Optimisation d'un code VBA pour EXCEL
Je viens de faire ce code et je n'arrive pas à le rendre plus simple.
Pouvez-vous m'aider ?
Sub UpdateWeek()
Application.ScreenUpdating = False
Windows("VAR_V20100308.xlsm").Activate
nb = Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP1").PivotFields("Semaine").PivotItems.Count
For l = 1 To 3
With Sheets("VAR_FR_LE_TMP").PivotTables("TCD_VAR_FR_LE_TMP" & l)
For i = 2 To nb
With Sheets("VAR_FR_LE_TMP").PivotTables("TCD_VAR_FR_LE_TMP" & l).PivotFields("Semaine")
.PivotItems(i).Visible = False
End With
Next
For i = 2 To semaine(Now - 14)
.PivotItems(i).Visible = True
End With
Next
End With
Next
For l = 1 To 3
With Sheets("VAR_FR_G500_TMP").PivotTables("TCD_VAR_FR_G500_TMP" & l)
For i = 2 To nb
With Sheets("VAR_FR_G500_TMP").PivotTables("TCD_VAR_FR_G500_TMP" & l).PivotFields("Semaine")
End With
Next
End With
Next
End With
Next
For l = 1 To 3
With Sheets("VAR_FR_PUB_TMP").PivotTables("TCD_VAR_FR_PUB_TMP" & l)
For i = 2 To nb
With Sheets("VAR_FR_PUB_TMP").PivotTables("TCD_VAR_FR_PUB_TMP" & l).PivotFields("Semaine")
End With
Next
End With
Next
End With
Next
For l = 1 To 3
With Sheets("VAR_FR_SMB_TMP").PivotTables("TCD_VAR_FR_SMB_TMP" & l)
For i = 2 To nb
With Sheets("VAR_FR_SMB_TMP").PivotTables("TCD_VAR_FR_SMB_TMP" & l).PivotFields("Semaine")
End With
Next
End With
Next
End With
Next
For l = 1 To 5
With Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP" & l)
For i = 2 To nb
With Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP" & l).PivotFields("Semaine")
End With
Next
End With
Next
End With
Next
For l = 1 To 4
With Sheets("DEC_TMP").PivotTables("TCD_AMOSTMP" & l)
For i = 2 To nb
With Sheets("DEC_TMP").PivotTables("TCD_AMOSTMP" & l).PivotFields("Semaine")
End With
Next
End With
Next
End With
Next
Application.ScreenUpdating = True
End Sub
Merci pour votre aide
Ludo
Sub UpdateWeek()
For l = 1 To 3
For i = 2 To nb
End With
Next
End With
Next
End With
Next
For l = 1 To 3
For i = 2 To nb
End With
Next
End With
Next
End With
Next
For l = 1 To 3
For i = 2 To nb
End With
Next
End With
Next
End With
Next
For l = 1 To 3
For i = 2 To nb
End With
Next
End With
Next
End With
Next
For l = 1 To 5
For i = 2 To nb
End With
Next
End With
Next
End With
Next
For l = 1 To 4
For i = 2 To nb
End With
Next
End With
Next
End With
Next
End Sub
Ludo
Configuration: Windows Vista / Firefox 3.6
Cool ca marche :-) Merci beaucoup
Voici la nouvelle version :
Sub UpdateWeek() Application.ScreenUpdating = False Windows("VAR_V20100308.xlsm").Activate nb = Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP1").PivotFields("Semaine").PivotItems.Count For l = 1 To 3 With Sheets("VAR_FR_LE_TMP").PivotTables("TCD_VAR_FR_LE_TMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With With Sheets("VAR_FR_G500_TMP").PivotTables("TCD_VAR_FR_G500_TMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With With Sheets("VAR_FR_PUB_TMP").PivotTables("TCD_VAR_FR_PUB_TMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With With Sheets("VAR_FR_SMB_TMP").PivotTables("TCD_VAR_FR_SMB_TMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With Next For l = 1 To 5 With Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With Next For l = 1 To 4 With Sheets("DEC_TMP").PivotTables("TCD_AMOSTMP" & l).PivotFields("Semaine") For i = 2 To semaine(Now - 14) .PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb .PivotItems(i).Visible = False Next End With Next Application.ScreenUpdating = True End Sub -
Test
Je n'arrive pas à ajouter un nouveau message. -
Voici une proposition, je ne pense pas avoir fait d'erreur de copié-colléSub UpdateWeek() Dim PF_1 As PivotField Dim PF_2 As PivotField Dim PF_3 As PivotField Dim PF_4 As PivotField Dim PF_5 As PivotField Application.ScreenUpdating = False Windows("VAR_V20100308.xlsm").Activate nb = Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP1").PivotFields("Semaine").PivotItems.Count Set PF_1 = Sheets("VAR_FR_LE_TMP").PivotTables("TCD_VAR_FR_LE_TMP" & l).PivotFields("Semaine") Set PF_2 = Sheets("VAR_FR_G500_TMP").PivotTables("TCD_VAR_FR_G500_TMP" & l).PivotFields("Semaine") Set PF_3 = Sheets("VAR_FR_PUB_TMP").PivotTables("TCD_VAR_FR_PUB_TMP" & l).PivotFields("Semaine") Set PF_4 = Sheets("VAR_FR_SMB_TMP").PivotTables("TCD_VAR_FR_SMB_TMP" & l).PivotFields("Semaine") Set PF_5 = Sheets("VAR_FR_TMP").PivotTables("TCD_VAR_FR_TMP" & l).PivotFields("Semaine") Set PF_5 = Sheets("DEC_TMP").PivotTables("TCD_AMOSTMP" & l).PivotFields("Semaine") For l = 1 To 3 For i = 2 To semaine(Now - 14) PF_1.PivotItems(i).Visible = True PF_2.PivotItems(i).Visible = True PF_3.PivotItems(i).Visible = True PF_4.PivotItems(i).Visible = True PF_5.PivotItems(i).Visible = True Next For i = (semaine(Now - 14)+1) To nb PF_1.PivotItems(i).Visible = False PF_2.PivotItems(i).Visible = False PF_3.PivotItems(i).Visible = False PF_4.PivotItems(i).Visible = False PF_5.PivotItems(i).Visible = False Next Next Application.ScreenUpdating = True End Sub
@schmoe92Bonsoir,
J'ai remarqué une erreur dans mon code, je pensais que dans chaque boucles, tu avais l = 1 To 3 mais tes deux dernières boucles vont à 5 et 4 donc c'est un premier point qui ne vas pas mais ça ne devrait pas bloquer le code si le tien fonctionne. Je regarde et je te tiens au courant.
Je n'avais pas testé le code, ça m'aiderai si tu me mettais le lien vers ton fichier (si c'est possible)
@schmoe92Bonjour,
C'est bon j'ai retrouvé mon erreur. Je corrige et je te renvoie. En fait, je n'aurai pas besoin de ton fichier.
