Alcatel Wireless Fix / No Battery on Screen
Beatrice -
baladur13 Posted messages 47335 Registration date   Status Moderator Last intervention   -
Hello, I just changed the batteries of the Alcatel cordless phone. The screen continuously displays "no battery." What should I do?
Configuration: Macintosh / Chrome 96.0.4664.93
1 answer
  1. baladur13 Posted messages 47335 Registration date   Status Moderator Last intervention   14 392
    Hello,
    What model is this Alcatel...?
    Did you change the batteries????
    You need to use rechargeable batteries!
    Putting regular batteries in a charger could cause them to explode...
    Did you install these "batteries" the right way? Usually, they are "head to tail" and there are + and - indicators in the slots.
    It's very difficult to catch a black cat in a dark room.
    Especially when it's not there...
    1. EricDu78 Posted messages 1 Status Member
      Hello,
      I have the same issue; how did you resolve the problem?
      1. baladur13 Posted messages 47335 Registration date   Status Moderator Last intervention   14 392 > EricDu78 Posted messages 1 Status Member
        Hello,
        Same issue ===> same question.
        See message#1
