Problem with my PS Vita charging
aissammagder Posted messages 11 Status Member -
TsukinoMochi Posted messages 116 Status Member -
Hello
I have a problem with my PS Vita, it won't charge
When I plug it in, it shows that it's charging for a few moments, then it stops charging
And when I turn it on, it shows that the battery is not charging, it works for a few seconds then it shows the battery is empty.
Please, I’m looking for a solution.
1 answer
  1. TsukinoMochi Posted messages 116 Status Member 25
    Hello,
    Sorry if the response is a bit late.
    There are probably only two alternatives: either the battery has an issue, or the charger being used has one (is it old? Is it certified by Sony – in other words, official?).
    To solve your problem, you can try looking here: https://forums.commentcamarche.net/forum/affich-31259234-ma-ps-vita-ne-se-charge-plus#answers
    Visiting a console repair shop to ask for their opinion (at least, it's free) could guide you in searching for adequate solutions to do yourself online (not all battery repair manipulations are complicated, but the risk of damaging your console if done incorrectly is still there, you should be aware of that...)
    Hoping I've been helpful; if not, don't hesitate...
    "If you think you are too small to be effective, you have never been in bed with a mosquito."
    -Dalai Lama
