Problème Ecran Bleu
J'ai actuellement un problème d'écran bleu sur mon Pc :
Acer Aspire M7811 - Intel Core i3-530 - 8 Go
Intel Core i3-530 Processor (4M Cache, 2.93 GHz)
NVIDIA GForce 650 Zotac Amp Edition
8 Go de mémoire vive DDR3
Mes erreurs son les suivantes :
file:///C:/Documents%20and%20Settings/Thomas/Local%20Settings/Temporary%20Internet%20Files/OLKA4B/WhoCrashedOutput.htm
Les écrans bleus surviennent lorsque je joue à World of Warcraft pas pendant une navigation internet.
Je remercie d'avance les personnes qui répondront.
Bonne journée.
  1. Re bonjour,
    Rapport Whocrashed :
    System Information (local)
    computer name: THOMAS-PC
    windows version: Windows 7 , 6.1, build: 7600
    windows dir: C:\Windows
    Hardware: Aspire M7811, Acer, H57M01
    CPU: GenuineIntel Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz Intel586, level: 6
    4 logical processors, active mask: 15
    RAM: 8513486848 total
    VM: 2147352576, free: 1954902016
    Crash Dump Analysis
    Crash dump directory: C:\Windows\Minidump
    Crash dumps are enabled on your computer.
    On Sun 19/01/2014 19:59:13 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\011914-14476-01.dmp
    This was probably caused by the following module: win32k.sys (0xFFFFF9600026779C)
    Bugcheck code: 0x50 (0xFFFFF900C2904D44, 0x0, 0xFFFFF9600026779C, 0x0)
    Error: PAGE_FAULT_IN_NONPAGED_AREA
    file path: C:\Windows\system32\win32k.sys
    product: Système d'exploitation Microsoft® Windows®
    company: Microsoft Corporation
    description: Pilote Win32 multi-utilisateurs
    Bug check description: This indicates that invalid system memory has been referenced.
    This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
    The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
    crash dump file: C:\Windows\memory.dmp
    This was probably caused by the following module: win32k.sys (win32k!EngSetPointerShape+0x21A4)
    On Sat 18/01/2014 16:04:53 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\011814-16161-01.dmp
    This was probably caused by the following module: win32k.sys (win32k+0x22C9E6)
    Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960002EC9E6, 0xFFFFF88003A8E140, 0x0)
    Error: SYSTEM_SERVICE_EXCEPTION
    Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
    On Sat 18/01/2014 13:30:00 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\011814-19780-01.dmp
    This was probably caused by the following module: win32k.sys (win32k+0xC4283)
    Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960000F4283, 0xFFFFF8800674D060, 0x0)
    Merci d'avance et bonne journée.
