LG TV won't turn on, red LED blinking.
Beuck63 Posted messages 1 Status Member -
MPMP10 Posted messages 47589 Registration date   Status Member Last intervention   -
Hello everyone.
My LG TV (model 32LB550B) won't turn on, the red light is blinking. After looking at various comments, I had a friend check the capacitors since I'm not very handy????, none are faulty. Indeed, when I use a hairdryer, the TV starts after about 10 good minutes. The TV is 7 years old. Do you have any ideas? Thanks in advance for your advice.
1 answer
  1. MPMP10 Posted messages 47589 Registration date   Status Member Last intervention   19 094
    Hello,
    Check with a repair person for a quote or invest...
    Generally speaking, when the LED is flashing, the issue is often related to the power supply.
