Minecraft ne marche pas sur mon pc
minecraft ne marche pas sur mon pc, j'appuie sur PLAY puis quelques secondes plus tard il y a un message d'erreur, le voici en entier:
---- Minecraft Crash Report ----
// But it works on my machine.
Time: 20/10/15 10:07
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ave.ap(SourceFile:534)
at ave.am(SourceFile:363)
at ave.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.8
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.8.0_31, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 103590272 bytes (98 MB) / 159395840 bytes (152 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
PS: Windows 7, PC assez ancien (4/5 ans)
Merci d'avance!
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
LWJGL: 2.9.4
GL Caps:
Using VBOs: No
Resource Packs:
CPU: <unknown>
Merci d'avance!
Bien, si avant ton Minecraft marchait comme un ange, je te conseille ces étapes :
1 - Désinstalle ton Minecraft (Attention ! Tu vas perdre tout tes mondes et mods), pour cela, supprime déjà l'icône de raccourci sur ton Bureau si elle est là. Après, appuie sur la touche Windows (Celle ayant le logo de Windows dessus) et sur la touche R en même temps. Une fois que ça ouvre une petit fenêtre en bas à gauche, écrit dans la barre blanche :- %appdata%
Appuie sur Entrée après et tu auras un dossier qui va s'ouvrir, dans ce dossier tu vas trouver un autre dossier au nom de *.minecraft*, une fois trouvé ce dossier, supprime-le.
2 - Fais les nouvelles mises à jour de Java sur ce site : https://www.java.com/fr/download/
3 - Ré-installe Minecraft sur le site où tu l'as téléchargé, en général si tu as payé Minecraft il faut que tu vas sur ce site là pour le ré-installer : https://s3.amazonaws.com/Minecraft.Download/launcher/Minecraft.exe
4 - Re-joue, il faut que tu sais que peut-être que ta configuration PC (carte graphique, processeur,...) n'est pas bonne pour ce jeu, si tu veux vérifier va sur ce site :
https://www.systemrequirementslab.com/cyri/requirements/minecraft/11356/?p=a
Si il te demande des autorisations de Java, accepte-les.
A savoir aussi que si tu joues avec des mods, ta configuration PC ne peuvent pas tourner les plus gros.
Ne lisez pas ma signature (troll)-
@drakmoxDerien ! ;)
