Problem with Fomax 25629 universal remote
miquette11
Posted messages
6
Status
Member
billmaxime Posted messages 50523 Registration date Status Contributor Last intervention -
Hello,
By mistake, while trying to increase the volume, my finger accidentally touched the small VCR button located just above. As a result, even though I've changed the batteries, the automatic connection isn't working. I tried inserting a cassette thinking it would reset the system, but that didn't work either. I attempted to reset it by following the steps with the device codes, but there's still no response. How can I resolve this issue?
Moreover, since the beginning, I haven't been able to change channels using the + and - buttons. Is there a solution?
Thanks to anyone who can provide helpful advice. Have a great day!
Thank you Billmaxime for your response; unfortunately, I'm unable to unlock the situation! There is indeed a TV/VCR button above the SET and TV1 or TV2 buttons, but nothing works! To get the red light to turn on, I can only press SET and, while holding that button down, press TV1, but if I press TV/VCR while the red light remains on, nothing happens. Do you have any other suggestions please?
hi
my finger touched the little VCR button
press the TV button and your problem should be solved
see you
the radiation level is higher at the unemployment office than at Chernobyl -
Re
If you have the remote control manual, I suggest you consult it because I can't find it on the NET
See you
The radiation level is higher at the employment center than at Chernobyl. -
re
look at this page to download/view the instructions
https://fr.wikihow.com/programmer-une-t%C3%A9l%C3%A9commande-universelle-sans-bouton-de-recherche-de-codes
