.DownloadArgs
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.LinkToPromoteArgs
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.RawDataArgs
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.TinyUrlArgs
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Business.Tinyfying.ViralLinkArgs
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ClientCallback
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.ContractBase
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.AddToUserContentCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.CheckLoginStatusCommand
          Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent.Mediator.Communication.DataContracts.CleanCacheCommand
          AdwCleaner[R1].txt - [6514 octets] - [13/02/2014 21:38:17]
          AdwCleaner[R2].txt - [6464 octets] - [13/02/2014 21:52:58]
          AdwCleaner[S0].txt - [47359 octets] - [13/02/2014 21:29:02]
          AdwCleaner[S1].txt - [6008 octets] - [13/02/2014 21:54:53]
          ########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [6068 octets] ##########
          1. Merci pour ton aide juju
            voici le rapport:
            # AdwCleaner v2.202 - Rapport créé le 26/04/2013 à 15:59:08
            # Mis à jour le 23/04/2013 par Xplode
            # Système d'exploitation : Windows Vista (TM) Home Premium Service Pack 2 (32 bits)
            # Nom d'utilisateur : Dynali - DIDINA
            # Mode de démarrage : Normal
            # Exécuté depuis : C:\Users\Dynali\desktop\adwcleaner.exe
            # Option [Suppression]
            ***** [Services] *****
            Arrêté & Supprimé : BrowserProtect
            ***** [Fichiers / Dossiers] *****
            Dossier Supprimé : C:\Program Files\DomaIQ Uninstaller
            Dossier Supprimé : C:\Program Files\Fluendo
            Dossier Supprimé : C:\Program Files\Optimizer Pro
            Dossier Supprimé : C:\Program Files\Supreme Savings
            Dossier Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Optimizer Pro
            Dossier Supprimé : C:\Users\Dynali\AppData\Local\Google\Chrome\User Data\Default\Extensions\ihkeoookbpemkdccdccdmacnidhooohk
            Dossier Supprimé : C:\Users\Dynali\AppData\Local\moovida air
            Dossier Supprimé : C:\Users\Dynali\AppData\Local\Supreme Savings
            Dossier Supprimé : C:\Users\Dynali\AppData\Local\Updater19962
            Dossier Supprimé : C:\Users\Dynali\AppData\LocalLow\BabylonToolbar
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\Babylon
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\eType
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\BrowserProtect
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\moovida-1
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\extensions\crossriderapp19962@crossrider.com
            Dossier Supprimé : C:\Users\Dynali\AppData\Roaming\Optimizer Pro
            Fichier Supprimé : C:\Program Files\Mozilla Firefox\searchplugins\babylon.xml
            Fichier Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\eBay.lnk
            Fichier Supprimé : C:\Users\Dynali\AppData\Local\Google\Chrome\User Data\Default\bProtector Web Data
            Fichier Supprimé : C:\Users\Dynali\AppData\Local\Google\Chrome\User Data\Default\bprotectorpreferences
            Fichier Supprimé : C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\bProtector_extensions.rdf
            Fichier Supprimé : C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\bprotector_extensions.sqlite
            Fichier Supprimé : C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\bprotector_prefs.js
            Supprimé au redémarrage : C:\ProgramData\BrowserProtect
            ***** [Registre] *****
            Clé Supprimée : HKCU\Software\aed8d9b539b844
            Clé Supprimée : HKCU\Software\AppDataLow\Software\Crossrider
            Clé Supprimée : HKCU\Software\AppDataLow\Software\Supreme Savings
            Clé Supprimée : HKCU\Software\Cr_Installer
            Clé Supprimée : HKCU\Software\DataMngr_Toolbar
            Clé Supprimée : HKCU\Software\DSNR Labs
            Clé Supprimée : HKCU\Software\InstallCore
            Clé Supprimée : HKCU\Software\InstalledBrowserExtensions
            Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{171DEBEB-C3D4-40B7-AC73-056A5EBA4A7E}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{15D2D75C-9CB2-4EFD-BAD7-B9B4CB4BC693}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Supreme Savings
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\bProtectSettings
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{BA14329E-9550-4989-B3F2-9732E92D17CC}
            Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
            Clé Supprimée : HKCU\Software\Optimizer Pro
            Clé Supprimée : HKCU\Software\Softonic
            Clé Supprimée : HKCU\Toolbar
            Clé Supprimée : HKLM\SOFTWARE\aed8d9b539b844
            Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{C26644C4-2A12-4CA6-8F2E-0EDE6CF018F3}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{11111111-1111-1111-1111-110111991162}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{761F6A83-F007-49E4-8EAC-CDB6808EF06F}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{76C45B18-A29E-43EA-AAF8-AF55C2E1AE17}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{96EF404C-24C7-43D0-9096-4CCC8BB7CCAC}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{97720195-206A-42AE-8E65-260B9BA5589F}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{97D69524-BB57-4185-9C7F-5F05593B771A}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{986F7A5A-9676-47E1-8642-F41F8C3FCF82}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{9AFB8248-617F-460D-9366-D71CDEDA3179}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{B18788A4-92BD-440E-A4D1-380C36531119}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
            Clé Supprimée : HKLM\SOFTWARE\Classes\CrossriderApp0019962.BHO
            Clé Supprimée : HKLM\SOFTWARE\Classes\CrossriderApp0019962.BHO.1
            Clé Supprimée : HKLM\SOFTWARE\Classes\CrossriderApp0019962.Sandbox
            Clé Supprimée : HKLM\SOFTWARE\Classes\CrossriderApp0019962.Sandbox.1
            Clé Supprimée : HKLM\SOFTWARE\Classes\S
            Clé Supprimée : HKLM\Software\DataMngr
            Clé Supprimée : HKLM\Software\DomaIQ
            Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\dhkplhfnhceodhffomolpfigojocbpcb
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{11111111-1111-1111-1111-110111991162}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{21111111-1111-1111-1111-110111991162}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{11111111-1111-1111-1111-110111991162}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110111991162}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1602F07D-8BF3-4C08-BDD6-DDDB1C48AEDC}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{AC6D819E-AA8F-4418-A3BB-D165C1B18BB5}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
            Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\063A857434EDED11A893800002C0A966
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{15D2D75C-9CB2-4EFD-BAD7-B9B4CB4BC693}
            Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Supreme Savings
            Clé Supprimée : HKLM\Software\Supreme Savings
            Clé Supprimée : HKU\S-1-5-21-601728263-2293456949-254054262-1000\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
            Donnée Supprimée : HKLM\..\Windows [AppInit_DLLs] = c:\progra~2\browse~1\261249~1.132\{c16c1~1\browse~1.dll
            Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Main [bprotector start page]
            Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes [bProtectorDefaultScope]
            Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{BA14329E-9550-4989-B3F2-9732E92D17CC}]
            Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{BA14329E-9550-4989-B3F2-9732E92D17CC}]
            Valeur Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [Optimizer Pro]
            Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{98889811-442D-49DD-99D7-DC866BE87DBC}]
            Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
            ***** [Navigateurs] *****
            -\\ Internet Explorer v9.0.8112.16476
            Remplacé : [HKCU\Software\Microsoft\Internet Explorer\Main - Start Page] = hxxp://www2.delta-search.com/?affID=120519&babsrc=HP_ss&mntrId=A860001CBF76D024 --> hxxp://www.google.com
            -\\ Mozilla Firefox v20.0 (fr)
            Fichier : C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\prefs.js
            C:\Users\Dynali\AppData\Roaming\Mozilla\Firefox\Profiles\45or1uvh.default\user.js ... Supprimé !
            Supprimée : user_pref("extensions.BabylonToolbar.appId", "{BDB69379-802F-4eaf-B541-F8DE92DD98DB}");
            Supprimée : user_pref("extensions.BabylonToolbar.bbDpng", 23);
            Supprimée : user_pref("extensions.BabylonToolbar.ffxUnstlRst", true);
            Supprimée : user_pref("extensions.BabylonToolbar.firstRun", false);
            Supprimée : user_pref("extensions.BabylonToolbar.hdrMd5", "6E8ACF2980AAF604166499590CC6BC97");
            Supprimée : user_pref("extensions.BabylonToolbar.id", "a86015d5000000000000001cbf76d024");
            Supprimée : user_pref("extensions.BabylonToolbar.instlDay", "15820");
            Supprimée : user_pref("extensions.BabylonToolbar.lastActv", "23");
            Supprimée : user_pref("extensions.BabylonToolbar.lastDP", 23);
            Supprimée : user_pref("extensions.BabylonToolbar.rvrt", "false");
            Supprimée : user_pref("extensions.BabylonToolbar.smplGrp", "none");
            Supprimée : user_pref("extensions.BabylonToolbar.tlbrSrchUrl", "hxxp://search.babylon.com/?babsrc=TB_def&mntrId=[...]
            Supprimée : user_pref("extensions.BabylonToolbar.vrsn", "1.8.11.10");
            Supprimée : user_pref("extensions.BabylonToolbar.vrsni", "1.8.11.10");
            Supprimée : user_pref("extensions.BabylonToolbar.vrsnTs", "1.8.11.1021:38:01");
            Supprimée : user_pref("extensions.BabylonToolbar_i.babTrack", "affID=120519");
            -\\ Google Chrome v26.0.1410.64
            Fichier : C:\Users\Dynali\AppData\Local\Google\Chrome\User Data\Default\Preferences
            [OK] Le fichier ne contient aucune entrée illégitime.
            AdwCleaner[R1].txt - [11663 octets] - [26/04/2013 15:58:31]
            AdwCleaner[S1].txt - [11244 octets] - [26/04/2013 15:59:08]
            ########## EOF - C:\AdwCleaner[S1].txt - [11305 octets] ##########
            1. Contributeur sécurité
              Il se désinstalle comme tout programme classique.
              ● Pour Windows Vista/Seven : Allez dans le Panneau de Configuration puis Programmes et Fonctionnalités
              ● Pour Windows XP : Allez dans le Panneau de Configuration puis Ajout/Suppression de programmes
              ▶ Chercher et désinstaller : Optimizer pro
              ▶ Désinstalle aussi toutes les barres d'outils / Toolbar tant que tu y es...
              ● A savoir qu'il est proposé à l'installation de programmes, donc y a des chances que tu aies installés d'autres trucs, fais ça :
              ▶ Télécharge AdwCleaner ( d'Xplode ) sur ton bureau.
              ▶ Lance le, clique sur [Suppression] puis patiente le temps du scan.
              ▶ Une fois le scan fini, un rapport s'ouvrira. Poste moi son contenu dans ta prochaine réponse.
              Note : Le rapport est également sauvegardé sous C:\AdwCleaner[S1].txt
