Difference between ATX and EPS connectors?
AlphaBetaDeltaOmega
Posted messages
944
Status
Member
AlphaBetaDeltaOmega Posted messages 944 Status Member -
Hello, everything is in the title. What is the difference between the 4-pin ATX connectors on motherboards and the 8-pin EPS connectors on other motherboards?
For a Phenom II x4 955 Black Edition 125W, does this motherboard fit the bill?
https://www.materiel.net/
Thank you.
Thank you.
Hello
The EPS 8 pins is actually a doubled 4 pins ATX. The latter is called “P4”.
For the motherboard, it's fine, but new chipsets are being released right now, the AMD series 8xx, so the motherboard you've linked is becoming outdated. -
So what's the difference with the Series 7?
Is this one okay?
