HELP !!!
Salut à tous !
G un soucis, ki commence sérieusement a m'énnerver !!!
Voilà, à chaque démarrage de mon PC, g une page web ki s'affiche et je ne c pa comment faire pour m'en débarrassé ! est-ce un virus ou autre chose ???? Voici la page, si qq comprend qc aider moi svp
MSN HandWriting Error
Hello, you where redirected to this page because you have the MSN HandWriting Plugin for Messenger Plus! installed, but forgot something!
Please read this before pulling any conclusions about spy- or adware.
For MSN HandWriting to function correctly, it will need two things:
1.The Ink Redistributables
2.Windows 2000/XP/2003 or higher.
If your PC did not match this profile, you where redirected to this page. this is not malware/spyware/adware or whatever you call that crap, I did not use a MessageBox for a very simple reason: it would lock up your MSN Messenger login process, and you would no longer be able to log into msn!
Now, the next step:
How to fix this
Yes, this is obviously what you where looking for, so here's a quick run-trough to see what went wrong:
- Are you sure you are running Windows 2000/XP/2003 ? if not, proceed to Removing MSN HandWriting
- Are you sure you installed the Ink Redistributables for "All Users"? if not, proceed either to Removing MSN HandWriting or Installing the Ink Redistributables
- if those two questions did not solve this page, then I would have no clue what the hell you did wrong, and you'd probably be best off by Removing MSN HandWriting
The Ink Redistributables is a package for windows to enable the handwriting control needed by MSN to work with handwriting
You can obtain it in three ways:
First thing to try is to see if you can find your Windows 2000/XP/2003 CD, and try to install "Microsoft Journal Viewer", to my knowledge this includes the neccesary components for the MSN HandWriting plugin.
If that did not fix it, or you where unable to find the CD, you can download a seperate Ink Redistributables package from one of the mirrors below Please make sure you install for "All users" and not for "Just me"!:
- Mess.be (ink redists are included in this packge)
- Kaonet.net (ink redists are included in this packge)
- Messenger Plus! Plugins database (ink redists are included in this packge)
If installing the Ink Redistributables did not help, you should try to proceed to Removing MSN HandWriting
MSN HandWriting is a DLL that resides in your Messenger Plus! Plugins folder, usually located at:
C:\Program Files\Messenger Plus! 2\Plugins\
Before trying to remove the dll, make sure MSN Messenger and Windows Messenger are completely turned off, so also close them from your system tray.
After that, you should try to locate MSNHandWriting.dll in the above mentioned folder, and delete or rename it to something not ending in .dll
If you cannot find the dll, please make sure that system files are not hidden.
If Windows refuses to remove the dll, Please make sure with the task manager that neither of these processes is running: msnmsgr.exe, msmsgs.exe, msgplus.exe
If this did not yet fix your problem, you can try HandWriting DLL Uninstaller by Sk3tch...
If these steps still did not solve your problem, you can try to find help at the Messenger Plus! Forums
  1. moi c tout le contaire je veux l' installé et je sais ke sa ne marhce pas et pour tan j' ai installé tout ceux ki mon dit ou enfin ce ke j' ai compris et sa ne marhce toujour pa
    1. Salut Vins !!!
      Je suis pas surque tu fais bien a vouloir installé ce truc, moi ça m'a gonflé pendant des semaines.... j'ai fini par le supprimé car ça n'a jamais marché lol.
      Bon courage et si t'arrive a le faire fonctionné, dis moi comment t'as fais !
      Bye et à bientôt.
  2. Et puis bon si tu veux vraiment dessiner sur MSN t'essayes de mettre un des 3 trucs de ta page web:
    1. Dejà rassure toi ce n'est pas un virus (je pense).
      En fait t'as installé HandWriting (plugin pour MSN) et ca marche pas!
      Je suis pas sur que ca marchera mais tu devrai supprimer le fichier "Handwriting.dll" dans C:\Program Files\MessengerPlus! 3\Plugins. Mais tu ne pourra le supprimer que si tu termine les processus "msnmsgr.exe, msmsgs.exe et msgplus.exe" (dans ctrl-alt-suppr/processus).
      Après ca plus de soucis (je pense), par contre t'aura toujours pas Handwriting. Mais bon, c'est pas si génial que ça...
