Reponse a regis59 (probleme connection MSN)
après ton message, j'ai installer hijackthis, et voici ci-dessous la copie du rapport comme tu me l'a demandé.
maintenant que dois je faire.
je te remercie par avance et attend tes instructions (moi je nage complètement).
a+
Logfile of HijackThis v1.99.1
Scan saved at 13:57:00, on 07/10/2005
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
C:\WINDOWS\System32\rundll32.exe
C:\PROGRA~1\Agnitum\OUTPOS~1\outpost.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\Program Files\a2\a2guard.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
C:\Program Files\Outlook Express\msimn.exe
C:\hijackthis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.fr/
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.123mania.com/040C/ie.asp
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R3 - URLSearchHook: SrchHook Class - {15651C7C-E812-44a2-A9AC-B467A2233E7D} - C:\WINDOWS\System32\GIDCAI32.dll (file missing)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: BHOsrc Class - {622CC208-B014-4FE0-801B-874A5E5E403A} - C:\WINDOWS\System32\GIDCAI32.dll (file missing)
O2 - BHO: HTML Class - {9C5B2F29-1F46-4639-A6B4-828942301D3E} - C:\WINDOWS\System32\SIPSPI32.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [KAVPersonal50] "C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus Personal\kav.exe" /minimize
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\HP\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
O4 - HKLM\..\Run: [LoadSIPS] rundll32.exe C:\WINDOWS\System32\SIPSPI32.dll,SIPSPI32
O4 - HKLM\..\Run: [Outpost Firewall] C:\PROGRA~1\Agnitum\OUTPOS~1\outpost.exe /waitservice
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe"
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [a-squared] "C:\Program Files\a2\a2guard.exe"
O4 - Startup: desktop(2).ini
O4 - Global Startup: desktop(2).ini
O4 - Global Startup: Démarrage rapide du logiciel HP Image Zone.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: Lancement rapide d'Adobe Reader(2).lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Lancement rapide d'Adobe Reader.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Browser Adjust - {44627E97-789B-40d4-B5C2-58BD171129A1} - C:\Program Files\Agnitum\Outpost Firewall\Plugins\BrowserBar\ie_bar.dll
O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O16 - DPF: {15651C7C-E812-44A2-A9AC-B467A2233E7D} (SrchHook Class) -
O16 - DPF: {9C5B2F29-1F46-4639-A6B4-828942301D3E} (HTML Class) -
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O20 - AppInit_DLLs: C:\PROGRA~1\Agnitum\OUTPOS~1\wl_hook.dll
O23 - Service: kavsvc - Kaspersky Lab - C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus Personal\kavsvc.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe
34 réponses
Suite à l'installation de HijackThis et à la copie du rapport, une demande d'instructions décrit des symptômes liés à des extensions malveillantes et des difficultés d'accès à certains sites et MSN. Plusieurs intervenants proposent des solutions, dont restaurer l'accès sécurisé via des conseils externes, réparer MSN Messenger 7.5 en réenregistrant des DLL clés et supprimer des éléments indésirables. D'autres contributions évoquent des vérifications liées à des messages d'erreur DNS ou ActiveX, des contrôles de modules et l'usage d'outils comme JV16 pour nettoyer les éléments détectés et désactiver les démarrages problématiques. En complément, une suggestion vise à recacher les fichiers caches et réactiver la restauration système pour éviter une récidive et préserver les points de restauration après le nettoyage.
Ravie pour toi Véro, si tu as un blème pour msn va voir dans mon profil
Bises à toi-
salut marie
je vous passe à tout les 3 (regis59, moe et toi bien sur) 1 petite info
me promenant sur le forum divers, j'ai trouvé la solution pour MSN MESSENGER 7.5, voici
voir ceci : www.techniland.com/fagmessenger.php3
et faire ces manip
si pbm de démarrage MSN faire ceci
Démarrer/exécuter puis là taper les 3 lignes l’une après l’autre suivies de Enter
regsvr32 softpub.dll
regsvr32 initpki.dll
regsvr32 mssip32.dll
ensuite ça doit remarcher, relancer l’ordi vous devez pouvoir vous reconnecter
INFO DE BERNIE61
et ça marche, j'ai retrouvé MSN 7.5
encore merci à tous
bises
salut vero
je suis content pour toi aussi en tout cas ^^
Moe est un as en la matiere
bonne continuation vero, pense si tu ne l as pas encore fait a recacher les fichiers caches et reactiver ta restauration systeme
bises -
salut vero
Content que tout remarche à nouveau ;-)
Je crois qu'on en apprend, nous aussi, tous les jours, personne n'a la science infuse lol et c'est ce qui est interressant (pour moi en tout cas).
Et surtout un grand merci à google, lol
bises
a+ -
re
est ce que kerio autorise msn à aller sur le net ?
tu as un tuto pour configurer kerio ici:
http://www.vulgarisation-informatique.com/kerio.php
tu dois pouvoir le verifier dans securité reseaux > applications
a+-
salut moe31
merci pour ton info sur kério, mais sur ce site je suis allée dans tutoriaux et sur tutotiaux internet explorer, et là j'ai suivi les instructions de configuration.
ensuite j'ai téléchargée MSN 6, et je me suis connecté et ça maaaaaaarche, je suis folle de joie!!!!!!!!!!!!!
je voulais tous vous remercier, régis59, toi, marie, vous êtes d'abord hyper sympa car, nous les débutants, nous sommes un peu chi***t et on ne comprend pas tjrs ce que vous expliquez, pourtant c'est très détaillé, mais vous avez la patience des anges et de plus vous êtes pleins de ressources.
soyez assurez de ma gratitude, tien pour la peine je vous embrasse(sur les 4 joues hi, hi)
j'espère ne pas revenir vous solliciter, mais on ne sait jamais.......
enfin maintenant j'ai plein de logiciels pour me protéger.
alors bonne nuit à tous
et encore merciiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
salut vero
content pour toi ;-)
Pour msn, est ce que ton firewall autorise l'acces au net pour msn ?
est ce que tu as autoriser windows à memoriser tes identifiants (mot de passe et pseudo) pour ne pas avoir à les retaper ou est ce que tu les tapes à chaque fois ?
a+-
re moe
j'ai kério (installer sur la demande de régis59) mais j'ai aussi kasperski depuis le départ et ça marchait
de plus, je tapes tjrs mon adresse et mon mot de passe, rien n'est mémorisé
j'ai désinstallée MSN MESSENGER dans ajout/suppr
je voudrai télécharger la version 6, mais dans le bureau de mon ordi j'ai encore l'extracteur de MSN MESSENGER mais quand je clic sur les proriétés, il s'avère que c'est la version 6.0 et quand je lui demande de l'installer, il met installation de MSN MESSENGER 7.5??????? c'est normal ou quoi?
salut
Pour l'acces aux sites securisés, jete un oeil ici:
http://www.pcastuces.com/newsletter/adj/1199.htm
a+ -
re,
a partir d ajout/supp de programme , supprime ces 2 logiciels ce sont des rogues:
-BPS SPYWARE
- spywareblaster
Ensuite telecharge ce nettoyeur de registre, supprime les ronds verts comme indiqué et aussi ce dont tu ne te sers plus et que tu as desinstaller eventuellement
jv16
(ancienne version gratuite) http://www.puntocr.it/index.php?module=downloads_riz&func=display&pid=3&lid=26
là tu le lances tu cliques sur outil registre/outil/nettoyage de registre/continuer /démarrer
là tu le laisses faire c’est un peu long
quand il a fini
tu sélectionnes les ronds verts par paquet de 20 ou 30
une fois que tu les a sélectionnés tu cliques sur supprimer en bas à droite
et tu continues jusqu’à ce qu’il ne reste plus de ronds verts
Pour msn:
tu n as pas de connection, as tu un message d erreur?
Pour les sites securisé, que ce passe, t il, un message?
a+-
salut régis59
j'ai supprimé les 2 rogues (qu'est ce que c'est?) et j'ai nettoyé les registres avec jv16, et il n'y a plus de point vert, que du rouge.
Pour msn:
R : MSN EXPLORER : connexion impossible, un message empèche peut être le bon fonctionnement de notre serveur ou a l'établissement de votre connexion internet
réessayé plus tard
MSN MESSENGER : au depart il me demande mon adresse msn, mais quand je la tape elle met au moins 20 secondes avant de s'afficher, ensuite j'ai le message suivant -
la connexion MSN MESSENGER a échouée, car le serveur est temporairement inaccessible
réessayée plus tard
R : impossible afficher la page, plus toute les info pour essayer de l'afficher, mais j'ai tout vérifiée et apparement tout est ok (parametres par défaut), et en bas de la page il y a : impossible trouver serveur ou erreur DNS dans internet explorer.
avant j'avais un message avec le mot activeX dedans, mais je me rappelle plus quoi
merci encore de ta gentillesse, au fait peux tu me dire ce que veut dire( lol)
excuse mon ignarité
A+ -
re régis59,
j'ai retrouvé la phrase que l'on me mettais avant quand je voulais rentrer dans les site sécurisés, la voilà
les paramètres de sécurité actuels ne vous permettent pas l'ésécuter les controles activex de cette page, en conséquence cette page ne sera peut être pas affichée correctement
merci -
Bonsoir Véro,
As-tu essayer MSN par là :
http://webmessenger.msn.com/default.aspx?R=1
Essaies de lire ceci :
http://www.commentcamarche.net/forum/affich-1806167
Peut-être un problème de proxy
http://www.commentcamarche.net/forum/affich-1841117
Tu as toujours la possibilité de créer une nouvelle adresse, mais lis ceci avant :
http://www-chimie.u-strasbg.fr/~GB/Bon_MdP.html
Sachant que la version 7.5 a toujours des problèmes.
Ensuite quand tu télécharge MSN, FAUT DECOCHER les 4 cases.
Et ne pas prendre MSN+
J'ai essayé de faire au mieux pour ton MSN
Bizz
A+
@^^Marie^^salut marie
j'ai essayée ce que tu viens de m'écrire, négatif rien ne marche,
je pensais désinstaller MSN 7.5 et essayé de télécharger la version6
quand penses tu? ou bien j'attends la réponse de régis59
merci encore de ta gentillesse -
bonne nuit regis, je vais pas tarder à suivre..
a++ -
Bonne nuit olivier.....
bisous vero...
douce nuit a vs 2...
et bon courage aux forumers...
a domani ! -
Celui la mon ami Olivier lol
http://www.commentcamarche.net/forum/affich-1840635-%5BPokapoka%5D-et-autres-probl%E8mes#2005-10-10%2021%3A54%3A27
lol t as vraiment l air d un c.. looooooooooool -
lol, je vais avoir l'air d'un c.. mais tu parle de quel post ?
merci moe pr l autre poste.... -
lol, pas grave ;-)
a+ -
salut vero
ouf ! enfin supprimer...
ou en sont tes soucis ??
ps:dsl moe pour ta manip-
bonne nuit à toi aussi régis59
pour demain, voici mes autres soucis.
1/ tjrs pas de connection à MSN
2/ tjrs pas de connection sur site sécurisé (bnp, assedic etc...)
d'autre part, avec tout les logiciels que tu m'as fait télécharger, il n'y a pas de problème de comptabilité?
- adaware
- a2
- spybot
- j'avais déjà BPS SPYWARE et kasperski
- spywareblaster
- kério, je n'ai pas pu le désinstaller(ajout/suppression prog)
- mozilla fire fox
- silent runner
- chaos shredder
- a-squared
- outpost firewall pro
aux quels cas lesquels dois je supprimer?
A demain
salut
j'ai vu le log hijackthis, mais je te posais cette question car apres avoir fais une restau systeme, j'ai eu un "prob" similaire.
j'avais un prog que j'ai du reinstaller, et dans programmfile il y avait deux dossier pour le meme programme dont un avec (2) à la fin du nom.
je me demandais juste s'il ni avait pas eut le meme probleme avec tes fichiers.
dommage que tu n'ai pas pu copier/coller ici leur contenu...
a++ -
pas grave regis, juste pour savoir si elle à fait une restau systeme recemment.
a++ -
Véro, ce n'est pas la peine d'écrire plusieurs messages destinés à régis59 puisque tu as un post en cours avec lui... http://www.commentcamarche.net/forum/affich-1845316-site-s%E9curis%E9s-%E0-r%E9gis-59
Donc reste sur le même post pour qu'il puisse suivre.
Merci et Bonne soirée,
M. -
fais ce ke moe te demande ici alors
C:\Documents and Settings\Véronique\Menu Démarrer\Programmes\Démarrage
a+-
régis59
comme je l'ai dit à moe31 j'avais déjà supprimé dans allusers, mais dans véronique il y en avait 2 (les mêmes) alors je les ais supprimé, voici le hijacksthis
Scan saved at 20:57:34, on 10/10/2005
Running processes:
C:\WINDOWS\system32\cisvc.exe
O23 - Service: Kerio Personal Firewall 4 (KPF4) - Kerio Technologies - C:\Program Files\Kerio\Personal Firewall 4\kpf4ss.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe -
atend
- 1
- 2
