[DEBIAN][DUAL-HEAD] Position des écrans
je suis entrain de configurer mon bureau sur 2 écrans. Lorsqu'ils sont gérés indépendemment, je n'ai pas de soucis je sort de celui de gauche par la droite et inversement. Par contre, dans le cas du burea étendu, impossible d'arriver au même résultat!!!
Quelqu'un peut il m'aider SVP???
je vous mais mon XF86Config-4:
encore merci de votre aide!
# XF86Config-4 (XFree86 X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the XF86Config-4 manual page. # (Type "man XF86Config-4" at the shell prompt.) # # This file is automatically updated on xserver-xfree86 package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xfree86 # package. # # If you have edited this file but would like it to be automatically updated # again, run the following commands as root: # # cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom # md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum # dpkg-reconfigure xserver-xfree86 Section "ServerLayout" Identifier "Default Layout" Screen 0 "aticonfig Screen 0" 0 0 InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "Files" # local font server # if the local font server has problems, we can fall back on these FontPath "unix/:7100" FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/Speedo" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" EndSection Section "Module" Load "GLcore" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "speedo" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xfree86" Option "XkbModel" "pc105" Option "XkbLayout" "fr" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Monitor" Identifier "aticonfig Monitor 0" EndSection Section "Monitor" Identifier "aticonfig Monitor 1" EndSection Section "Device" Identifier "ATI Graphics Adapter 0" Driver "fglrx" Option "(null)" Option "DesktopSetup" "horizontal" Option "OverlayOnCRTC2" "0" BusID "PCI:1:0:0" EndSection Section "Device" Identifier "ATI Graphics Adapter 1" Driver "fglrx" BusID "PCI:1:0:0" Screen 1 EndSection Section "Screen" Identifier "aticonfig Screen 0" Device "ATI Graphics Adapter 0" Monitor "aticonfig Monitor 0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Section "Screen" Identifier "aticonfig Screen 1" Device "ATI Graphics Adapter 1" Monitor "aticonfig Monitor 1" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Section "DRI" Mode 0666 EndSection
Les positions des moniteurs se gèrent dans le fichier xorg.conf (ou XFree86 ..)
de mémoire, c'est à la déclaration des moniteurs ou des screens qu'on rajoute le mot-clef "RightOf"
en cherchant sur google "xorg.conf screen rightof" tu devrais trouver ton bonheur ;) -
ModérateurA priori tu peux gérer ça directement dans les paramètre d'affichage de ton window manager (kde...), non ? Sinon pour les cartes nvidia il y a également possibilité de passer par l'assistant livré avec les drivers propriétaires (clic droit sur le bureau etc...)
Bonne chance
