Setting up sound on Philips 55Oled865 TV
Madusch Posted messages 3 Status Member -
MPMP10 Posted messages 47651 Registration date   Status Member Last intervention   -
How do you adjust the bass and treble on such a device? It seems impossible... do you have a solution? THANK YOU
  1. MPMP10 Posted messages 47651 Registration date   Status Member Last intervention   19 120
    Hello there!
    You can possibly play with the equalizer....
    User manual for 55OLED865 and 65OLED865
    https://www.download.p4c.philips.com/files/6/65oled865_12/65oled865_12_dfu_fra.pdf
    The technocrats, if they were given the Sahara, in 5 years, they would have to buy sand from elsewhere.
    Coluche.
    3
    1. Madusch Posted messages 3 Status Member
      I saw that on pages 52/53 of the manual, but on one hand it's not easy to access and I'm not sure it will enhance the highs. Have you tried it? Thank you.
      1. MPMP10 Posted messages 47651 Registration date   Status Member Last intervention   19 120 > Madusch Posted messages 3 Status Member
        Have you tried
        Uh!
        We're on a forum here and I don't have the same TV as you.
      2. Madusch Posted messages 3 Status Member > MPMP10 Posted messages 47651 Registration date   Status Member Last intervention
        It's a shame because honestly, this kind of manipulation is not easy, but I sincerely thank you nonetheless.
      3. MPMP10 Posted messages 47651 Registration date   Status Member Last intervention   19 120 > Madusch Posted messages 3 Status Member
        You're welcome...
        To keep it simple, it's a path you just need to follow. First, go to "Custom AI Equalizer", then Settings > Sound > Preferred Mode Settings, and so on...
