Bird-UM1 Sound quality issues and background noise?
Yann
Zarbik45 Posted messages 484 Status Member -
Hello,
I recently got a Bird-UM1 (yes, another one), but I have a problem.
The sound quality is poor, and I can hear the noises from my keyboard behind the microphone, as well as all the other sounds. There’s also a slight background noise that's not too bothersome, but if anyone has a tip for that, I'd appreciate it...
The microphone is supposed to be cardioid, so I don't understand why I'm picking up noises from behind.
I also don't get the sound quality.
Thanks in advance for your help.
Hello,
What do you use to record your microphone? (Mixer + XLR or USB and software)
“Life is a mystery to be lived, not a problem to be solved” - Gandhi-
Hello,
For now it's USB with Audacity, and I've also tried to listen to the mic directly through my headphones.
