Audio problems with LED TV
petitbaguio Posted messages 13 Status Member -
jeannets Posted messages 28464 Registration date   Status Contributor Last intervention   -
Hello everyone
With my Schneider GMS 32a2 LED TV, the main speaker sound is cut off when I plug in a wireless headset to the optical jack. How can I receive both audio sounds simultaneously with this type of TV?
What device is possible? Thank you for your help
  1. jeannets Posted messages 28464 Registration date   Status Contributor Last intervention   Ambassador 6 618
    Hello,
    On some TVs, you need to go to the Audio menu and choose one or the other or both... But this happens in the TV menus... as mentioned in the manual...
    But on other TVs, like Sony, it's impossible; it's one or the other, but not both...
    Personally, I tried adding a Bluetooth transmitter to the Optical output... It works... but the TV detects the BT transmission... and cuts off the speakers... It's a never-ending loop...
    You can also contact the manufacturer's support by email..!!
  2. baguio
    Hello and thank you
    On this TV, there are 3 HDMI outputs including 1 HDMI ARC. Why not use a male HDMI adapter with an audio jack output? Would the main sound be cut off? Or a soundbar with audio output instead?
  3. jeannets Posted messages 28464 Registration date   Status Contributor Last intervention   Ambassador 6 618
    If the TV reception comes via the internet... The HDMI port is occupied by the decoder... it's not a power strip.
    Let's add that HDMI connections are rarely outputs... but rather inputs.
    And I believe that this adapter does not exist...??
