PC Power Supply / sb power flashing
nayrb77 Posted messages 48 Status Member -
Hello, I bought a new Corsair 350W power supply to connect to an Asus M2N E SLI motherboard. The problem is that the tower won't start and the sb pwr LED on the motherboard is blinking instead of staying solid.
Here's what I've tested:
- I tested the power supply by shorting the ps-on and ground, and the power supply works.
- I connected the power supply to another tower with a Gigabyte motherboard and the power supply works.
- I tested a 250W FSP power supply on the Asus M2N E SLI and the power supply works, and the LED stays solid green.
- I tested the Corsair power supply on the Asus M2N E SLI by removing the RAM, HDD, USB devices, graphics card, and leaving only the CPU, and the power supply does not work.
When I say that the power supply does not work, I mean that the green sb power LED blinks instead of staying solid.
Thanks in advance.
Configuration: Windows 7 / Firefox 43.0
  1. vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention   Ambassador 3 592
    hi
    did you properly connect the P4 (4-pin) power connector to the motherboard connector at the top left???
    see you later
    no links on the web page in English, I already fly enough on my own
    1. nayrb77 Posted messages 48 Status Member 1
      The 12v from the CPU? Yes, I plugged it in.
  2. vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention   Ambassador 3 592
    You haven't touched the front panel connections on the motherboard???
    no link on the English web page, I'm already flying solo enough
      No, I haven't unplugged anything at that level. On the panel, I have the power led+, power led-, the hdd led, and the power sw that are connected.
    2. vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention   3 592
      I plugged the power supply into another tower with a Gigabyte motherboard and the power supply works
      I don't see what could happen
    3. nayrb77 Posted messages 48 Status Member 1 > vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention
      What does that mean?
    4. vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention   3 592
      OK
      I don't see the exact cause
      I've never had this case.
    5. nayrb77 Posted messages 48 Status Member 1
      Is it a bad contact between certain power supply wires and the connector?
  3. vieu bison boiteu Posted messages 44334 Registration date   Status Contributor Last intervention   Ambassador 3 592
    it's possible, we cannot rule out this hypothesis
    but knowing which contact
    no link on the webpage in English, I already steal enough by myself
  4. nayrb77 Posted messages 48 Status Member 1
    Hello, I tested the power supply on another Asrock motherboard and the same problem occurred, it doesn't work. I'm going to replace it.
    Thank you for your responses.
