Probleme avec "fenetre de connexion"
je suis sous ubuntu 8.04 hardy et j'ai un souci avec le raccourci du menu "system/administration/fenetre de connexion
en effet quand je clique dessus, il demande le mot de passe puis la fenêtre s'ouvre et se referme immédiatement !!
merci de votre aide .
Joffrey
Configuration: Linux
Firefox 3.0.1
  1. bon, je peux preciser mon probleme un peu :)
    j'ai trouver l'executable pour essayer en commande
    $ sudo /usr/sbin/gdmsetup
    ext()
    gdmsetup[8725]: Pango-WARNING: Invalid UTF-8 string passed to pango_layout_set_text()
    Erreur de segmentation
    joffrey@joffrey-desktop:~$
    1. bon, j'ai fait des recherche qui mon rammené a ce fichier ;
      sudo gedit /etc/gdm/gdm.conf-custom
      j'obtiens :
      # GDM Configuration Customization file.
      # This file is the appropriate place for specifying your customizations to the
      # GDM configuration. If you run gdmsetup, it will automatically edit this
      # file for you and will cause the daemon and any running GDM GUI programs to
      # automatically update with the new configuration. Not all configuration
      # options are supported by gdmsetup, so to modify some values it may be
      # necessary to modify this file directly by hand.
      # Older versions of GDM used the "gdm.conf" file for configuration. If your
      # system has an old gdm.conf file on the system, it will be used instead of
      # this file - so changes made to this file will not take effect. Consider
      # migrating your configuration to this file and removing the gdm.conf file.
      # To hand-edit this file, simply add or modify the key=value combination in
      # the appropriate section in the template below. Refer to the comments in the
      # /usr/share/gdm/defaults.conf file for information about each option. Also
      # refer to the reference documentation.
      # If you hand edit a GDM configuration file, you should run the following
      # command to get the GDM daemon to notice the change. Any running GDM GUI
      # programs will also be notified to update with the new configuration.
      # gdmflexiserver --command="UPDATE_CONFIG <configuration key>"
      # e.g, the "Enable" key in the "[debug]" section would be "debug/Enable".
      # You can also run gdm-restart or gdm-safe-restart to cause GDM to restart and
      # re-read the new configuration settings. You can also restart GDM by sending
      # a HUP or USR1 signal to the daemon. HUP behaves like gdm-restart and causes
      # any user session started by GDM to exit immediately while USR1 behaves like
      # gdm-safe-restart and will wait until all users log out before restarting GDM.
      # For full reference documentation see the gnome help browser under
      # GNOME|System category. You can also find the docs in HTML form on
      # https://wiki.gnome.org/Projects/GDM
      # NOTE: Lines that begin with "#" are considered comments.
      # Have fun!
      [daemon]
      AutomaticLoginEnable=true
      AutomaticLogin=unik
      TimedLoginEnable=true
      TimedLogin=unik
      TimedLoginDelay=10
      [security]
      DisallowTCP=false
      [xdmcp]
      [gui]
      [greeter]
      SoundOnLoginFile=
      DefaultFace=
      GlobalFaceDir=///
      [chooser]
      [debug]
      [servers]
      si vous etes sur hardy pouvez le comparer au miens !
      1. alors vous êtes tous en vacances ou quoi?, moi j'en reviens
        bon en fouinant, oui car je cherche de mon coté aussi, vu le soutien , hein
        j'ai trouvé ceci :
        Ben moi, j'ai le même genre de problème depuis peu, mais je ne sais pas
        si c'est lié à gtk 1.x
        J'ai ça dans gkrelm2, et dans l'explorateur de fichier de openoffice et
        d'autres...
        quand je lance gkrellm2, j'ai cette erreur :
        (gkrellm2:19547): Pango-WARNING **: Invalid UTF-8 string passed to pango_layout_set_text()
        Pour nautilus (et probablement quelques autres applis gnome), ça semble
        réglé en commentant la ligne :
        G_FILENAME_ENCODING=UTF-8
        de /etc/env.d/50glib2
        or j'ai le meme message pour gdmsetup
        si qq un a une suggestion, car j'ai reardé dans " /gdm.conf-custom " mais y a rien de tel .
        une petite aide si petite soit elle
        Joffrey
