How to connect Wi-Fi on an OCEANIC LED185B3 TV
marazur06 -
 Marazur06 -
Hello,
I have a Free box Crystal, with the decoder connected to the living room TV.
I have a small TV bought for my daughter in her bedroom (upstairs), an OCEANIC LED185B3 without built-in Wi-Fi. I should mention that there is no antenna socket in her room... but my daughter bought a Thomson 537 antenna (which is useless in this case...)
How can I connect it to the FREE network without getting a multi-TV subscription and without running a bunch of cables?
Maybe there's a possibility with a router? but I don't know anything about that.
Thank you for your responses!
Configuration: Windows XP / Firefox 28.0
  1. Marazur06
    Thank you for your response, Jeannets!
    When you talk about an antenna, what type are you referring to?
    The TV is connected to an indoor THOMSON antenna, but I'm not getting any reception, or I may not know how to run the search (my daughter threw away the manual and I can't find it online...)
    2
