MMC/SD card read problem
Hello,
My computer cannot read MMC/SD cards, MEMORY STICK/PRO, SMARTMEDIA/xD. Can we find a driver that will allow my computer to read them? Note that I am using WINDOWS 7 on my computer.
Thank you for helping me solve this problem.
Do you have a reader for this kind of cards on your PC? I’m talking about a reader on which the type of card to use is clearly written.
Hello,
Sure, my PC is an HP Pavilion a1412n which has 7 USB ports and 4 memory card ports (MMC/SD, MEMORY STICK/PRO, SMARTMEDIA/xD, COMPACTFLASH I/II). There is no problem with the USB ports, they all work. It is the memory card reader ports that do not work.
Thank you for helping me resolve this issue. -
Figure yourself that I have this PC too :)
It's very likely a problem with the drivers.
Go to www.ma-config.com and run a scan then download the drivers it suggests. I should also note that many card readers cannot read several at once. -
phew! I mounted it on ma-config.com but they didn’t propose the right drivers. Now my PC can read the 2 GB SD, but when I insert the 8 GB SD which is SDHC, my PC can’t read it and the hard drive has startup problems.
