Battery issue with Wii Fit
NEIGAZELLE
cath_c -
cath_c -
Hello everyone,
I have an issue with the Wii Fit charging battery.
I’ve tried charging for several hours, but nothing changes. When I press the power button, it lights up blue and then nothing!! Do you have a solution for what’s happening to me?
My Wii is on, the charger button is green.
Thank you for your help.
Configuration: Windows Vista Firefox 3.0.14
Hello.
I just bought the "Rechargeable battery pack" and I’m having the same problem.
The Wii balance board doesn’t turn on and when I put the battery to charge the indicator turns green to tell me the battery is charged.
What should I do? -
Hello,
You need to use the correct game, for example for Wii Fit you have to start the game and turn on the Balance Board when they say so
Cøkì죙
