Acceleration graphique
Bonjour à tous
Je viens à vous après avoir longuement cherché sur internet...
Sur mon portable Acer 3003 Wlmi impossible d'activer l'accélération graphique... (Chipset intel intégré)
Voici quelques détails :
->lspci | grep "VGA"
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter
-> glxinfo | grep "direct rendering"
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
->LIBGL_DEBUG=verbose glxinfo|less
name of display: :0.0
display: :0 screen: 0
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_EXT_texture_from_pixmap
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (2.1 Mesa 7.0.1)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_fragment_program,
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_program,
GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
GL_ATI_draw_buffers, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_fragment_program, GL_NV_light_max_exponent, GL_NV_point_sprite,
GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x22 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x24 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x3d 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
(END)
Que vos lumières m'éclairent par pitié !!!
Merci d'avance.
KowA
GLX version: 1.2
GLX extensions:
OpenGL extensions:
(END)
Merci d'avance.
KowA
Configuration: Ubuntu 7.10 Firefox 2.0.0.8
Malheureusement sur LINUX c'est seulement sur les cartes ATI et NVIDEA qui bénéficient de pilotes propriétère quand peu activer l'accélération graphique pour les jeux; Les pilote libre ne le supporte pas pour l'instant sinon pour ceux qui ont des cartes graphique ATI et Nvidea et qui sont sur UBUNTU il faut aller dans system administration pilote de péripherique et espérer que votre carte sois supporté
Pas d'accord.
Chez moi (sidux), le pilote graphique libre d'intel fonctionne nickel, la 3D aussi. C'est d'ailleurs le driver le plus évolué. Il supporte déjà déjà des choses qui sortiront avec la prochaine version de linux et de xserver (kernel modesetting, dri2) ainsi que GEM qui vient de sortir avec linux 2.6.28.
D'ailleurs les pilotes graphiques propriétaires donnent parfois des soucis. Par exemple il y a des bugs graphiques avec kde 4 avec les drivers nvidia propriétaires qui sont dus à ces drivers. Depuis le temps que ça dure, les bugs n'ont tjrs pas été corrigés de la part de nvidia (en tout cas pas dans la version stable de leur driver). S'ils auraient été libres ces bugs aurait pu être corrigés par la communauté. -
@JonasBonjour,
Pourriez-vous poster votre xorg.conf ?
Il semble que chez moi, je n'ai pas l'extension GL_EXT_framebuffer_object.
Voici mon xorg.conf
# Xorg configuration created by pyxf86config
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "InputDevice"
# keyboard added by rhpxl
Identifier "Keyboard0"
Driver "kbd"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "intel"
Option "AddARGBGLXVisuals" "True"
Option "XAANoOffscreenPixmaps" "true"
Option "DRI" "true"
# Option "AccelMethod" "EXA" # Xaa old stable, EXA is new and better.
Option "AccelMethod" "exa"
Option "MigrationHeuristic" "greedy"
# Option "ExaNoComposite" "true"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
Virtual 3072 3072
EndSubSection
EndSection
Section "Module"
Load "glx"
Load "dri"
EndSection -
@JonasBonjour,
J'utilise le driver intel sous Fedora 9 avec DRI.
Je n'arrive pas à activer l'extension GL_EXT_framebuffer_object.
Avez-vous une idée?
Mon xorg.conf
EndSection
Driver "kbd"
EndSection
Section "Device"
Driver "intel"
Option "DRI" "true"
EndSection
Section "Screen"
Device "Videocard0"
DefaultDepth 24
Viewport 0 0
Depth 24
Virtual 3072 3072
EndSubSection
EndSection
Section "Module"
Load "extmod"
Load "glx"
Load "dbe"
Load "dri"
Load "freetype"
EndSection
et ce que donne glxinfo
direct rendering: Yes
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) 965GM 20061102
OpenGL version string: 2.0 Mesa 7.1 rc1
OpenGL extensions:
GL_ARB_fragment_shader, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_shading_language_120, GL_ARB_shadow, GL_ARB_texture_border_clamp,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_EXT_clip_volume_hint, GL_EXT_cull_vertex, GL_EXT_compiled_vertex_array,
GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_vertex_array, GL_3DFX_texture_compression_FXT1,
GL_APPLE_client_storage, GL_APPLE_packed_pixels,
GL_ATI_blend_equation_separate, GL_ATI_separate_stencil,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_point_sprite, GL_NV_texture_rectangle, GL_NV_texgen_reflection,
GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_OES_read_format,
3 GLX Visuals
0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x55 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
36 GLXFBConfigs:
0x56 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x57 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x58 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x59 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x5a 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x5b 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x5c 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5d 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5e 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5f 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x60 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x61 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x62 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x63 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x64 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x65 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x66 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x67 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x68 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x69 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6a 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6b 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6c 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6d 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6e 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x6f 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x70 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x71 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x72 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x73 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x74 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x75 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x76 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x77 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x78 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x79 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Petit up...
Je suis dans l'incapacité d'interpréter le LIBGL_DEBUG=verbose, la solution y réside surement mais tout seul je cale...
Merci de votre aide... -
J'ai exactement le même pb et je ne sais pas comment activer l'accélération graphique pour pouvoir utiliser Play on linux. Voici ce que la commande glxinfo | grep "direct rendering" me donne :
J'ai suivi à la lettre la documentation Radeon http://doc.ubuntu-fr.org/radeon mais j'ai toujours ce pb.
De plus je lance la commande LIBGL_DEBUG=verbose glxinfo | less et voilà le résultat :
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: ATI
client glx version string: 1.3
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
GLX_ARB_multisample
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R200 20060602 AGP 4x x86/MMX+/3DNow!+/SSE TCL
OpenGL version string: 1.3 Mesa 7.0.3
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x26 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x27 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x29 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2e 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2f 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x30 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x31 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x71 32 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
vincent@vincent-desktop:~$ glxinfo | grep "direct rendering"
vincent@vincent-desktop:~$ glxgears
9511 frames in 5.1 seconds = 1881.636 FPS
9600 frames in 5.0 seconds = 1906.285 FPS
9600 frames in 5.1 seconds = 1900.321 FPS
9587 frames in 5.0 seconds = 1905.312 FPS
9480 frames in 5.0 seconds = 1887.319 FPS
9600 frames in 5.0 seconds = 1906.238 FPS
9587 frames in 5.0 seconds = 1905.739 FPS
9600 frames in 5.0 seconds = 1905.374 FPS
9600 frames in 5.0 seconds = 1906.580 FPS
4440 frames in 5.5 seconds = 805.490 FPS
4320 frames in 5.0 seconds = 859.061 FPS
4320 frames in 5.1 seconds = 839.624 FPS
10680 frames in 5.0 seconds = 2118.867 FPS
12000 frames in 5.0 seconds = 2385.823 FPS
10231 frames in 5.1 seconds = 1989.509 FPS
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 272513 requests (264443 known processed) with 0 events remaining.
vincent@vincent-desktop:~$ lspci | grep "VGA"
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon RV250 If [Radeon 9000] (rev 01)
vincent@vincent-desktop:~$ sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.ok
vincent@vincent-desktop:~$ LIBGL_DEBUG=verbose glxinfo|less
libGL: XF86DRIGetClientDriverName: 5.3.0 r200 (screen 0)
libGL: OpenDriver: trying /usr/lib/dri/r200_dri.so
libGL error: dlopen /usr/lib/dri/r200_dri.so failed (/usr/lib/dri/r200_dri.so: undefined symbol: _glapi_get_dispatch)
libGL error: unable to find driver: r200_dri.so
MERCI D'AVANCE pour tout aide. -
Slt,
Ton pb est tjrs d'actualité?
Il semble que tu as un problème avec une fonction appelée par le driver.
Peux-tu faire un
ls -l usr/lib/libGL.so.1* -
Hi,
Apparement nous avons tous le meme probleme...
Pour ma part je suis sous Ubuntu 7.10 version PPC 64-bits (Playstation3),
bizarement j'ai reussi a activé les effets de bureau, tout marche a la perfection
par contre c'est mon processeur qui se charge de tout, donc sa rame un peu (beaucoup...).
Mon probleme (le notre) se situe au niveau du driver (generique). qui utilise mal (pas) la carte graphique, d'ou "direct rendering: no (if you want to...)".
Dans mon cas c'est la Firme nippone qui refuse l'acces au RSX (Nvidia) sous Linux (c'est chiant...).
Dans le votre, en installant tout un tas de lib et drivers, ca devrait fonctionner,
Ce sera plus compliqué pour les 64-bit (bienvenue au club).
Via Synaptic fait vos recherche pas mot clé (exemple: XGL).
Bon courage, Linux c'est l'avenir!
id psn: Aysteewan (pour plus de conseil sur Ubuntu PS3...) -
bonsoir pourriez vous m'aider svp je galere a mort j'en ai mal au crane je voudrai activé les effets virtuel ainsi que l'accelerateur graphique help me please!!!!!
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 2.1 Mesa 7.2
OpenGL shading language version string: 1.10
OpenGL extensions:
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_half_float_pixel, GL_ARB_imaging, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects,
GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_EXT_clip_volume_hint, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
GL_EXT_copy_texture, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit, GL_EXT_fog_coord,
GL_EXT_gpu_program_parameters, GL_EXT_histogram, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_paletted_texture, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object,
GL_ATI_blend_equation_separate, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATI_fragment_shader,
GL_ATI_separate_stencil, GL_IBM_multimode_draw_arrays,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_program_debug,
GL_MESA_resize_buffers, GL_MESA_texture_array, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_fragment_program,
GL_NV_light_max_exponent, GL_NV_point_sprite, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_OES_read_format, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGI_texture_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
2 GLX Visuals
0x3a 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
32 GLXFBConfigs:
0x3b 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x3c 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x3d 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x3e 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x3f 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x40 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x41 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x42 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x43 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x44 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x45 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x46 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x47 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x48 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x49 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x4a 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x4b 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x4c 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x4d 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x4e 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x4f 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x50 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x51 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x52 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x53 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x54 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x55 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x56 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x57 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x58 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x59 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5a 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
merci pour votre aide merci beaucoup
