Problem with universal head with 2 outputs
Hello,
I have just installed a new universal LNB with 2 outputs on my satellite dish, the problem is that I have no signal on the second television while the other one is working perfectly, I should specify that I have TNTsat.
Thank you for informing me about the steps to follow.
Configuration: Windows 7 Internet Explorer 8.0
I understand, but it is important to know that HD TV requires more sensitive equipment for signal reception and the signal transmission must be shielded against the slightest interference.
Good luck for the rest.-
@cricribudTo you, REDBART, I just wanted to thank you again, I followed your advice and it's working.
Maybe see you next time.
