Connecting a DVD player/recorder to a satellite receiver
Hello,
I have a SAMSUNG TV and a THOMSON Fransat satellite receiver. I bought a SAMSUNG DVD player/recorder BD-H8500. The DVD player is unable to recognize and tune TV or Radio channels. I was told that it’s impossible (except with a PANASONIC player that takes video outputs). Before I throw away my DVD player, has anyone any solution?
Thank you.
Thank you.
1 answer
Good evening,
First, I will give you the connections to follow:
1) SATELLITE ANTENNA <- CABLE -> SAT INPUT OF RECEIVER.
2) RECEIVER SAT OUTPUT <- CABLE -> INPUT " ANT IN " OF PLAYER/RECORDER.
3) OUTPUT " ANT OUT (TO TV) " <- CABLE -> TV ANTENNA INPUT.
4) RECEIVER HDMI OUTPUT <- CABLE HDMI -> HDMI 1 TV.
5) PLAYER/RECORDER HDMI OUTPUT <- CABLE HDMI -> HDMI 2 TV.
Back of player/recorder:
Back of receiver:
If these connections are made as described above, there should be no reason it wouldn’t work.
Regards ;-)
--> NO PROBLEMS, ONLY...SOLUTIONS <--
Alcohol doesn't solve anything, that said, neither do water or milk ;-)-
It was simply a matter of choosing a dual-tuner recording demodulator Fransat (for example an Aston HD Xena Fransat) with two antenna inputs connected to a dual-output LNB + 2 separate cables. In this ad hoc configuration you can watch any channel and record any other at the same time on Eutelsat 5WA.. (promo: the OCS bouquet is in free access until 5 Jan 2015 via the Fransat card)
