Probleme tconstruct
bonjour quand je veux lancer minecraft 1.7.10 avec tconstruct et mantle ça crach je n'ai que ces 2 mods et j'ai testé plusieures versions de forge ca me fait la meme voila le crash :
---- Minecraft Crash Report ----
// I bet Cylons wouldn't have this problem.
Time: 14/01/17 10:07
Description: There was a severe problem during mod loading that has caused the game to fail
cpw.mods.fml.common.LoaderException: java.lang.ClassNotFoundException: tconstruct.TConstruct
at cpw.mods.fml.common.LoadController.transition(LoadController.java:163)
at cpw.mods.fml.common.Loader.loadMods(Loader.java:544)
at cpw.mods.fml.client.FMLClientHandler.beginMinecraftLoading(FMLClientHandler.java:208)
at net.minecraft.client.Minecraft.func_71384_a(Minecraft.java:480)
at net.minecraft.client.Minecraft.func_99999_d(Minecraft.java:878)
at net.minecraft.client.main.Main.main(SourceFile:148)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
Caused by: java.lang.ClassNotFoundException: tconstruct.TConstruct
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:191)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at cpw.mods.fml.common.ModClassLoader.loadClass(ModClassLoader.java:58)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:344)
at cpw.mods.fml.common.FMLModContainer.constructMod(FMLModContainer.java:440)
at com.google.common.eventbus.EventSubscriber.handleEvent(EventSubscriber.java:74)
at com.google.common.eventbus.SynchronizedEventSubscriber.handleEvent(SynchronizedEventSubscriber.java:47)
at com.google.common.eventbus.EventBus.dispatch(EventBus.java:322)
at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:304)
at com.google.common.eventbus.EventBus.post(EventBus.java:275)
at cpw.mods.fml.common.LoadController.sendEventToModContainer(LoadController.java:212)
at cpw.mods.fml.common.LoadController.propogateStateMessage(LoadController.java:190)
at cpw.mods.fml.common.LoadController.distributeStateMessage(LoadController.java:119)
at cpw.mods.fml.common.Loader.loadMods(Loader.java:513)
... 10 more
Caused by: java.lang.IllegalArgumentException
at org.objectweb.asm.signature.SignatureVisitor.<init>(Unknown Source)
at tconstruct.preloader.ASMInterfaceRepair$SigChecker.<init>(ASMInterfaceRepair.java:98)
at tconstruct.preloader.ASMInterfaceRepair.verifyAPI(ASMInterfaceRepair.java:136)
at tconstruct.preloader.ASMInterfaceRepair.transform(ASMInterfaceRepair.java:39)
at net.minecraft.launchwrapper.LaunchClassLoader.runTransformers(LaunchClassLoader.java:279)
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:176)
... 38 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
Minecraft Version: 1.7.10
Operating System: Windows 7 (amd64) version 6.1
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 195337744 bytes (186 MB) / 327065600 bytes (311 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
FML: MCP v9.05 FML v7.10.99.99 Minecraft Forge 10.13.4.1492 6 mods loaded, 6 mods active
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
UC mcp{9.05} [Minecraft Coder Pack] (minecraft.jar)
UC FML{7.10.99.99} [Forge Mod Loader] (forge-1.7.10-10.13.4.1492-1.7.10.jar)
UC Forge{10.13.4.1492} [Minecraft Forge] (forge-1.7.10-10.13.4.1492-1.7.10.jar)
UC TConstruct-Preloader{0.1.1} [Tinkers Corestruct] (minecraft.jar)
UC Mantle{1.7.10-0.3.2.jenkins184} [Mantle] (Mantle-1.7.10-0.3.2.jar)
UE TConstruct{1.6.0d37} [Tinkers' Construct] (TConstruct_mc1.7.10_1.6.0d37.jar)
GL info: ' Vendor: 'ATI Technologies Inc.' Version: '3.3.11672 Compatibility Profile Context' Renderer: 'ATI Radeon HD 4300/4500 Series'
Mantle Environment: Environment healthy.
  1. ton tinker a l'air corrompu... il me semble
    essaye de télécharger avec d'autres versions
