Problem uninstalling pdf suite
Solved
zouzou
kaneagle Posted messages 86285 Registration date Status Moderator Last intervention -
Hello,
I can't uninstall PDF Suite, it stops during the process with error code 2753.
Do you have a solution?
Configuration: Windows XP / Internet Explorer 6.0
Restart by tapping F8 to enter safe mode. Once there, go to Start, Control Panel, Add or Remove Programs, select PDF Suite and uninstall it, or go to: C\program files\pdf suite, click on uninstall or remove and the uninstallation will proceed.
Human beings are at their best when things are at their worst. -
Hello
which software are you trying to use to remove it
Ccleaner works well and is also free
Hello,
Try uninstalling it in safe mode.
Try uninstalling it with --> revo-uninstaller.
You're welcome
Have a good evening.
