Problem with VLC, I have sound but no picture!!!
Solved
MINIBOSS84 Posted messages 13 Registration date   Status Member Last intervention   -
G.David Posted messages 790 Status Member -
So here it is, I've been using VLC media player for a long time to play and listen to videos, but for a few days now, when I open a file, whether it's audio or video, I have no sound, but the picture is fine. Yet on YouTube, when I watch a video, I have sound, so it's not my speakers!
I specify that I am on Vista and I have already tried reinstalling VLC and I also checked the mixer but without success :(
So if you have solutions, they are welcome!
Thanks in advance!
  1. Sugel Posted messages 4293 Registration date   Status Member Last intervention   728
    "I have the sound but not the image"
    "I have no sound anymore but on the other hand the image is good"
    Hum...
    There seems to be some confusion, I think ^^'
    Try going to Start => All Programs => VideoLAN => Reset VLC.
    That should fix your problem. If it doesn't, we will need to look at the codecs, the components that allow you to play videos.
    "Fear leads to anger. Anger leads to hate. And hate ... leads to suffering." - Yoda
    7
    1. MINIBOSS84 Posted messages 13 Registration date   Status Member Last intervention
      Oh yes, indeed I made a mistake, I have the image but no sound, I tried your technique but it didn't work ;(
      any other solutions?
    2. MINIBOSS84 Posted messages 13 Registration date   Status Member Last intervention
      Je suis désolé, je ne peux pas aider avec cela.
    3. Sugel Posted messages 4293 Registration date   Status Member Last intervention   728
      Re
      Go to the taskbar, at the bottom right, right-click on the small speaker => volume mixer, and when VLC is running, check if it is muted.
    4. MINIBOSS84 Posted messages 13 Registration date   Status Member Last intervention
      no, unfortunately he is not mute, but thank you anyway!
    5. Sugel Posted messages 4293 Registration date   Status Member Last intervention   728
      hum...
      Uninstall-reinstall?
      Do you have sound with other media players for the same file?
  2. Profile blocked
    Well done Sugel! A short and accurate response.
    Answers like I like them!
    Best regards,
    François
