Problème avec flash player 7
bonjour,
J'ai installé flash player 7 et ensuite j'ai voulu visualiser des cartes virtuelles de ce site : http://carte.dromadaire.com/fr/
Malheureusement, je n'arrive pas à visualiser les animations (image et son).
J'ai ensuite desinstallé mozilla et supprimé le repertoire ".mozilla "avec son repertoire "plugin" qui contient les fichiers suivant :
-rwxr-xr-x 1 pristella pristella 856 sep 10 19:17 flashplayer.xpt*
-rwxr-xr-x 1 pristella pristella 2096844 sep 10 19:17 libflashplayer.so*
J'ai redemarré mandriva puis j'ai reinstallé mozilla et flash player .
Voilà le resultat de l'installation :
[pristella@lns-vlq-21-nan-82-255-76-34 install_flash_player_7_linux]$ ./flashplayer-installer
Copyright(C) 2002-2003 Macromedia, Inc. All rights reserved.
Macromedia Flash Player 7 for Linux
Macromedia Flash Player 7 will be installed on this machine.
You are running the Macromedia Flash Player installer as a non-root user.
Macromedia Flash Player 7 will be installed in your home directory.
Support is available at http://www.macromedia.com/support/flashplayer/
To install Macromedia Flash Player 7 now, press ENTER.
To cancel the installation at any time, press Control-C.
NOTE: Macromedia Flash Player requires two font packages
to be installed, ttfonts and urw-fonts.
Press ENTER to continue...
NOTE: Please exit any browsers you may have running.
----------- Install Action Summary -----------
Macromedia Flash Player 7 will be installed in the following directory:
Mozilla installation directory = /home/pristella/.mozilla
Proceed with the installation? (y/n/q): y
NOTE: Please ask your administrator to remove the xpti.dat from the
components directory of the Mozilla or Netscape browser.
Installation complete.
Perform another installation? (y/n): n
WARNING: You have the MOZ_PLUGIN_PATH environment variable set.
Either unset this environment variable or set the path in this
environment variable to the path you are installing the plug-in.
Please log out of this session and log in for the changes to take effect.
The Macromedia Flash Player installation is complete.
Il y a 2 choses que je ne comprend, l'histoire du fichier xpti.dat et celle du WARNING:
you have the MOZ_PLUGIN_PATH environment variable set.
A l'issue je suis retourné sur le site des cartes virtuelles pour en visualiser une et là ça marche (image et son).
Mais lorsque je redemarre mandriva ou que je quitte la session et que je retourne sur le site des cartes virtuelles, je ne peux plus les visualiser (image noir ou apparente mais sans animations et sans son).
Pourriez-vous m'aider à comprendre ce problème.
merci d'avance
merci d'avance
15 réponses
Je vois que tu as une histoire de gplflash, serais-ce possible que ce soit celà qui perturbe ta naviguation?
gplflash c'est flash libre
http://gplflash.sourceforge.net/
Faudrait voir de ce côté là.
Car tu as deux choses qui font exactement pareil...limite
Contributeurvi, voilà un extrait :
Generated File. Do not edit.
[HEADER]
Version:0.08:$
[PLUGINS]
/usr/lib/mozilla/plugins/libnpflash.so:$
1107081453000:1:5:$
Flash Movie player Version 0.4.13 compatible with Shockwave Flash 4.0 <P>Shockwave is a trademark of <A HREF="https://www.adobe.com/">Macromedia®</A
><P>GPLFLash homepage : <A HREF="http://gplflash.sourceforge.net/">gplflash.sf.net</A>:$
Shockwave Flash:$
2
0:application/x-shockwave-flash:Flash Plugin:swf:$
1:application/x-futuresplash:Future Splash:spl:$
/usr/lib/mozilla/plugins/opensc-signer.so:$
1107789670000:1:5:$
This plugins handles web signatures using OpenSC smartcard library.:$
OpenSC Signer plugin:$
0:text/x-text-to-sign:Text to be signed:sgn:$
/usr/lib/mozilla/plugins/kaffeineplugin.so:$
1108588853000:1:5:$
Will start external Kaffeine Media Player for embedded media streams.:$
Kaffeine Starter Plugin:$
20
0:video/mpeg: MPEG animation: mpeg, mpg, mpe:$
1:video/x-mpeg: MPEG animation: mpeg, mpg, mpe:$
2:audio/mpeg2: MPEG audio: mp2:$
3:audio/x-mpeg2: MPEG audio: mp2:$
4:audio/mpeg3: MPEG audio: mp3:$
5:audio/x-mpeg3: MPEG audio: mp3:$
6:audio/mpeg: MPEG audio: mpa,abs,mpega:$
7:audio/x-mpeg: MPEG audio: mpa,abs,mpega:$
8:video/quicktime: Quicktime animation: mov,qt:$
9:video/x-quicktime: Quicktime animation: mov,qt:$
10:video/msvideo: AVI animation: avi:$
11:video/x-msvideo: AVI animation: avi:$
12:application/x-mplayer2: mplayer2: asf,asx,asp:$
13:video/x-ms-asf-plugin: mms animation: asf,asx,asp:$
14:audio/x-pn-realaudio-plugin: Real audio: rpm:$
15:audio/x-ogg: OGG Media: ogg,ogm:$
16:audio/x-scpls: MPEG audio: pls:$
17:audio/x-ms-wma: Microsoft Media Audio: wma:$
18:video/x-ms-wmv: Microsoft Media Video: wmv:$
19:audio/x-mpegurl: Streaming-MPEG-Audio: m3u:$
/usr/lib/mozilla/plugins/nphelix.so:$
Salut
Quand tu fais ta manipulation est-ce que tu laisses les deux naviguateurs ouverts?
Si c'est oui, alors c'est normal, un son par plate-forme...
Si c'est non, je me fais curé...
8)
limite
Contributeurben non, je ne laisse pas les 2 ouvert. Mais ça marche quand même, à part qu'il faut ouvrir à 2 reprises les navigateurs.
Peut-être que lors de la 1ère ouverture avec mozilla-1.7.6, le plugin ne se charge pas instantanement ?? mais pour que cela fonctionne, je dois impérativement ouvrir en second firefox, le fermer puis à nouveau ouvrir mozilla-1.7.6. Si j'ouvre 2 fois de suite mozilla-1.7.6, ça ne marche pas ??
:o -
Là j'y comprends plus rien...
Dans ton fichier /home/goldorak/.mozilla/firefox/pluginreg.dat
tu dois avoir quelque chose ainsi::
Generated File. Do not edit. [HEADER] Version:0.08:$ [PLUGINS] /opt/firefox-installer/plugins/libflashplayer.so:$ :$ 1085088844000:1:1:$ Shockwave Flash 7.0 r25:$ Shockwave Flash:$ 2 0:application/x-shockwave-flash:Shockwave Flash:swf:$ 1:application/futuresplash:FutureSplash Player:spl:$ /opt/jdk1.5.0_04/jre/plugin/i386/ns7/libjavaplugin_oji.so:$ :$ 1117799554000:1:5:$ Java(TM) Plug-in 1.5.0_04:$ Java(TM) Plug-in 1.5.0_04-b05:$ 31 0:application/x-java-vm:Java::$ 1:application/x-java-applet:Java::$ 2:application/x-java-applet;version=1.1:Java::$ 3:application/x-java-applet;version=1.1.1:Java::$ 4:application/x-java-applet;version=1.1.2:Java::$ 5:application/x-java-applet;version=1.1.3:Java::$ 6:application/x-java-applet;version=1.2:Java::$ 7:application/x-java-applet;version=1.2.1:Java::$ 8:application/x-java-applet;version=1.2.2:Java::$ 9:application/x-java-applet;version=1.3:Java::$ 10:application/x-java-applet;version=1.3.1:Java::$ 11:application/x-java-applet;version=1.4:Java::$ 12:application/x-java-applet;version=1.4.1:Java::$ 13:application/x-java-applet;version=1.4.2:Java::$ 14:application/x-java-applet;version=1.5:Java::$ 15:application/x-java-applet;jpi-version=1.5.0_04:Java::$ 16:application/x-java-bean:Java::$ 17:application/x-java-bean;version=1.1:Java::$ 18:application/x-java-bean;version=1.1.1:Java::$ 19:application/x-java-bean;version=1.1.2:Java::$ 20:application/x-java-bean;version=1.1.3:Java::$ 21:application/x-java-bean;version=1.2:Java::$ 22:application/x-java-bean;version=1.2.1:Java::$ 23:application/x-java-bean;version=1.2.2:Java::$ 24:application/x-java-bean;version=1.3:Java::$ 25:application/x-java-bean;version=1.3.1:Java::$ 26:application/x-java-bean;version=1.4:Java::$ 27:application/x-java-bean;version=1.4.1:Java::$ 28:application/x-java-bean;version=1.4.2:Java::$ 29:application/x-java-bean;version=1.5:Java::$ 30:application/x-java-bean;jpi-version=1.5.0_04:Java::$ /opt/firefox-installer/plugins/libnullplugin.so:$ :$ 1121612100000:1:5:$ The default plugin handles plugin data for mimetypes and extensions that are not specified and facilitates downloading of new plugins.:$ Default Plugin:$ 1 0:*:All types:.*:$
regardes si tu as bien des lignes parlant de flash...limite
ContributeurBon, le problème est réglé mais pas totalement :
Après avoir copier les 2 fichiers dans le repertoire plugin de mozilla-firefox, l'animation et le son fonctionne, idem quand je vais sur mozilla-1.7.6. Ensuite je reboot et j'ouvre la carte virtuelle dans mozilla et là ça ne marche pas (pas de son mais l'animation fonctionne), j'essaie sur firefox idem. Puis je reviens sur mozilla et là ca marche, idem sur firefox. J'y comprend rien.
Pour m'assurer de la curiosité du problème, je reboot et refais la me manip:
1ère ouverture sur mozilla --------> marche pas
2ème ouverture sur firefox --------> marche pas
3ème ouverture sur mozilla -------> ça marche
4ème ouverture sur firefox ----------> ça marche
J'en perd mon latin :) -
Salut copie seulement les deux fichiers flashplayer.xpt et libflashplayer.so
dans /usr/lib/mozilla-firefox-1.0.2/plugins/ pour commencermon exemple::
[goldorak@bxflash ~]$ cd /opt/firefox-installer/plugins/ [goldorak@bxflash plugins]$ ls -l total 2076 -rw-r--r-- 1 goldorak root 856 mai 20 2004 flashplayer.xpt -rwxr-xr-x 1 goldorak root 2096844 mai 20 2004 libflashplayer.so* lrwxrwxrwx 1 root root 57 aoû 28 02:42 libjavaplugin_oji.so -> /opt/jdk1.5.0_04/jre/plugin/i386/ns7/libjavaplugin_oji.so* -rwxrwxrwx 1 root root 18840 jui 17 16:55 libnullplugin.so* [goldorak@bxflash plugins]$
limite
ContributeurMais alors pourquoi ça marche avant de rebooter ???
récapitulatif
dans /usr/lib/ j'ai les répertoire suivant :
1- mozilla
2-mozilla-1.76
3-mozilla-firefox-1.0.2
Dans /usr/lib/mozilla/plugins/ j'ai les fichiers suivant :
[pristella@lns-vlq-21-mar-82-255-60-100 ~]$ cd /usr/lib/mozilla/plugins
[pristella@lns-vlq-21-mar-82-255-60-100 plugins]$ ls -l
total 2448
-rw-r--r-- 1 root root 856 sep 12 20:34 flashplayer.xpt
-rwxr-xr-x 1 root root 11052 fév 16 2005 kaffeineplugin.so*
-rwxr-xr-x 1 root root 2096844 sep 12 20:34 libflashplayer.so*
-rwxr-xr-x 1 root root 13860 mar 25 20:35 libmozilla_bonobo.so*
-rwxr-xr-x 1 root root 8252 mar 14 09:28 libmozswfdec.so*
-rwxr-xr-x 1 root root 15864 jan 30 2005 libnpflash.so*
-rwxr-xr-x 1 root root 18460 sep 12 20:37 libnullplugin.so*
-rwxr-xr-x 1 root root 203644 avr 9 10:08 mplayerplug-in.so*
-rwxr-xr-x 1 root root 44688 mar 5 2005 nphelix.so*
-rwxr-xr-x 1 root root 5086 mar 5 2005 nphelix.xpt*
-rwxr-xr-x 1 root root 38656 mar 17 07:28 nsdejavu.so*
-rwxr-xr-x 1 root root 18936 fév 7 2005 opensc-signer.so*
Dans /usr/lib/mozilla-1.76/plugins/ j'ai les fichiers suivant :
[pristella@lns-vlq-21-mar-82-255-60-100 plugins]$ cd /usr/lib/mozilla-1.7.6/plugins
total 2448
-rw-r--r-- 1 root root 856 sep 12 20:52 flashplayer.xpt
-rwxr-xr-x 1 root root 11052 sep 12 20:54 kaffeineplugin.so*
-rwxr-xr-x 1 root root 2096844 sep 12 20:54 libflashplayer.so*
-rwxr-xr-x 1 root root 13860 sep 12 20:55 libmozilla_bonobo.so*
-rwxr-xr-x 1 root root 8252 sep 12 20:55 libmozswfdec.so*
-rwxr-xr-x 1 root root 15864 sep 12 20:56 libnpflash.so*
-rwxr-xr-x 1 root root 18460 sep 12 20:56 libnullplugin.so*
-rwxr-xr-x 1 root root 203644 sep 12 20:56 mplayerplug-in.so*
-rwxr-xr-x 1 root root 44688 sep 12 20:56 nphelix.so*
-rwxr-xr-x 1 root root 5086 sep 12 20:57 nphelix.xpt*
-rwxr-xr-x 1 root root 38656 sep 12 20:57 nsdejavu.so*
-rwxr-xr-x 1 root root 18936 sep 12 20:57 opensc-signer.so*
Dans /usr/lib/mozilla-firefox-1.0.2/plugins/ j'ai les fichiers suivant :
[pristella@lns-vlq-21-mar-82-255-60-100 plugins]$ cd /usr/lib/mozilla-firefox-1.0.2/plugins
total 20
-rwxr-xr-x 1 root root 18460 jui 22 17:09 libnullplugin.so*
Faut-il que je copie les fichiers de /usr/lib/mozilla(1.7.6)/plugins/ dans /usr/lib/mozilla-firefox-1.0.2/plugins/ ??????????
Sinon comment puis-je régler mon problème??
merci encore pour ton aide -
Salut
Je crois là où tu te trompes, c'est bien où tu installes les plugins Pristella
Tu dois les installer dans un repertoire comme +-
/usr/lib/mozilla-firefox/plugins
où bien...
là où tu as voulu installé tes nouveaux mozilla 1.7 et firefox 1.0.6
Donc si tu l'as insatllé dans /usr/local/mozilla/plugins, c'est de ce côté
que tu devrais copier-coller les fichiers...
limite
Contributeurvoilà, me problème en installant firefox.
J'ai installé firefox puis j'ai testé sur firfox une carte virtuelle , ça marche
puis j'ai ouvert une carte virtuelle avec mozilla-1.76, ça marche
enfin je reboot et je reessaye une carte sur mozilla-1.7.6, plus de son sur la carte virtuelle
j'essaie en ouvrant firefox -------IDEM
J'y comprend rien :(:( il suffit que je reboot pour ne plus avoir de son sur les cartes virtuelles. ????? -
ContributeurC'est incomprehensible, je viens de copier tous les plugins de /usr/lib/mozilla/plugins/ dans /home/pristella/.mozilla/plugins/ et j'ai le me problème ....
Après les avoir copiés, je teste une carte virtuelles et ça marche , image et sons. Ensuite je reboot et reessaye la me carte virtuelle, l'animation fonctionne mais pas le son.
Je vais tester en installant firefox ....
C'est minant :( -
ContributeurAlors, il y a du mieux car maintenant j'ai l'image et l'animation des cartes virtuelles avec le son mais lorsque je reboot, j'ai l'nimation mais plus le son ??? c'est bizarre, ça ne marche plus après un reboot.
Une précision, dans /usr/lib/ j'ai un repertoire MOZILLA et un autre MOZILLA-1.7.6. Peut-être y -t-il conflit entre les 2?
Je vais essayé quelquechose en copiant tous les fichiers du réperoire /usr/lib/mozilla-1.7.6/plugins/ dans /home/pristella/.mozilla/plugins/
Peut est-ce là le problème ??? -
Salut Matthieu
Tu as installé ceci dans le repertoire plugins de firefox?
Tu dois obligatoirement installer celà dans le dossier plugins, car lorsque
ton naviguateur essaie d'acceder à une page qui nécéssite un plugin,
le naviguateur recherche dans son dossier plugins
flashplayer.xpt et libflashplayer.so sont à copier coller dans :
Pour Matthieu
/home/matthieu/firefox-installer/plugins
limite
Contributeurbonjour limite et merci pour tes réponses,
Juste une précision, mon navigateur n'est pas firefox mais Mozilla 1.7.6.
De plus , durant l'installation les fichiers ont bien été copiés mais dans le réperoire plugins :/home/pristella/.mozilla/plugins donc normalement tout est en ordre. Malheureusement ça ne fonctionne pas .
Comme je l'explique plus haut, flash fonctionne juste après l'installation mais après le reboot, ça ne fonctionne plus.
Néanmoins, je vais suivre ton conseil en installant firefox....
merci pour ton aide -
bonjour moi aussi j'ai un pb d'installation de flash player 7, je l'ai installé par la console, c'est le meme topo que ce que Pristella à copier, à part que j'ai réussis à l'installer dans/home/matthieu/firefox-installer/ mais quand j'essaye d'écouter une radio ou autre il cherche un plugin qu'il ne trouve jamais
Komen faire? -
Resalut
j'ai oublier de te dire qu'il ne faut pas nécessairement faire la phase d'installation du flash player en mode console.
Décompresse n'importe où l'archive flash
et suis la manipulation <2> 8)limite
Salut Pristella
Donc, essaie de cette façon
Ton repértoire firefox, se trouve en principe dans /usr/lib
tu dois juste copier coller les deux fichiers flashplayer.xpt et libflashplayer.so
dans le repertoire /usr/lib/mozilla-firefox/plugins
pour Konqueror
1.Ouvres Konqueror
2.Onglet configuration
3.Configurer konqueror
4.Modules externes
5. Tu dois donner le chemin du dossier plugin de Mozilla firefox.
Et normalement après même avec konqueror, tu vois du flash, etc
Je suis à l'écoute pour des questions...
limite
Salut Pristell
