Code::blocks
code::blocks ;"htd - Debug": The compiler's setup (GNU GCC Compiler) is invalid, so Code::Blocks cannot find/run the compiler.
Probably the toolchain path within the compiler options is not setup correctly?! (Do you have a compiler installed?)
Goto "Settings->Compiler...->Global compiler settings->GNU GCC Compiler->Toolchain executables" and fix the compiler's setup.
Skipping...
Skipping...
Hello,
En gros il faut télécharger et/ou (ensuite) indiquer à codeblock dans sa configuration (Settings->Compiler...->Global compiler settings->GNU GCC Compiler->Toolchain executables) ou se trouve le compilateur ...
https://openclassrooms.com/forum/sujet/codeblocks-probleme-compileur
You may stop me but you can't stop us all ;-) -
ContributeurSalut,
Tu as probablement téléchargé une version de Codeblocks sans compilateur.
Désinstalle la, télécharge "codeblocks-16.01mingw-setup.exe" sur http://www.codeblocks.org/downloads/26 et installe le.
Dal
