[Nero] Probleme Gravure DVD
Résolu/Fermé
Bonjour, voici j'ai un probleme de gravure avec mon nero 7.
Quelqu'un peu m'aider avec ces logs ? Il grave les cd et non les dvds.
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
 (Nero Express)
Recorder:             <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 7.7.5.1
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <MITSUMI  CD-ROM FX240S !B>Version: j01  - HA 1 TA 1 - 7.7.5.1
Scsi-Device-Map
DiskPeripheral : MDT MD1200BB-00FTA0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4160B atapi Port 1 ID 0 DMA: On CdRomPeripheral : MITSUMI CD-ROM FX240S !B atapi Port 1 ID 1 DMA: Off
CDRom-Device-Map
HL-DT-ST DVDRAM GSA-4160B E: CDRom0 MITSUMI CD-ROM FX240S !B F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte BUFE : 0 Physical memory : 511MB (523504kB) Free physical memory: 305MB (312356kB) Memory in use : 40 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 16.2.2007 Graver une image DVD 16:08:21 #1 Text 0 File SCSIPTICommands.cpp, Line 411 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 16:08:21 #2 Text 0 File Burncd.cpp, Line 3465 Turn on Disc-At-Once, using DVD media 16:08:21 #3 Text 0 File DlgWaitCD.cpp, Line 306 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1799797 (399:57.22, 3515MB) 16:08:21 #4 Text 0 File DlgWaitCD.cpp, Line 318 Write in overburning mode: NO (enabled: CD) 16:08:21 #5 Text 0 File DlgWaitCD.cpp, Line 2912 Recorder: HL-DT-ST DVDRAM GSA-4160B, Media type: DVD-R Disc Manufacturer: TYG02 - Disc Application Code: 64, Disc Physical Code: 193 16:08:21 #6 Text 0 File DlgWaitCD.cpp, Line 490 >>> Protocol of DlgWaitCD activities: <<< ========================================= 16:08:22 #7 Text 0 File ThreadedTransferInterface.cpp, Line 823 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - Mode CD-ROM 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 1799798 (1799798) = #1799798/399:57.23 not relocatable, disc pos for caching/writing not required/not required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1799648 blocks [E: HL-DT-ST DVDRAM GSA-4160B] -------------------------------------------------------------- 16:08:22 #8 Text 0 File ThreadedTransferInterface.cpp, Line 1026 Prepare [E: HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3685986304, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 1799798 | 1799648 | 0x00 0 | 1 | 1 | 0x41 | 1799798 | 1799648 | 0x00 1799798 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 16:08:22 #9 Text 0 File SCSIPTICommands.cpp, Line 209 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 16:08:22 #10 Phase 24 File dlgbrnst.cpp, Line 1760 Caching of files started 16:08:22 #11 Text 0 File Burncd.cpp, Line 4298 Cache writing successful. 16:08:22 #12 Phase 25 File dlgbrnst.cpp, Line 1760 Caching of files completed 16:08:22 #13 Phase 36 File dlgbrnst.cpp, Line 1760 Burn process started at 8x (11 080 Ko/s) 16:08:22 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2764 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 16:08:22 #15 Text 0 File DVDR.cpp, Line 3070 Recording mode: Sequential Recording Mode 16:08:22 #16 Text 0 File DVDR.cpp, Line 3226 Start write address at LBA 0 DVD high compatibility mode: Yes 16:08:22 #17 Text 0 File Cdrdrv.cpp, Line 9288 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 1E75E4 h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 0 h Start sector number of the next Border-In: 0 h Media Specific [16..63]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 16:09:22 #18 SPTI -1039 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1039) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x09 Sense Qual: 0x01 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 04 00 00 00 00 10 32 34 00 0C 09 01 Buffer x22040040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16:09:22 #19 CDR -1039 File Writer.cpp, Line 301 Focus or tracking error E: HL-DT-ST DVDRAM GSA-4160B 16:09:23 #20 Text 0 File DVDR.cpp, Line 3446 EndDAO: Last written address was -1 16:09:23 #21 CDR -1039 File WriterStatus.cpp, Line 162 Focus or tracking error E: HL-DT-ST DVDRAM GSA-4160B 16:09:23 #22 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 16:09:25 #23 Phase 38 File dlgbrnst.cpp, Line 1760 Burn process failed at 8x (11 080 Ko/s) 16:09:26 #24 Text 0 File SCSIPTICommands.cpp, Line 254 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 16:09:28 #25 Text 0 File Cdrdrv.cpp, Line 10529 DriveLocker: UnLockVolume completed 16:09:28 #26 Text 0 File SCSIPTICommands.cpp, Line 411 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) </pre>
Internet Explorer 6.0
    l'origine de ton problème est matérielle, donc c'est soit le disque soit le graveur...
    plusieurs pistes à explorer :
    où achètes-tu tes DVD ? il existe de nombreuses contrefaçons des DVD Taiyo Yuden dont la qualité n'a rien à voir avec les vrais...
    https://www.afterdawn.com/guides/archive/dvd-r_media_report.cfm
    pour le graveur, débranche la prise électrique du lecteur de CDROM branché sur la même nappe IDE que ton graveur DVD LG et réessaye mais en 4x ...
    1. Ce que je trouve special, c'est qu'il grave les CD, mais pas les DVD. J'ai essayé verbatim et memorex que j'ai acheté chez bureau en gros.
      Je vais tenter un nettoyage. Je vous reviens avec ca.
    2. Voici, j'ai fait un nettoyage... et rien de plus. J'ai deconnecté mon autr cd rom et rien. J'ai meme fait un formatage et tout reinstaller. J'ai tester 3 sortes de dvd...dont verbatim.
      Comme j'ai dit, il grave les cd mais pas les dvds. Pourtant, il le faisiat bien avant.
      Voici le dernier log
      Windows XP 5.1
      IA32
      WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56
      ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34
      Nero Version: 6.6.0.13
      Internal Version: 6, 6, 0, 13c
       (Nero Express)
      Recorder:             <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 6.6.0.13
       Adapter driver:      <atapi>                   HA 1
       Bus Type      :      default (0) -> ATAPI, detected: ATAPI
      CD-ROM:               <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 6.6.0.13
      Scsi-Device-Map
      DiskPeripheral : MDT MD1200BB-00FTA0 atapi Port 0 ID 1 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4160B atapi Port 1 ID 0 DMA: On
      CDRom-Device-Map
      HL-DT-ST DVDRAM GSA-4160B E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523504kB) Free physical memory: 157MB (161372kB) Memory in use : 69 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 17.2.2007 Burn DVD Image 03:56:12 #1 Text 0 File Reader.cpp, Line 127 Reader running 03:56:12 #2 Text 0 File Writer.cpp, Line 122 Writer HL-DT-ST DVDRAM GSA-4160B running 03:56:12 #3 Text 0 File Burncd.cpp, Line 3167 Turn on Disc-At-Once, using DVD media 03:56:12 #4 Text 0 File DlgWaitCD.cpp, Line 260 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1799797 (399:57.22, 3515MB) 03:56:12 #5 Text 0 File DlgWaitCD.cpp, Line 272 Write in overburning mode: NO (enabled: CD) 03:56:12 #6 Text 0 File DlgWaitCD.cpp, Line 2339 Recorder: HL-DT-ST DVDRAM GSA-4160B, Media type: DVD-R Disc Manufacturer: MCC 03 - RG20 Disc Application Code: 64, Disc Physical Code: 193 03:56:12 #7 Text 0 File DlgWaitCD.cpp, Line 438 >>> Protocol of DlgWaitCD activities: <<< ========================================= 03:56:12 #8 Text 0 File ThreadedTransferInterface.cpp, Line 830 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 1799798 (1799798) = #1799798/399:57.23 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1799798 blocks [HL-DT-ST DVDRAM GSA-4160B] -------------------------------------------------------------- 03:56:12 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1043 Prepare recorder [HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3685986304, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1799798 | lead-out | 1 | 0x41 | 0x00 03:56:12 #10 Phase 24 File dlgbrnst.cpp, Line 1832 Caching of files started 03:56:13 #11 Text 0 File Burncd.cpp, Line 4051 Cache writing successful. 03:56:13 #12 Phase 25 File dlgbrnst.cpp, Line 1832 Caching of files completed 03:56:13 #13 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 4x (5 540 KB/s) 03:56:13 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2609 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 03:56:13 #15 Text 0 File DVDR.cpp, Line 2267 Recording mode: Sequential Recording Mode 03:56:13 #16 Text 0 File Mmc.cpp, Line 21469 Set BUFE: Buffer underrun protection -> ON 03:56:13 #17 Text 0 File DVDR.cpp, Line 2421 Start write address at LBA 0 DVD high compatibility mode: Yes 03:56:13 #18 Text 0 File Cdrdrv.cpp, Line 8438 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 5 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16..63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 03:57:30 #19 SCSI -1194 File Cdrdrv.cpp, Line 1436 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x063C0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x04 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10 0x32 0x38 0x00 0x0C 0x73 0x04 03:57:30 #20 CDR -1194 File Writer.cpp, Line 311 PMA update failure 03:57:30 #21 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 03:57:30 #22 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 03:57:30 #23 Text 0 File DVDR.cpp, Line 2658 EndDAO: Last written address was -1 03:57:46 #24 CDR -1194 File WriterStatus.cpp, Line 167 PMA update failure HL-DT-ST DVDRAM GSA-4160B\H1 T0 03:57:46 #25 TRANSFER -24 File WriterStatus.cpp, Line 167 Could not perform end of Disc-at-once 03:57:46 #26 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 4x (5 540 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02 File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2002-12-31 07:00:00 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) </pre>
    3. Contributeur
      @luckyCharmSalut
      Note que les Memorex ne valent pas grand chose.
    4. @Oric1Bonjour
      J'ai fait la mise à jour et toujours le meme probleme. Voici le dernier log
      Windows XP 5.1
      IA32
      ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
      NT-SPTI used
      Nero Version: 6.6.1.4
      Internal Version: 6, 6, 1, 4d
       (Nero Express)
      Recorder:             <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 6.6.1.4
      CD-ROM:               <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 6.6.1.4
      Scsi-Device-Map
      CDRom-Device-Map
      HL-DT-ST DVDRAM GSA-4160B E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523504kB) Free physical memory: 164MB (168164kB) Memory in use : 67 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 17.2.2007 Burn DVD Image 11:43:08 #1 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 72704KB of Memory 11:43:08 #2 Text 0 File Reader.cpp, Line 124 Reader running 11:43:08 #3 Text 0 File Writer.cpp, Line 122 Writer HL-DT-ST DVDRAM GSA-4160B running 11:43:08 #4 Text 0 File Burncd.cpp, Line 3305 Turn on Disc-At-Once, using DVD media 11:43:08 #5 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1799797 (399:57.22, 3515MB) 11:43:08 #6 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 11:43:08 #7 Text 0 File DlgWaitCD.cpp, Line 2612 Recorder: HL-DT-ST DVDRAM GSA-4160B, Media type: DVD-R Disc Manufacturer: MCC 03 - RG20 Disc Application Code: 64, Disc Physical Code: 193 11:43:08 #8 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 11:43:08 #9 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 1799798 (1799798) = #1799798/399:57.23 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1799798 blocks [HL-DT-ST DVDRAM GSA-4160B] -------------------------------------------------------------- 11:43:08 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3685986304, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1799798 | lead-out | 1 | 0x41 | 0x00 11:43:08 #11 Text 0 File SCSIPassThrough.cpp, Line 38 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 11:43:08 #12 Text 0 File SCSIPassThrough.cpp, Line 83 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 11:43:08 #13 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 11:43:08 #14 Text 0 File Burncd.cpp, Line 4145 Cache writing successful. 11:43:08 #15 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 11:43:08 #16 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 4x (5 540 KB/s) 11:43:08 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 11:43:08 #18 Text 0 File DVDR.cpp, Line 2707 Recording mode: Sequential Recording Mode 11:43:08 #19 Text 0 File DVDR.cpp, Line 2863 Start write address at LBA 0 DVD high compatibility mode: Yes 11:43:08 #20 Text 0 File Cdrdrv.cpp, Line 8647 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16..63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 11:44:30 #21 SPTI -1194 File SCSIPassThrough.cpp, Line 289 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1194) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x04 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 10 32 38 00 0C 73 04 Buffer x03740000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11:44:30 #22 CDR -1194 File Writer.cpp, Line 311 PMA update failure E: HL-DT-ST DVDRAM GSA-4160B 11:44:30 #23 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 11:44:30 #24 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 11:44:30 #25 Text 0 File DVDR.cpp, Line 3103 EndDAO: Last written address was -1 11:44:46 #26 CDR -1194 File WriterStatus.cpp, Line 167 PMA update failure E: HL-DT-ST DVDRAM GSA-4160B 11:44:46 #27 TRANSFER -24 File WriterStatus.cpp, Line 167 Could not perform end of Disc-at-once 11:44:46 #28 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 4x (5 540 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02 Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) </pre>
  2. Autre question... Il est possible que le graveur soit brisé ... mais qu'il est capable de ...
    -Lire les cd
    -Lire les DVD
    -Graver les cd
    Mais ne peut pas...
    -Graver les DVD?
      Bonsoir LuckyCharm
      L'idéal avant d'acheter inutilement, serait de trouver un graveur du même type qui fonctionne et de l'essayer sur votre ordinateur ou encore d'essayer votre graveur sur un ordinateur dont la gravure de DVD est effective. Vous saurez vite ainsi si votre problème est logiciel ou matériel.
    2. Merci du conseil ! :)
      J'ai mis à jour en meme temps avec le site : https://www.touslesdrivers.com/ un driver que je n,avais pas vu. Et vlan...il se met à graver. Je ne saute pas tout de suite à capoter. Je vais faire d'autres vérifications.
    3. Bonjour, je vous explique ce qui en est. Le tout semble regler.
      Donc.. quand je mets mes DVD... il m'offre 4 ou 8X. J'ai alors choisis 2x sans DVd...et ensuite... j'ai mis le DVD pour quil grave bien à 2 X...
      Puis, avec la mise a jour trouver sur le site precedemment dit, le tout fonctionne bien.
      DVD: verbatim.
      Voilà! Merci et bonne chance aux autrs :)
    4. @luckyCharmsalut! j'ai le meme prob que toi. mon graveur lis et grave les cdr mais pa les dvd.
      dés que je met ub dvd le graveur reste inactif.Je ne comprend pas.mon gravur est un hl-dt-st il était incorporé dans la tour acer
      Voilà je ne sais que faire.Merci à toi si tu pouvais m'orienter un peu
      sandri.
  3. Contributeur
    Il se vend des cd munis de petites brosses qui permettent de nettoyer les lentilles (et qui suffisent généralement si vous n'avez pas un enfant qui mange de la confiture ou du miel sur ses dvd. J'ai l'impression qu'un nettoyage réglerait votre problème.
    Pour faire le même travail manuellement, ces deux sites peuvent être utiles:
    http://www.station-drivers.com/page/depcd.htm
    https://fr.audiofanzine.com/platine-cd/pedago/tutoriels/Nettoyer-et-r%25C3%25A9gler-la-lentille-d%2527un-lecteur-CD-3076/
    Bonne chance!
    1. Bonjour à tous, j'ai le même soucis que cité ci dessus, mais je semble ne pas m'y connaitre autant en informatique que vous... alors je vois que le problème est resolu mais je ne comprend pas de quelle manière en fait...
      Donc, j'ai un ordi portable avec dvd rom, dvd rw
      il lit les cd
      il grave les cd
      il lit les dvd
      mais ne grave pas les dvd : il marque
      : writting error : error occurred writting data to disc
      unknown error use extended date for more information ( 1051.)
      error sence data : SENSE KEY : 2 ASC : 30 ASCQ : 11
      Alors voilà, pour info, j'utilise nero, mais j'en ai essayé plein d'autres et c toujours pareil.... au dernier moment, ça bugg .... je ne sais plus quoi faire.... si vous pouvez m'aider, vous seriez au top.
      J'ai acheté un camescope disc dur depuis plusieurs mois, et je ne peux graver dvd!
      Sinon, j'utilise dvd R, mes videos sont au format mpg...
      HELP !!!! PLEASE!!!!!
      1. Bonjour. Mon lecteur/graveur cd et dvd Philips remplit toutes ses fonctions sauf celle de graveur dvd...
        J'ai installé Néro Ultra Prémium dernièrement.
        Serais-t-ce une incompatibilité de programmes (dvdFab Platinium+any dvd+dvd Shrink+dvd Copy6,...)? J'ai supprimé Any dvd maisq cela ne semble rien changer au problème...
        On dirait que le graveur dvd n'existe plus?...
        Voyez plutôt le message d'erreur reçu lorsque je tente de graver un dvd préalablement compressé par dvd Shrink:
        Code:
        Windows XP 5.1
        IA32
        WinAspi: File 'Wnaspi32.dll': Ver=2.0.1.45, size=172099 bytes, created 11/10/2003 16:53:12
        ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14/03/2007 12:43:16
        NT-SPTI used
        Nero API version: 7.10.1.0
        Using interface version: 6.3.1.4
        Installed in: C:\Program Files\Nero\Nero 7\Core\
        Application: ahead\Nero - Burning Rom
        Internal Version: 7, 10, 1, 0
        Recorder: <_NEC DVD_RW ND-3500AG> Version: 2.88 - HA 1 TA 1 - 7.10.1.0
        === Scsi-Device-Map ===
        CdRomPeripheral : IVI Virtual CD 0.5a iviVD Port 0 ID 0 DMA: Off
        DiskPeripheral : ST3160021A atapi Port 1 ID 0 DMA: On
        CdRomPeripheral : PHILIPS DROM6216 atapi Port 2 ID 0 DMA: On
        CdRomPeripheral : _NEC DVD_RW ND-3500AG atapi Port 2 ID 1 DMA: On
        === CDRom-Device-Map ===
        PHILIPS DROM6216 D: CdRom0
        _NEC DVD_RW ND-3500AG E: CdRom1
        IVI Virtual CD K: CdRom2
        AutoRun : 1
        Excluded drive IDs:
        BUFE : 0
        Physical memory : 511MB (523756kB)
        Free physical memory: 157MB (161592kB)
        Use Inquiry : 1
        6.12.2007
        NeroAPI
        17:15:25 #1 Phase 112 File APIProgress.cpp, Line 285
        DVD-Video files reallocation started
        17:15:26 #2 Phase 114 File APIProgress.cpp, Line 285
        DVD-Video files reallocation completed (no file modified)
        17:15:26 #3 Phase 111 File APIProgress.cpp, Line 285
        DVD-Video files sorted
        17:15:26 #4 Text 0 File SCSIPTICommands.cpp, Line 424
        17:15:26 #5 Text 0 File AudioCompilationImpl.cpp, Line 838
        DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
        DRM: Beginning burn process.
        17:15:26 #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
        First writeable address = 0 (0x00000000)
        17:15:26 #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
        17:15:26 #8 Text 0 File Burncd.cpp, Line 3508
        17:15:27 #9 Text 0 File DlgWaitCD.cpp, Line 307
        Last address to be written: 2042431 (453:52.31, 3989MB)
        17:15:27 #10 Text 0 File DlgWaitCD.cpp, Line 319
        17:15:27 #11 Text 0 File DlgWaitCD.cpp, Line 2972
        Recorder: _NEC DVD_RW ND-3500AG, Media type: DVD-R
        Disc Manufacturer: PRINCO - RGM1
        17:15:27 #12 Text 0 File DlgWaitCD.cpp, Line 493
        17:15:27 #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
        0: TRM_DATA_MODE1 ()
        original disc pos #0 + 2042432 (2042432) = #2042432/453:52.32
        relocatable, disc pos for caching/writing not required/ required
        -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2042432 blocks [E: _NEC DVD_RW ND-3500AG]
        17:15:27 #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
        Prepare [E: _NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO
        DAO infos:
        MCN: ""
        1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4182900736, ISRC ""
        DAO layout:
        0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
        0 | 1 | 1 | 0x41 | 2042432 | 0 | 0x00
        2042432 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
        17:15:27 #15 Text 0 File SCSIPTICommands.cpp, Line 215
        SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
        17:15:27 #16 Text 0 File Burncd.cpp, Line 4294
        Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
        17:15:27 #17 Phase 24 File APIProgress.cpp, Line 285
        17:15:27 #18 Text 0 File Burncd.cpp, Line 4413
        17:15:27 #19 Phase 25 File APIProgress.cpp, Line 285
        17:15:27 #20 Phase 36 File APIProgress.cpp, Line 285
        Burn process started at 8x (11.080 KB/s)
        17:15:27 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
        Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
        17:15:27 #22 Text 0 File DVDR.cpp, Line 3225
        17:15:27 #23 Text 0 File DVDR.cpp, Line 3381
        17:15:27 #24 Text 0 File Cdrdrv.cpp, Line 9869
        ---- Disc Structure: Physical Format Information (00h) ----
        Revision number of maximum recording speed: 6.0
        Revision number of minimum recording speed: -
        Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
        Class: 0
        17:15:27 #25 SPTI -1046 File SCSIPassThrough.cpp, Line 179
        CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1046)
        Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
        Sense Code: 0x30
        Sense Qual: 0x05
        CDB Data: 0x53 00 00 00 00 00 1F 2A 40 00 00 00
        Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
        17:15:27 #26 CDR -1046 File ThreadedTransferInterface.cpp, Line 1752
        Illegal disc
        17:15:27 #27 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
        Could not perform start of Disc-at-once
        17:15:27 #28 Text 0 File ThreadedTransfer.cpp, Line 269
        Pipe memory size 74390400
        17:15:27 #29 Phase 38 File APIProgress.cpp, Line 285
        Burn process failed at 8x (11.080 KB/s)
        17:15:27 #30 Text 0 File AudioCompilationImpl.cpp, Line 863
        DRM: DRM burn session terminated.
        17:15:27 #31 Text 0 File AudioCompilationImpl.cpp, Line 892
        DRM: Closing entire DRM handling. Bye.
        17:15:27 #32 Text 0 File SCSIPTICommands.cpp, Line 261
        17:15:29 #33 Text 0 File Cdrdrv.cpp, Line 11185
        17:15:29 #34 Text 0 File SCSIPTICommands.cpp, Line 424
        Existing drivers:
        File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 8/01/2006 17:49:05 (Prassi/Veritas driver for win 2K)
        Registry Keys:
