Problème d'installation du plugin more
Et bien voila j'ai un serveur minecraft bukkit version 1.7.2 j'installe le plugin MCore pour la version 1.7.2 et il me met ce message d'erreur:
Could not load 'plugins/mcore.jar' in folder 'plugins'
org.bukkit.plugin.InvalidPluginException: java.lang.UnsupportedClassVersionError: com/massivecraft/mcore/MCore : Unsupported major.minor version 51.0
at org.bukkit.plugin.java.JavaPluginLoader.loadPlugin(JavaPluginLoader.java:137) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.plugin.SimplePluginManager.loadPlugin(SimplePluginManager.java:308) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.plugin.SimplePluginManager.loadPlugins(SimplePluginManager.java:231) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.craftbukkit.v1_7_R1.CraftServer.loadPlugins(CraftServer.java:255) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.craftbukkit.v1_7_R1.CraftServer.<init>(CraftServer.java:233) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at net.minecraft.server.v1_7_R1.PlayerList.<init>(PlayerList.java:63) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at net.minecraft.server.v1_7_R1.DedicatedPlayerList.<init>(SourceFile:14) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at net.minecraft.server.v1_7_R1.DedicatedServer.init(DedicatedServer.java:126) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at net.minecraft.server.v1_7_R1.MinecraftServer.run(MinecraftServer.java:424) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at net.minecraft.server.v1_7_R1.ThreadServerApplication.run(SourceFile:617) [craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
Caused by: java.lang.UnsupportedClassVersionError: com/massivecraft/mcore/MCore : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClass1(Native Method) ~[?:1.6.0_65]
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637) ~[?:1.6.0_65]
at java.lang.ClassLoader.defineClass(ClassLoader.java:621) ~[?:1.6.0_65]
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141) ~[?:1.6.0_65]
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283) ~[?:1.6.0_65]
at java.net.URLClassLoader.access$000(URLClassLoader.java:58) ~[?:1.6.0_65]
at java.net.URLClassLoader$1.run(URLClassLoader.java:197) ~[?:1.6.0_65]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.6.0_65]
at java.net.URLClassLoader.findClass(URLClassLoader.java:190) ~[?:1.6.0_65]
at org.bukkit.plugin.java.PluginClassLoader.findClass(PluginClassLoader.java:77) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.plugin.java.PluginClassLoader.findClass(PluginClassLoader.java:62) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at java.lang.ClassLoader.loadClass(ClassLoader.java:306) ~[?:1.6.0_65]
at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ~[?:1.6.0_65]
at java.lang.Class.forName0(Native Method) ~[?:1.6.0_65]
at java.lang.Class.forName(Class.java:249) ~[?:1.6.0_65]
at org.bukkit.plugin.java.PluginClassLoader.<init>(PluginClassLoader.java:40) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
at org.bukkit.plugin.java.JavaPluginLoader.loadPlugin(JavaPluginLoader.java:133) ~[craftbukkit.jar:git-Bukkit-1.7.2-R0.2-3-g530fcb7-b2982jnks]
... 9 more
Est ce que quelqu'un pourrait m'aider svp ? merci d'avance
8 réponses
  1. La version de CraftBukkit ne supporte pas cette version de MCore (d'après ce qui est écrit)
    Chicken <3
    1. Mais j'ai installé le plugin mcore pour la version 1.7.2 et mon serveur minecraft est en 1.7.2 craftbukkit
      1. Peux-tu donner le lien du plugin ?
        1. Voilà le lien: http://dev.bukkit.org/bukkit-plugins/mcore/
          1. Tout le monde à le même problème que toi ...
            Lis les commentaires du plugin, tu trouveras sûrement une solution !
            1. Je suis sur MAC book pro ios j'ai JAVA 7 update 51 (la dernière version) mais JAVA 6 il me semble que je les mais je ne c'est pas comment desinstaller JAVA 6 sur MAC :,(
                1. Supprime complètement Java avant de mettre Java.
                  Sinon, essaye ce que j'ai dis, un autre monde !
