Issue changing quantity on Aliexpress
Clementinios Posted messages 2 Status Member -
madmyke Posted messages 52304 Registration date   Status Moderator Last intervention   -
Hello,
I currently have a problem on AliExpress. I would like to order the same item multiple times, but I cannot change the quantity, it says "1 piece per user." I want to emphasize that I have already made several orders with my account and I could change the quantity before.
Thank you for your help if you have encountered this type of problem, etc...
1 answer
  1. madmyke Posted messages 52304 Registration date   Status Moderator Last intervention   12 488
    Hello
    "1 item per user" means that it is limited to 1 item, intentionally.
    Why we don't know anything. Please check with the seller.
    best regards
    -3
