Difference between DVB-T and TNT
Hello,
I want to know the different types of DVB standards and the difference between the DVB-T standard and TNT.
  • Descending date
  1. DVB-T stands for "Digital Video Broadcasting – Terrestrial". It is the part of the DVB standard applied to terrestrial radio transmissions. In France and Switzerland, this system is used for digital terrestrial television (TNT). This standard defines the method of transmitting television services (audio, video, and data), using OFDM modulation with a concatenation of channel coding (COFDM).
    1. why can't we record Fr3?
  2. Hello
    You have all the technical information on WIKIPEDIA
    hi
    1. Note that there is no difference between DVB-T and TNT since they are the same thing.
      However, there is a difference between the DVB-T standard (T = terrestrial) and the DVB-S standard (S = satellite), all of which fall under the framework of terrestrial broadcasting, without physical support, via airwaves. Cable and ADSL are not terrestrial, according to the ITU's definition, but there is increasing talk of
      the terrestrial distribution (wired)
      The DVB-S and T standards are "invariable" you cannot receive TNT with a DVB-S terminal, in less technical terms, no TNT via satellite dish.
      Do not take the presentations made by general media that do not technically master the subject literally.
