Sound output issue: Razer Leviathan.
Coolbb -
sawsix Posted messages 4824 Registration date   Status Member Last intervention   -
Hello,
The sound bar is not producing any sound.
There is a crackling noise when it is plugged in and unplugged.
However, in the audio manager, the sound check tool does respond correctly to the volume changes.
Best regards,
Configuration: Windows / Chrome 42.0.2311.135
1 answer
  1. sawsix Posted messages 4824 Registration date   Status Member Last intervention   1 035
    Hi,
    You need to disable the audio device and then enable it again.
    -3
