[VBA] Comment optimiser ce code ?
Bonjour, je travail sur VBA d'excel et j'aimerais insérer une variable avant un "="
du style :
For i = 1 To 10
UserForm1."Checkbox"&i.Caption = "toto" & i
Next i
Je veux que chaque CheckBox s'apelle toto1, toto2 etc.
pour éviter de faire ceci :
Merci !
du style :
For i = 1 To 10
Next i
For i = 4 To 31
Range("A" & i).Select
If i = 4 Then
' cliste est un UserForm et L1 une checbox ..
cliste.L1.Caption = ActiveCell.FormulaR1C1
ElseIf i = 5 Then
cliste.L2.Caption = ActiveCell.FormulaR1C1
ElseIf i = 6 Then
cliste.L3.Caption = ActiveCell.FormulaR1C1
ElseIf i = 7 Then
cliste.L4.Caption = ActiveCell.FormulaR1C1
ElseIf i = 8 Then
cliste.L5.Caption = ActiveCell.FormulaR1C1
ElseIf i = 9 Then
cliste.L6.Caption = ActiveCell.FormulaR1C1
ElseIf i = 10 Then
cliste.L7.Caption = ActiveCell.FormulaR1C1
ElseIf i = 11 Then
cliste.L8.Caption = ActiveCell.FormulaR1C1
ElseIf i = 12 Then
cliste.L9.Caption = ActiveCell.FormulaR1C1
ElseIf i = 13 Then
cliste.L10.Caption = ActiveCell.FormulaR1C1
ElseIf i = 14 Then
cliste.L11.Caption = ActiveCell.FormulaR1C1
ElseIf i = 15 Then
cliste.L12.Caption = ActiveCell.FormulaR1C1
ElseIf i = 16 Then
cliste.L13.Caption = ActiveCell.FormulaR1C1
ElseIf i = 17 Then
cliste.L14.Caption = ActiveCell.FormulaR1C1
ElseIf i = 18 Then
cliste.L15.Caption = ActiveCell.FormulaR1C1
ElseIf i = 19 Then
cliste.L16.Caption = ActiveCell.FormulaR1C1
ElseIf i = 20 Then
cliste.L17.Caption = ActiveCell.FormulaR1C1
ElseIf i = 21 Then
cliste.L18.Caption = ActiveCell.FormulaR1C1
ElseIf i = 22 Then
cliste.L19.Caption = ActiveCell.FormulaR1C1
ElseIf i = 23 Then
cliste.L20.Caption = ActiveCell.FormulaR1C1
ElseIf i = 24 Then
cliste.L21.Caption = ActiveCell.FormulaR1C1
ElseIf i = 25 Then
cliste.L22.Caption = ActiveCell.FormulaR1C1
ElseIf i = 26 Then
cliste.L23.Caption = ActiveCell.FormulaR1C1
ElseIf i = 27 Then
cliste.L24.Caption = ActiveCell.FormulaR1C1
ElseIf i = 28 Then
cliste.L25.Caption = ActiveCell.FormulaR1C1
ElseIf i = 29 Then
cliste.L26.Caption = ActiveCell.FormulaR1C1
ElseIf i = 30 Then
cliste.L27.Caption = ActiveCell.FormulaR1C1
ElseIf i = 31 Then
cliste.L28.Caption = ActiveCell.FormulaR1C1
End If
Next i
Merci !
oui oubien pour ne pas devoir compter le décallage :
userform.controls("toto" & i) -
Trop cool ca marche !
Merci beaucoup à vous deux !! -
il y a deux facons d'adresser un controle
soir par son nom soit par son ordre
il faut employer une adresse
du genre userform.controls(i+décalage initial) -
Le code est en VB,
J'ai essayé :cliste.Control ["L"&i].Caption = ActiveCell.FormulaR1C1
oucliste.["L"&i].Caption = ActiveCell.FormulaR1C1
mais il me dit "Membre de méthode ou de donnée introuvable" -
ContributeurSalut,
En VBA je ne sais pas, mais en VB il existe un moyen, c'est je crois cliste.Control["nomducontrol"]
