Problème d'installation avec proftpd
bonjour,
Jai un très gros problème.
Voilà jessaie dinstaller sur ma debian proftpd.
Alors jai utiliser la commande apt-get install proftpd
Mais au moment de le lancer elle maffiche deux erreurs la première est que :
_no certificate files found
_unknown configuration directive ListOptions on line 16 of 'etc/proftpd.conf'
çi dessous "ma" config proftpd qui fonctionne:
Ghost
# This is a basic ProFTPD configuration file.
# It establishes a single server and a single anonymous login.
# It assumes that you have a user/group "nobody" and "ftp"
# for normal/anonymous operation.
ServerName "ProFTPD Default Installation"
ServerType standalone
#ServerType inetd
DefaultServer on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# This next option is required for NIS or NIS+ to work properly:
#PersistentPasswd off
SystemLog /var/log/proftpd.log
TransferLog /var/log/xferlog
# Normally, we want files to be overwriteable.
<Directory /*>
AllowOverwrite on
</Directory>
# A basic anonymous FTP server configuration.
# To enable this, remove the user ftp from /etc/ftpusers.
<Anonymous ~ftp>
#<Anonymous /var/www/htdocs>
RequireValidShell off
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Limit the maximum number of anonymous logins
MaxClients 50
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin welcome.msg
DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot
<Limit WRITE>
DenyAll
</Limit>
# An upload directory that allows storing files but not retrieving
# or creating directories.
# <Directory incoming/*>
# <Limit READ>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
</Anonymous>
comment ai je pu ne pas y penser!!!
zut!!
voici mon fichier de configuration :
ServerName "Serveur_Pedagogique"
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
#ListOptions "-l"
DenyFilter \*.*/
#Uncomment this line if you are using NIS or LDAP to retrieve passwords:
#Uncomment this line if you woud use TLS module:
#TLSProtocols SSLv23
TLSRSACertificateFile /etc/ssl/mon_ca/private/ca_key.pem
TLSRSACertificateKeyFile /etc/ssl/mon_ca/private/ca_key.pem
#TLSLog /var/log/proftpd/tls.log
#Uncomment this line if you would use quota module:
#Quotas on
#Uncomment this line if you would use ratio module:
#Ratios on
#Port 21 is the standard FTP port
Port 21
#To prevent DOS attacks,set the maximum number of child processes
#to 30.If you need to allow more than 30 concurrent connections
#at once ,simply increase this value.Note that this ONLY works
#in standalone mode,in inetd mode you should use an inetdserver
#that allows you to limit maximum number of processes per service
#(such as xinetd)
MaxInstances 30
#Set the user and group that the server normally runs at.
User nobody
Group nogroup
#Umask 022 is a good standard umask to prevent new files and dirs
#(second parm)from being group and world writable
Umask 022 022
#Normally,we want files to be overwriteable
AllowOverwrite on
#Delay engine reduces impact of trhe so-called Timing Attack described in
#http://security.lss.hr/Index.php? [...]2004-10-02
#It is on by default
<Directory /var/ftp>
AllowOverwrite on
AllowRetrieveRestart on
AllowStoreRestart on
HiddenStor off
HideNoAccess on
</Directory>
et voilà ce que ca me donne lorsque jessaie de démarrer mon serveur ftp:
se3:/etc/init.d# proftpd start
- No certificate files found!
- Fatal: unknown configuration directive 'TLSRSACertificateFile' on line 26 of '/etc/proftpd.conf'.
Alors si quelqun peut maier ca serait sympa :
HELP!!!!!!!!
merci davance. -
la premiere question est plutot fantaisiste
la seconde ..donne nous cette ligne de configuration ???
on a pas encore un tel don de lire tes fichier par transmission de pensée
Ghost
