Probleme d'installation vista
Bonsoir tous le monde
J' ai fait une restart de mon pc portal asus f5n et pendant l'install sa beuguer quand depuis quand je le rallume j'ai( please wait while windows continues setting up your computer) qui charge et aprés j'ai ( the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install windows , click ok to restart the computer and then restart the installation.) donc je click sur ok et rien ne se passe quand je redemarr j'ai (cdboot could not find ntldr ) et une page (windows error recovery)
Voila mon probleme qui peut m'aider
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window)
2) In the black windows type the word "regedit"(without the inverted commas and hit enter. That will open the registry editor.
In the Registry Editor..
Browse to....
HKLocal machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box).
Then close the registry editor and then also close the black window.
Then click on OK for the error and the computer will restart and the installation may complete. just try it and let me know if it worked.
si quelqu'un veut bien traduire je dois aller me coucher ++
