Probleme de Warsam
reexpose ton probleme ici on va tacher de regler ca
♦G3и-н@¢км@и™©®♦
Configuration: windows xp pro SP3 , internet explorer 8 , Bitdefender Total Security 2010 , Malwarebyte's résident , Online Armor 3.5 , Privacy eraser pro
15 réponses
  1. réouvre hijackthis
    fais scan only
    coches ces lignes sur leur gauche:
    R3 - URLSearchHook: P2P Energy Toolbar - {2bae58c2-79f9-45d1-a286-81f911301c3a} - C:\Program Files\P2P_Energy\tbP2P1.dll
    R3 - URLSearchHook: tawdif Toolbar - {f4cab138-57da-46a9-8972-10d5b88d91f9} - C:\Program Files\tawdif\tbtaw0.dll
    F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\winlogon86.exe
    O2 - BHO: SBCONVERT Class - {A1056498-D09A-41E4-864B-505EDD640D9E} - C:\Program Files\SpeedBit Video Downloader\Toolbar\SpeedBitVideoDownloader.dll (file missing)
    O2 - BHO: tawdif Toolbar - {f4cab138-57da-46a9-8972-10d5b88d91f9} - C:\Program Files\tawdif\tbtaw0.dll
    O3 - Toolbar: tawdif Toolbar - {f4cab138-57da-46a9-8972-10d5b88d91f9} - C:\Program Files\tawdif\tbtaw0.dll
    O3 - Toolbar: DAEMON Tools Toolbar - {32099AAC-C132-4136-9E9A-4E364A424E17} - C:\Program Files\DAEMON Tools Toolbar\DTToolbar.dll
    O3 - Toolbar: SpeedBit Video Downloader - {0329E7D6-6F54-462D-93F6-F5C3118BADF2} - C:\Program Files\SpeedBit Video Downloader\Toolbar\SpeedBitVideoDownloader.dll (file missing)
    O2 - BHO: P2P Energy Toolbar - {2bae58c2-79f9-45d1-a286-81f911301c3a} - C:\Program Files\P2P_Energy\tbP2P1.dll
    O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
    O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
    O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
    O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Fichiers communs\InstallShield\UpdateService\issch.exe" -start
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\MpcStar\Codecs\QuickTime\QTSystem\qttask.exe" -atboottime
    O4 - HKLM\..\Run: [winupdate86.exe] C:\WINDOWS\system32\winupdate86.exe
    O8 - Extra context menu item: Tout télécharger avec BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddAllLink.htm
    O8 - Extra context menu item: Télécharger avec BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddLink.htm
    O8 - Extra context menu item: Télécharger toutes les vidéos avec BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddVideo.htm
    O10 - Unknown file in Winsock LSP: c:\windows\system32\winhelper86.dll
    O15 - ESC Trusted Zone: https://www.adobe.com/
    O15 - ESC Trusted Zone: http://www.commentcamarche.net
    O15 - ESC Trusted Zone: https://www.elkhabar.com/
    O15 - ESC Trusted Zone: https://www.lyad.fr
    O15 - ESC Trusted Zone: https://www.lyad.fr/
    O15 - ESC Trusted Zone: https://www.msn.com/fr-fr
    O15 - ESC Trusted Zone: http://runonce.msn.com
    O15 - ESC Trusted Zone: http://www.usthb.com
    O15 - ESC Trusted Zone: http://www.wideo.fr
    O15 - ESC Trusted Zone: http://*.windowsupdate.com
    O15 - ESC Trusted Zone: http://*.windowsupdate.com (HKLM)
    O15 - ESC Trusted IP range: http://10.16.4.5
    O23 - Service: Gestionnaire de mise à jour Winsudate (WinSvc) - Winsudate - C:\Program Files\Winsudate\gibsvc.exe
    tu les coches et tu clic sur "fix checked"
    et tu fermes le programme.
    redemarre le pc ensuite
    1. quand j'excute l'exécutable ce msg "warning" s'affiche :
      systeme restore interface not present
        1. essaie ceci :
          Télécharge OTL de OLDTimer
          ▶ enregistre le sur ton Bureau.
          ▶ Double clic ( pour vista => clic droit "executer en tant qu'administrateur") sur OTL.exe pour le lancer.
          ▶ Coche les 2 cases Lop et Purity
          ▶ Coche la case devant scan all users
          ▶ règle-le sur "60 Days"
          ▶ dans la colonne de gauche , mets tout sur all
          ne modifie pas ceci :
          "files created whithin" et "files modified whithin"
          ▶Clic sur Run Scan.
          A la fin du scan, le Bloc-Notes va s'ouvrir avec le rapport (OTL.txt).
          Ce fichier est sur ton Bureau (en général C:\Documents and settings\le_nom_de_ta_session\OTL.txt)
          ▶▶▶ NE LE POSTE PAS SUR LE FORUM
          Pour me le transmettre clique sur ce lien : http://www.cijoint.fr/
          ▶ Clique sur Parcourir et cherche le fichier ci-dessus.
          ▶ Clique sur Ouvrir.
          ▶ Clique sur "Cliquez ici pour déposer le fichier".
          Un lien de cette forme :
          http://www.cijoint.fr/cjlink.php?file=cjge368/cijSKAP5fU.txt
          est ajouté dans la page.
          ▶ Copie ce lien dans ta réponse.
          ▶▶ Tu feras la meme chose avec le "Extra.txt".
          1. ok essaie par ce lien
            http://www.cijoint.fr/cjlink.php?file=cj200912/cijX2BadVA.zip
            1. tjr rien, svp assisté moi car c le pc de travail
              1. bonjour
                Adware Gib Média Malwarebytes le traite
            2. oui si tu l as fait y a pas longtemps , j'etais en train de faire des màj....donc possible que tu sois tombé a ce moment-là
              1. le link ne marche pas j'ai pas pu téléchargé l'outil j'ai meme essayé avec un autre pc
                (en fait j'ai tjr le virus "setup.exe" sur mon pc )
                1. Desactive ton antivirus le temps de la manip ainsi que ton parefeu si présent
                  ▶ Télécharge List&Kill'em et enregistre le sur ton bureau
                  ▶ dezippe-le , (clic droit/ extraire.....)
                  Il ne necessite pas d'installation
                  ▶ double clic (clic droit "executer en tant qu'administrateur" pour Vista) pour lancer le scan
                  choisis la langue puis choisis l'option 1 = Mode Recherche
                  ▶ laisse travailler l'outil
                  un rapport du nom de catchme apparait sur ton bureau , ignore-le , mais ne le supprime pas pour l instant
                  ▶ Poste le contenu du rapport qui s'ouvre
                  1. lors de démarrage de windows s'afiche un msg : mon sys est infecté par worm/ win32 .....etc g retenu tout :-(
                    et j'ai chaque instant un message attention systeme detected a potential hazard (trjanSPM/LX) on your cmputer.........
                    g excuté hijackthis et g désactivé un exe advenced virus remover
                    1. g un widows server 2003 et j'ai excuté un exe par défaut qui a changé le thème bureau (j'ai éssaié de le rechangé mais tout est bloqué , désactivé gestionnaire des tache, certain racourci sur la bar des taches ne réponds plus (claculatrice, notebook, (msg: application cannot be excuted, the file is infected, please activate your antivirus sofware ...) ne figure plus dans le menu demarrer et chaque instant un message warning:
                      g fait hijackthis et voilà le ficher log
                      Scan saved at 13:00:42, on 09/12/2009
                      Platform: Windows 2003 SP2 (WinNT 5.02.3790)
                      MSIE: Internet Explorer v8.00 (8.00.6001.18702)
                      Boot mode: Normal
                      Running processes:
                      C:\WINDOWS\System32\smss.exe
                      C:\WINDOWS\system32\lsass.exe
                      C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
                      C:\Program Files\Fichiers communs\Symantec Shared\ccSvcHst.exe
                      C:\WINDOWS\system32\netdde.exe
                      C:\Program Files\Firebird\Firebird_2_1\bin\fbguard.exe
                      C:\Program Files\Java\jre6\bin\jqs.exe
                      C:\Program Files\Fichiers communs\Microsoft Shared\VS7DEBUG\MDM.EXE
                      C:\PROGRA~1\MICROS~4\MSSQL$~1\binn\sqlservr.exe
                      C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
                      C:\WINDOWS\system32\Dfssvc.exe
                      C:\Program Files\Fichiers communs\System\MSSearch\Bin\mssearch.exe
                      C:\Program Files\Firebird\Firebird_2_1\bin\fbserver.exe
                      C:\WINDOWS\Explorer.EXE
                      C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
                      C:\Program Files\Fichiers communs\Symantec Shared\ccApp.exe
                      C:\Program Files\Java\jre6\bin\jusched.exe
                      C:\WINDOWS\system32\ctfmon.exe
                      C:\Program Files\Fichiers communs\Ahead\Lib\NMBgMonitor.exe
                      C:\Program Files\Trend Micro\scanner\HijackThis.exe
                      C:\Program Files\Orbitdownloader\orbitdm.exe
                      C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
                      C:\Program Files\Orbitdownloader\orbitnet.exe
                      C:\Program Files\Fichiers communs\Ahead\Lib\NMIndexStoreSvr.exe
                      R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
                      R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
                      R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
                      R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://www.msn.com/fr-fr/?ocid=iehp
                      R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
                      R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
                      R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.msn.com/fr-fr/?ocid=iehp
                      R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
                      R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
                      O2 - BHO: Octh Class - {000123B4-9B42-4900-B3F7-F4B073EFC214} - C:\Program Files\Orbitdownloader\orbitcth.dll
                      O2 - BHO: Aide pour le lien d'Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
                      O2 - BHO: BitComet Helper - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Program Files\BitComet\tools\BitCometBHO_1.3.7.16.dll
                      O2 - BHO: IECatcher Class - {B930BA63-9E5A-11D3-A288-0000E80E2EDE} - C:\PROGRA~1\MASSDO~1\MDHELPER.DLL
                      O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
                      O2 - BHO: JQSIEStartDetectorImpl Class - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
                      O3 - Toolbar: P2P Energy Toolbar - {2bae58c2-79f9-45d1-a286-81f911301c3a} - C:\Program Files\P2P_Energy\tbP2P1.dll
                      O3 - Toolbar: Grab Pro - {C55BBCD6-41AD-48AD-9953-3609C48EACC7} - C:\Program Files\Orbitdownloader\GrabPro.dll
                      O4 - HKLM\..\Run: [1A:Stardock TrayMonitor] "C:\Program Files\Fichiers communs\Stardock\TrayServer.exe"
                      O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Fichiers communs\Symantec Shared\ccApp.exe"
                      O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\FICHIE~1\INSTAL~1\UPDATE~1\isuspm.exe -startup
                      O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
                      O4 - HKLM\..\Run: [MSConfig] "C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe" /auto
                      O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
                      O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Fichiers communs\Ahead\Lib\NMBgMonitor.exe"
                      O4 - HKCU\..\Run: [Real Desktop] "C:\Program Files\Real Desktop\Real Desktop.exe"
                      O4 - HKCU\..\Run: [HijackThis startup scan] C:\Program Files\Trend Micro\scanner\HijackThis.exe /startupscan
                      O4 - HKCU\..\RunOnce: [Shockwave Updater] C:\WINDOWS\system32\Adobe\SHOCKW~1\SWHELP~1.EXE -Update -1103472 -"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; .NET CLR 1.1.4322; InfoPath.2; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)" -"http://perso.ensad.fr/ari/davidov/prog/encarts/trigo.htm"
                      O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
                      O4 - HKUS\S-1-5-19\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'SERVICE LOCAL')
                      O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
                      O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
                      O4 - Global Startup: Orbit.lnk = C:\Program Files\Orbitdownloader\orbitdm.exe
                      O4 - Global Startup: Service Manager.lnk = C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
                      O8 - Extra context menu item: &Download by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/201
                      O8 - Extra context menu item: &Grab video by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/204
                      O8 - Extra context menu item: &Tout télécharger en utilisant Mass Downloader - C:\Program Files\Mass Downloader\Add_All.htm
                      O8 - Extra context menu item: Do&wnload selected by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/203
                      O8 - Extra context menu item: Down&load all by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/202
                      O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~1\Office12\EXCEL.EXE/3000
                      O8 - Extra context menu item: Télécharger en utilisant &Mass Downloader - C:\Program Files\Mass Downloader\Add_Url.htm
                      O9 - Extra button: Mass Downloader - {0FD01980-CCCB-11D3-80D4-0000E80E2EDE} - C:\Program Files\Mass Downloader\massdown.exe (file missing)
                      O9 - Extra 'Tools' menuitem: &Mass Downloader - {0FD01980-CCCB-11D3-80D4-0000E80E2EDE} - C:\Program Files\Mass Downloader\massdown.exe (file missing)
                      O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\system32\shdocvw.dll
                      O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\system32\shdocvw.dll
                      O9 - Extra button: BitComet - {D18A0B52-D63C-4ed0-AFC6-C1E3DC1AF43A} - res://C:\Program Files\BitComet\tools\BitCometBHO_1.3.7.16.dll/206 (file missing)
                      O9 - Extra button: ICQ6 - {E59EB121-F339-4851-A3BA-FE49C35617C2} - C:\Program Files\ICQ6\ICQ.exe
                      O9 - Extra 'Tools' menuitem: ICQ6 - {E59EB121-F339-4851-A3BA-FE49C35617C2} - C:\Program Files\ICQ6\ICQ.exe
                      O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll
                      O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/...
                      O16 - DPF: {9BBB3919-F518-4D06-8209-299FC243FC30} (Encrypt Class) - https://10.16.4.2:4343/SMB/console/html/root/AtxEnc.cab
                      O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
                      O17 - HKLM\System\CCS\Services\Tcpip\..\{20A81EB6-9609-4D63-A375-D69B14C612A1}: NameServer = 193.251.169.165,213.140.2.21
                      O17 - HKLM\System\CS1\Services\Tcpip\..\{20A81EB6-9609-4D63-A375-D69B14C612A1}: NameServer = 193.251.169.165,213.140.2.21
                      O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Fichiers communs\Symantec Shared\ccSvcHst.exe
                      O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Fichiers communs\Symantec Shared\ccSvcHst.exe
                      O23 - Service: Firebird Guardian - DefaultInstance (FirebirdGuardianDefaultInstance) - Firebird Project - C:\Program Files\Firebird\Firebird_2_1\bin\fbguard.exe
                      O23 - Service: Firebird Server - DefaultInstance (FirebirdServerDefaultInstance) - Firebird Project - C:\Program Files\Firebird\Firebird_2_1\bin\fbserver.exe
                      O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Fichiers communs\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
                      O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
                      O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
                      O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
                      O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - CACE Technologies - C:\Program Files\WinPcap\rpcapd.exe
                      O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
                      O23 - Service: Client de gestion Symantec (SmcService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
                      O23 - Service: Symantec Network Access Control (SNAC) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\SNAC.EXE
                      O23 - Service: Symantec Endpoint Protection (Symantec AntiVirus) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
