AC'97 & HD AUDIO Front Panel Wiring on MSI B85M-E33 Motherboard
Solved
av
krakixx Posted messages 3404 Registration date Status Member Last intervention -
Hello,
My problem is as follows: I bought a Cooler Master K350 case and an MSI B85M-E33 motherboard. I need to connect the AC'97 and HD AUDIO from the front panel to the motherboard. The case manual says to connect AC'97 to the corresponding port, but this port is not present on the motherboard. The HD AUDIO should be connected to a port named "Azilia (Intel High Definition Audio)" but this port is also missing. What should I do?
