Ligne de code sur PuTTY incomprenssible
Bonjour depuis quelques temps j'ai un vps ssous debian 7 jai voulu faire un serveur rust.Alpha
mais voila tout est installer mais quand je fait la commande ./Rustdedicated jai des lignes qui saffiche mais je ne comprend pas les voici :
root@klemens:~/Steam/steamapps/common/rust_dedicated# ./RustDedicated -batchmode
Set current directory to /root/Steam/steamapps/common/rust_dedicated
Found path: /root/Steam/steamapps/common/rust_dedicated/RustDedicated
Mono path[0] = '/root/Steam/steamapps/common/rust_dedicated/RustDedicated_Data/Managed'
Mono path[1] = '/root/Steam/steamapps/common/rust_dedicated/RustDedicated_Data/Mono'
Mono config path = '/root/Steam/steamapps/common/rust_dedicated/RustDedicated_Data/Mono/etc'
  1. Je ne connais pas rust.alpha, mais ces lignes ne ressemblent pas à des erreurs.
      M'est d'avis qu'il manque des paramètres à ta commande ;-(
      The startup command can be appended with the following startup parameters:
      parameter default description
      +server.ip 0.0.0.0 IP to listen to
      +server.port 28015 Port to listen to
      +server.tickrate 30 Server refresh rate (min acceptable 15, max 100) - Increasing this value increase CPU usage
      +server.hostname "Your Server Name" The displayed name of your server
      +server.identity "my_server_identity Changes path to your server data rust/server/my_server_identity. Useful for running multiple instances.
      +server.maxplayers 50 Max amount of players your server can handle. Max : 500 or more
      +server.wolrdsize 4000 Defines the size of the map generated (min 2000, max 8000)
      +server.saveinterval 600 Time in seconds for server save
      +rcon.ip 0.0.0.0 IP to listen to for RCON
      +rcon.port 28016 Port to listen to for RCON
      +rcon.password "YourPassword" RCON Password. If you remove it after setting it up, your server won't start.
      -logfile gamelog.txt If you're using a script, you'd better put the current date as a filename, otherwise, it'll be erased on every start.
      Source
      1. Allors comment faire pour que cela marche
          Se documenter, lire, lire encore et passer les bons paramètres ;-)
        2. C est ce que je fait c est pour sa que jai poser la question mais sur tout les forum il ny a pas d'explication
        3. Contributeur
          @klemens37Pourtant dans le lien donné plus haut il y a une belle ligne de paramètres en exemple ;-\
        4. Le truc c est que je ne sais pas comment faire pour l'écrire . Un exemple esce possible
        5. Après 10s de recherche sur internet :
          https://developer.valvesoftware.com/wiki/Rust_Dedicated_Server#Command_line_parameters
          Il y a la description de tous les paramètres et l'exemple suivant :
          ./Rustdedicated -batchmode +server.ip 0.0.0.0 +server.port 28015 +server.tickrate 30 +server.hostname "Your Server Name" +server.identity "your_server_identity" +server.maxplayers 50 +server.worldsize 4000 +server.saveinterval 600 +rcon.ip 0.0.0.0 +rcon.port 28016 +rcon.password "Your_Rcon_Password" -logfile logfilename.log"
          La valeur des paramètres dépend bien-sûr de ton serveur (adresse IP, port...)
