Probleme connection sur site tchatche
Problème de connection sur le site www.tchatche.com.
Pas lié à java ou autre car persiste que ce soit du portable ou poste fixe.
Par contre d'autre (avec d'autres fournisserus accès) se connecte vu les 10000 connectés actuels)
Message du type
Could not load file or assembly 'App_Web_6_cnkgs7, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'App_Web_6_cnkgs7, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'App_Web_6_cnkgs7, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'App_Web_6_cnkgs7, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
ASP.design_tchatajax_panels_bottom_ascx.__BuildControlTree(design_tchatajax_panels_bottom_ascx __ctrl) +0
ASP.design_tchatajax_panels_bottom_ascx.FrameworkInitialize() +34
System.Web.UI.UserControl.InitializeAsUserControlInternal() +31
System.Web.UI.UserControl.InitializeAsUserControl(Page page) +14
ASP.design_tchatajax_default_aspx.__BuildControlForm1() +487
ASP.design_tchatajax_default_aspx.__BuildControlTree(design_tchatajax_default_aspx __ctrl) +133
ASP.design_tchatajax_default_aspx.FrameworkInitialize() +34
System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +40
System.Web.UI.Page.ProcessRequest() +86
System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +18
System.Web.UI.Page.ProcessRequest(HttpContext context) +49
ASP.design_tchatajax_default_aspx.ProcessRequest(HttpContext context) +4
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +154
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.
Internet Explorer 6.0
15 réponses
  1. Bonjour, pareil pour moi, de l'aide, svp
    1. il faut faire quelque chose contre sa je suis aller dans le meilleur magasin informatique de ma ville il on regarder le message ils mon di on ne peut pas vous aider que faire
        Meme histoire!!!
        sur le site tchatche.com j arrive sur la page d acceuil clic sur tchate francais,
        jusque la ok, on me met la page ou y a genre acces visiteur...
        J rempli mon profil et qd j mets ok ca vire sur le mm style de page...
        J y comprends rien ...juste comme ca un beau jour.
        Bonne journée!soirée..!
        1. J'ai le meme souci depuis hier soir j'arrive plus a me connecter sur tchatche.com message suivant apparait sur la fenetre:
          QUE FAIRE?
          Server Error in '/' Application.
          Source Error:
          or:
          <configuration>
          <system.web>
          </system.web>
          </configuration>
          Stack Trace:
          Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
          1. bonjour,j'ai le meme problème.je n'arrive pas a me connecter et j'ai le meme message qui s'affiche.que dois-je faire?merci d'avance pour votre aide.bonne journée
              j'ai trouvé la solution hehe
              sur la page d'accueil choisir chat arabic par exemple mettre en francais choisir son pays la france et ca marche !!!!!!!!!!!!!!!!!!!!!!!
              1. jais bien un conte mais je peux pas rentrer
            2. Moi aussi mais pourquoi c uniquement le français tous les autres fonctionnent Merci pour votre aide
              Source Error:
              or:
              <configuration>
              <system.web>
              </system.web>
              </configuration>
              Stack Trace:
                g le meme soucis je ne pe pas me connecté avec mon compte comment faire pour entrez avec son pseudo et mot de passe?
                  Pas la peine d'inonder ce site en répetant l'un après l'autre que ca marche pas. au bout du 3eme on a compris.
                  Faut attendre qu'il fixent le problème c'est tout.
                  Cyr
                    j'ai un problème sur mon post fixe, j'accède à la page d'accueil de tchatche.com mais si je clic sur tchat rien ne s'affiche seulement un simple bip de la page après ça disparait aussitôt. Veuillez me guidez SVP
                    1. Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210 la meme chose que vou touse
                      1. moi ca fait ca c normal?
                        X-Antivirus-Status: Scanning
                        HTTP/1.1 100 Continue
                        X-Antivirus: avast! 4
                        X-Antivirus-Status: Clean
                        HTTP/1.1 500 Internal Server Error
                        Date: Sun, 10 Feb 2008 15:40:24 GMT
                        Server: Microsoft-IIS/6.0
                        X-Server: NETWS03
                        X-Powered-By: ASP.NET
                        Cache-Control: private
                        Content-Type: text/html; charset=utf-8
                        Content-Length: 2814
                        <html>
                        <head>
                        <title>Request timed out.</title>
                        <style>
                        body {font-family:"Verdana";font-weight:normal;font-size: .7em;color:black;}
                        p {font-family:"Verdana";font-weight:normal;color:black;margin-top: -5px}
                        b {font-family:"Verdana";font-weight:bold;color:black;margin-top: -5px}
                        H1 { font-family:"Verdana";font-weight:normal;font-size:18pt;color:red }
                        H2 { font-family:"Verdana";font-weight:normal;font-size:14pt;color:maroon }
                        pre {font-family:"Lucida Console";font-size: .9em}
                        .marker {font-weight: bold; color: black;text-decoration: none;}
                        .version {color: gray;}
                        .error {margin-bottom: 10px;}
                        .expandable { text-decoration:underline; font-weight:bold; color:navy; cursor:hand; }
                        </style>
                        </head>
                        <body bgcolor="white">
                        <span><H1>Server Error in '/' Application.<hr width=100% size=1 color=silver></H1>
                        <h2> <i>Request timed out.</i> </h2></span>
                        <font face="Arial, Helvetica, Geneva, SunSans-Regular, sans-serif ">
                        <b> Description: </b>An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
                        <br><br>
                        <b> Exception Details: </b>System.Web.HttpException: Request timed out.<br><br>
                        <b>Source Error:</b> <br><br>
                        <table width=100% bgcolor="#ffffcc">
                        <tr>
                        <td>
                        An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
                        </td>
                        </tr>
                        </table>
                        <br>
                        <b>Stack Trace:</b> <br><br>
                        <tr>
                        <td>
                        <pre>
                        [HttpException (0x80004005): Request timed out.]
                        </pre>
                        </td>
                        </tr>
                        </table>
                        <br>
                        <b>Version Information:</b> Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
                        </font>
                        </body>
                        </html>
                        [HttpException]: Request timed out.
                        This error page might contain sensitive information because ASP.NET is configured to show verbose error messages using <customErrors mode="Off"/>. Consider using <customErrors mode="On"/> or <customErrors mode="RemoteOnly"/> in production environments.-->
