Problème a minecraft
quand je lance minecraft se message apparait ??que dois-je faire ?
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 09/07/11 10:55
Minecraft: Minecraft Beta 1.7.3
OS: Windows XP (x86) version 5.1
Java: 1.6.0_26, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:294)
at net.minecraft.client.Minecraft.run(SourceFile:716)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 2f7e0029 ----------
MERCI !!
LWJGL: 2.4.2
MERCI !!
en gros, je pense que tu dois faire une mise a jour de ta carte graphique ! va sur ce site : https://www.touslesdrivers.com/ , clique en haut sur "mes drivers", descends et "lancer la detection". tu choisis ton systeme d'exploitation, tu installe le plug-in et lancer la detection et puis apres tu suis les instructions ! ^^
