OpenGL, Minecraft crash à chaque lancement. (need help!)
Ci-joint un rapport d'erreur reçu au lancement de Minecraft en 1.5.2 (nouveau launcher bien sûr), et si vous, personne(s) pouvant élucider mon problème, vous avez besoin d'un rapport d'erreur de mon Minecraft en 1.8, je pourrai vous le poster !
Merci d'avance pour votre aide, car j'en ai bien besoin ! <3 Ravel.
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 16/02/15 18:57
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows 8.1 (amd64) version 6.3
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 63936120 bytes (60 MB) / 127139840 bytes (121 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.RuntimeException: No OpenGL context found in the current thread.)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Thread.java:745)
--- END ERROR REPORT 36d3ebb3 ----------
Le problème porte sur le lancement de Minecraft 1.5.2 sous Windows 8.1, le jeu échouant à démarrer avec le message No OpenGL context found. La cause évoquée est généralement liée à des pilotes vidéo obsolètes ou incompatibles, et les solutions incluent la mise à jour des drivers et la désinstallation partielle des composants liés à la carte. D’autres pistes mentionnées dans le fil consistent à sauvegarder mods et ressources, supprimer le dossier .minecraft, puis vérifier l’utilisation de la carte graphique en mode haute performance. En cas de double GPU, des conseils évoquent d’assigner javaw.exe à la carte dédiée ou d’utiliser les paramètres du Catalyst Control Center pour forcer l’accélération graphique.
  1. Evidemment, j'ai essayer d'update mes drivers de carte graphique, mais faute de ma part, ça n'a apparamment rien changé.
      Comment tu t'y es pris ?
  2. Modérateur
    On va tenter de trouver un autre pilote.
    https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
    Copie-colle le résumé généré par AIDA64 dans ton prochain message.
    1. Ok, je vais faire mon possible.
  3. Ou si non tu sauvegarde tes mods et save puis resource pack et ensuite suprime ton .minecraft apres dis moi ce que sa donne
    1. déjà fait, ça ne change absolument rien
  4. --------[ AIDA64 Extreme ]----------------------------------------------------------------------------------------------
    Version AIDA64 v4.70.3200/fr
    Module de test 4.1.622-x64
    Site web https://www.aida64.com/
    Type de rapport Rapport rapide [ TRIAL VERSION ]
    Ordinateur HP450
    Générateur
    Système d'exploitation Microsoft Windows 8.1 6.3.9600.17328 (Win8.1 RTM)
    Date 2015-02-16
    Heure 19:39
    --------[ Résumé ]------------------------------------------------------------------------------------------------------
    Ordinateur:
    Type de système PC ACPI avec processeur x64 (Mobile)
    Service Pack du système [ TRIAL VERSION ]
    Internet Explorer 11.0.9600.17498
    DirectX DirectX 11.2
    Nom du système HP450
    Nom de l'utilisateur
    Domaine de connexion [ TRIAL VERSION ]
    Date / Heure 2015-02-16 / 19:39
    Carte mère:
    Type de processeur Mobile DualCore Intel Core i3-3120M, 2500 MHz (25 x 100)
    Nom de la carte mère Hewlett-Packard HP ProBook 450 G0
    Chipset de la carte mère Intel Panther Point HM76, Intel Ivy Bridge
    Mémoire système [ TRIAL VERSION ]
    DIMM3: SK Hynix HMT351S6EFR8A-PB [ TRIAL VERSION ]
    Type de Bios Unknown (06/24/2013)
    Moniteur:
    Carte vidéo Intel(R) HD Graphics 4000 (2118946 Ko)
    Accélérateur 3D AMD Radeon HD 8600M/8700M Series (Mars)
    Accélérateur 3D Intel HD Graphics 4000
    Moniteur LG Philips LP156WH3-TLAA [15.6" LCD]
    Multimédia:
    Carte audio IDT 92HD91BXX @ Intel Panther Point PCH - High Definition Audio Controller [C-1]
    Carte audio Intel Panther Point HDMI @ Intel Panther Point PCH - High Definition Audio Controller [C-1]
    Stockage:
    Contrôleur IDE Contrôleur AHCI SATA standard
    Contrôleur de stockage Contrôleur des espaces de stockage Microsoft
    Disque dur TOSHIBA MQ01ABD075 (750 Go, 5400 RPM, SATA-II)
    Lecteur optique hp CDDVDW SU-208CB
    État des disques durs SMART OK
    Partitions:
    C: (NTFS) [ TRIAL VERSION ]
    Taille totale [ TRIAL VERSION ]
    Entrée:
    Clavier Clavier standard PS/2
    Souris Souris compatible PS/2
    Souris Souris HID
    Réseau:
    Adresse IP principale [ TRIAL VERSION ]
    Adresse MAC principale
    Carte réseau Carte virtuelle directe Wi-Fi Microsoft
    Carte réseau Contrôleur Realtek PCIe GBE Family
    Carte réseau Ralink RT3290 802.11bgn Wi-Fi Adapter (192. [ TRIAL VERSION ])
    Périphériques:
    Imprimante Canon MG5500 series Printer WS
    Imprimante Fax
    Imprimante Microsoft XPS Document Writer
    Contrôleur USB2 Intel Panther Point PCH - USB 2.0 EHCI Controller #1 [C-1]
    Contrôleur USB2 Intel Panther Point PCH - USB 2.0 EHCI Controller #2 [C-1]
    Contrôleur USB3 Intel Panther Point PCH - USB 3.0 xHCI Controller [C-1]
    Périphérique USB Generic USB Hub
    Périphérique USB HP HD Webcam
    Périphérique USB Périphérique d'entrée USB
    Périphérique USB Périphérique USB composite
    Périphérique USB Ralink_RT3290_Bluetooth_01
    Batterie Adaptateur secteur Microsoft
    Batterie Batterie à méthode de contrôle compatible ACPI Microsoft
    DMI:
    Distributeur du Bios Hewlett-Packard
    Version du Bios 68IRF Ver. F.04
    Fabricant du système Hewlett-Packard
    Nom du système HP ProBook 450 G0
    Version du système A201BDD20B
    N° de série du système [ TRIAL VERSION ]
    UUID du système [ TRIAL VERSION ]
    Fabricant de la carte mère Hewlett-Packard
    Nom de la carte mère 1949
    Version de la carte mère KBC Version 90.0C
    N° de série de la carte mère [ TRIAL VERSION ]
    Fabricant du châssis Hewlett-Packard
    Version du châssis
    N° de série du châssis [ TRIAL VERSION ]
    Identifiant du châssis [ TRIAL VERSION ]
    Type du châssis Notebook
      "Accélérateur 3D AMD Radeon HD 8600M/8700M Series (Mars)
      Accélérateur 3D Intel HD Graphics 4000"
      --> Clic droit sur le Bureau > Catalyst Control Center
      Tu n'as pas un endroit pour mettre le fichier C:\Programmes\Java\jre8\bin\javaw.exe en hautes performances ?
      1. Je ne sais même pas l'emplacement du fichier en question, il faut malheureusement partir du principe que j'y connais pas grand chose dans ce domaine-là.
      2. ok
      3. mais c'est ce que j'ai fais mais comme tu a pus le constater en haut j'ai copie-coller ce que AIDA64 ma dit!!
      4. Modérateur
        J'ai modifié mon lien, il ne renvoyait pas vers le bon message.
        Comment tu t'y es pris pour mettre à jour le pilote de la carte graphique ?
