Probléme sur minecraft
Bonjour, cela fait 1 ans que j'ai acheté minecraft et depuis que j'ai passé mon ordinateur portable sous windows 8 proffesionel mon minecaft ne marche plus et m'affiche ce message :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 15/12/12 11:30
-- System Details --
Details:
Minecraft Version: 1.4.5
Operating System: Windows 8 (x86) version 6.2
Java Version: 1.7.0_09, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 422127288 bytes (402 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 1d19b3c1 ----------
  1. C'est peut être minecraft lui même qui n'est pas encore configuré sous windows 8
    1. http://www.ma-config.com/fr/services/60_trouver-les-pilotes.html
      demarrer la detection , mes pilotes et tu fait les mises a jour "carte graphiques "
      nessésaires
      pour plus de FPS en jeu tu peut aussi faire d'autres mises a jour ^^
      il faut installer un plug-inmais ca te servira surement pour d'autres problemes
