Grundig LED TV blinking issue
mikemarel72 -
Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   -
Hello, my Grundig LCD TV 40VLE5520BG
won't turn on anymore; the blue LED is blinking
the capacitors are not swollen
the fuse is okay
I can't find any information about this model. Is there a clone of this TV?
Do you have any advice for me to find the problem?
I have very little knowledge of electronics
I have already repaired power supply issues (bad capacitors, faulty LED strip) on other friends' TVs, but I'm stuck here
Thank you for your responses
Configuration: Windows / Firefox 87.0
1 answer
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 203
    Hello,
    It might be a circuit overload issue, not sure, but it's worth trying this:
    Unplug it and short the two prongs of the socket with a wire, paper clip, etc...
    Of course, do not plug it back in
    Wait an hour, remove the wire or paper clip and plug it back in
    I call a spade a spade *
         *in French in the text
    10
